Ranjan's MX-5 Track car.
For reviews / technical discussions on the other car.. using the knowledge of others on the forum
Has thanked: 28 times
Been thanked: 225 times
Re: Good riddance
Post by Neilparry » Wed Mar 18, 2020 8:58 pm
boosted wrote:
Neilparry wrote:Jon if you’ve got too much on I’ll take it off your hands.
Im ok thanks...worth a mint in bits...but i will restore! ImageImage
Thought you might say that ImageImageImage
boosted
Has thanked: 72 times
Been thanked: 370 times
Re: Good riddance
Post by boosted » Wed Mar 18, 2020 11:14 pm
warpc0il wrote::shock: I thought you meant 10th MX-5 for a minute, until I saw the badge :roll: :D
Nope number 24!! ( i think).
xamtex
Been thanked: 104 times
Re: Good riddance
Post by xamtex » Fri Mar 20, 2020 2:54 am
These users thanked the author xamtex for the post:
Ranjan (Fri Mar 20, 2020 10:10 am)
Ranjan
Has thanked: 38 times
Been thanked: 418 times
Re: Good riddance
Post by Ranjan » Fri Mar 27, 2020 2:55 am
Received a phone call 10 minutes ago from my contact in Japan saying they have found 3 ex-Racing mk1 bodyshells that would suit my requirements; it’s finally coming together.
Will have to outsource the viewing, damn it.
Ranjan.
boosted
Re: Good riddance
Post by boosted » Fri Mar 27, 2020 6:08 am
Check out Guido from sps motorsport in Germany... some fantastic engineering coming out of their workshops for all mx5s.
boosted
Re: Good riddance
Post by boosted » Fri Mar 27, 2020 6:10 am
Check the cages are hardtop compatiable....99% are not. For me i want windscreen and roof. After the Westfield its something i wont compromise on now.
Ive been in contact with Caged but no reply from then.
Has thanked: 4494 times
Been thanked: 1847 times
Re: Good riddance
Post by ChrisHolmes » Fri Mar 27, 2020 9:20 am
Uncle Neil Parry could make you a custom cage probably.
Exedy Stg1 Clutch
Custom front bumper, grills & Side Skirts
Adaptronic ECU
Has thanked: 112 times
Been thanked: 258 times
Re: Good riddance
Post by mrspiller » Fri Mar 27, 2020 9:54 am
boosted wrote:Check the cages are hardtop compatiable....99% are not. For me i want windscreen and roof. After the Westfield its something i wont compromise on now.
You going full cage Jon ?
boosted
Re: Good riddance
Post by boosted » Fri Mar 27, 2020 10:03 am
I want to build to race regs...cage that fits a hardtop overtop.
Re: Good riddance
Post by ChrisHolmes » Fri Mar 27, 2020 10:13 am
That rules out Neil then.
Exedy Stg1 Clutch
Adaptronic ECU
Re: Good riddance
Post by Neilparry » Fri Mar 27, 2020 10:18 am
As long as you follow the blue book regs you’ll be able to make one yourself. ( someone will correct me if I’m wrong) but I’m sure that’s the case.
Depending if you trust your welding skills
ChrisHolmes (Fri Mar 27, 2020 10:23 am)
Has thanked: 575 times
Been thanked: 477 times
Re: Good riddance
Post by New Duke » Fri Mar 27, 2020 10:33 am
I thought MK1s won't take E10 fuel? Any solution for when that comes in?
boosted
Re: Good riddance
Post by boosted » Fri Mar 27, 2020 10:51 am
Dont see it as an issue and choose another fuel.
boosted
Re: Good riddance
Post by boosted » Fri Mar 27, 2020 10:54 am
boosted
Re: Good riddance
Post by boosted » Fri Mar 27, 2020 10:59 am
More concerned about the FD....
Lean condition on boost not good.
Re: Good riddance
Post by ChrisHolmes » Fri Mar 27, 2020 11:06 am
I just had a wonderful thought regarding the rubber/viton seals in rotor oil seals when E10 fuel is used. Potentially I suppose the oil film on these may delay or even negate any side effects but does anyone know for sure?
Exedy Stg1 Clutch
Adaptronic ECU
boosted
Re: Good riddance
Post by boosted » Fri Mar 27, 2020 11:10 am
Ethanol is 33% less efficient than petrol....so range and performance effected...so more fuel needed. . Blimin climate change con...
Re: Good riddance
Post by ChrisHolmes » Fri Mar 27, 2020 11:13 am
If the blender at the refinery has dyslexia the effect of 10% M ethanol would be interesting!
Exedy Stg1 Clutch
Adaptronic ECU
Re: Good riddance
Post by New Duke » Fri Mar 27, 2020 11:39 am
I'll cross my fingers for you guys then. My understanding was that nothing was formalised on that front and that the current plan is for E5 protection fuel to be sold in limited locations for a limited time until everything at some point is E10. Which is exactly how E5 was rolled out in most of Europe and just like every fuel (even V-Power) in the UK is now E5.
Ethanol is 33% less efficient than petrol....so range and performance effected...so more fuel needed. Image. Blimin climate change con...
The E10 mix will be 1.5-3% less efficient that E5. So yes the reduced power and efficiency don't really outweigh the 2% reduced emissions. It'll cost less to make but cost no less at the pump.
Been thanked: 166 times
Re: Good riddance
Post by Yorindesarin » Fri Mar 27, 2020 1:41 pm
Meanwhile... We have a lovely oil war going on... I couldn't believe my eyes when I saw petrol at just £1.07 a litre... Makes premium £1.12~ for tesco momentum.. Compared to the £1.33 I was paying last year at around this time... Thats quite a big difference. Ridiculous really.
Ranjan
Re: Good riddance
Post by Ranjan » Fri Mar 27, 2020 2:36 pm
This is never going to be a road car so I need a proper cage so will definitely not fit under a roof.
I think I will stick with Flyin Miata for all my stuff; just drop it off at theirs and have everything done by one company.
Have placed an order for the Pandem carbon kit including all wings, doors, bonnet, boot, diffuser, and splitter; eye-watering price.
As for fuel I am going to be running it on racing 110 octane which is still going to be produced or so I have been told.
Ranjan.
These users thanked the author Ranjan for the post:
ChrisHolmes (Fri Mar 27, 2020 5:37 pm)
Re: Good riddance
Post by Yorindesarin » Fri Mar 27, 2020 3:05 pm
Sticking NA or going Turbo Ranjan? I can't remember if you made a decision about what engine was going to be in it.
Ranjan
Re: Good riddance
Post by Ranjan » Fri Mar 27, 2020 11:34 pm
Ollie,
Have not decided yet.
Turbo or supercharger, or both, or neither :-k :-k
Will need to have a word with the guys at Mazda.
Ranjan.
Has thanked: 9338 times
Been thanked: 2235 times
Re: Good riddance
Post by GreySilver Beast » Fri Mar 27, 2020 11:41 pm
I have put Race Fuel in the GT86 before when I was in Germany back in 2018 and christ did the car shift :shock:
RX-8OC Club Calendar - R.A.C.E Car Club - NPT Website - GSB III 03/08/13 - Present
S/D-C/limits - RX-8,3MPS,RX-8 R3,GT86 =17 Skid Pan =1 Go Karting =1 Cars Driven =185
3 MPS MKII T/D = 6
RX-8 R3 T/D = 5 + 7 session's
GT86 T/D = 60.5 + 31 session's
Total T/Days Jan 2011 = 71.5 + 38 session's
Re: Good riddance
Post by Yorindesarin » Sat Mar 28, 2020 12:18 am
Considered ethanol on higher boost? Or higher % ethanol fuels possibly not always E85 if you get my drift?
Return to “The Other Car..”
