new disks and pads
AndyBrad
Been thanked: 17 times
new disks and pads
Post by AndyBrad » Tue Feb 18, 2020 1:25 pm
So im currently running red stuff all round which i like but im going to grab a new set of discs for when the weather turns better. Nothing wrong with the old ones but they are tatty.
Ive seen the black ones on ebay at a very reasonable price. Are they any good or am i better painting standard discs?
Ainmhidh
Has thanked: 375 times
Been thanked: 321 times
Re: new disks and pads
Post by Ainmhidh » Tue Feb 18, 2020 2:58 pm
What do you mean black ones?
Given most of the surface of the disc is contact area for the pads any paint there will initially contaminate your pads and possibly trash brake performance, before burning off and leaving bare metal again.
I got Black diamond discs a couple of years back and they were a lovely dark colour, right up until I cleaned them with brake cleaner at installation and they became a fairly standard sort of metal colour. Are they worth the money? Dunno, but worth the deal I got from someone clearing out at the time.
V8 Power
Has thanked: 124 times
Been thanked: 287 times
Post by V8 Power » Tue Feb 18, 2020 3:08 pm
Black Diamond disks have a protective black coating that wears off with initial braking (or as per Alan).
I have Black Diamond on my track car and have used them on other cars without issues. Stay clear of drilled ones though!
Carbon seats
Sabelt 6 point harnesses
Direct cold air feed
Tein Monosport coilovers
Carbon Adjustable wing
Feed gearknob
Axial short shift
Autec lightweight alloys
Whiteline ARB's
Stripped interior
RRP Coils MSD leads
Yorindesarin
Has thanked: 21 times
Been thanked: 203 times
Post by Yorindesarin » Tue Feb 18, 2020 3:11 pm
I've seen MTEC on ebay that offer corrosion proofing/uv protective coatings on their discs. Im probably going to get them when I put the car back on the road as the price isn't quite Black diamond level. Im sure I read a couple of people have used them before.
Ainmhidh
Post by Ainmhidh » Tue Feb 18, 2020 3:16 pm
Do check you're getting the right size for front and rear (top of head 323mm and 303mm ??)
Reason: corrected front disc size
New Duke
Has thanked: 627 times
Been thanked: 519 times
Post by New Duke » Tue Feb 18, 2020 3:36 pm
I had those for a couple of years and they were absolutely fine, and looked cool. For the money were a bargain despite the scare stories and general snobbery regarding brake brands. £200 delivered including pads.
They will wear pads faster that smooth discs. Any drilled/grooved discs will though, particularly on track. Think cheese grater. No drama if you use cheap pads but I wouldn't combine them with fancy pads.
Yorindesarin
Post by Yorindesarin » Tue Feb 18, 2020 3:48 pm
Do check you're getting the right size for front and rear (top of head 343mm and 303mm ??)
323mm fronts Alan. :lol:
Ranjan once told me not to worry so much about what discs I have on. But rather get decent enough ones and top quality pads.
These users thanked the author Yorindesarin for the post:
Ainmhidh (Tue Feb 18, 2020 3:51 pm)
Techathy
Has thanked: 11 times
Been thanked: 19 times
Post by Techathy » Tue Feb 18, 2020 6:19 pm
^^ This. Also, remember that any groves, dimples or holes in the swept area of the disc the maximal braking power you have available. But they do help break up any water film in wet conditions so I do like a sparse J-Hook or grooved pattern for daily driving.
Conan
Has thanked: 56 times
Been thanked: 699 times
Post by Conan » Tue Feb 18, 2020 7:39 pm
The standard discs are very good so cleaning and using a proper coating is fine.
Grooves I believe are primarily for gas dispersal which can cause a friction problem.
Unless your going on track you don’t need to consider things like that unless you like the ascetics.
Always use good pads for the purpose , ie : don’t use race pads for the road as you will compromise your braking.
Yorindesarin
Post by Yorindesarin » Tue Feb 18, 2020 8:11 pm
I should really go and find the pricing on standard discs to compare to MTEC ones.
Has thanked: 386 times
Been thanked: 1483 times
Post by warpc0il » Tue Feb 18, 2020 8:23 pm
Pagid has long been my brake disc brand of choice for road cars
PaulAV
Has thanked: 54 times
Been thanked: 182 times
Post by PaulAV » Tue Feb 18, 2020 8:40 pm
Last year I fitted a full set of ebc slotted discs and red stuff pads, used the club discount think they were about £350 all in (even got a top up bottle of brake fluid) no issues (they come with a black anti corrosion treatment, this obviously wears of the fiction surface) stopping is good straight out the box
Yorindesarin
Post by Yorindesarin » Tue Feb 18, 2020 8:42 pm
So about 50 quid or so cheaper for Pagid discs than MTEC without protection on em.
Post by warpc0il » Tue Feb 18, 2020 9:17 pm
Yorindesarin
Post by Yorindesarin » Tue Feb 18, 2020 9:23 pm
Thats what I was thinking Dave. Considering just getting some decent enough road brakes on the car to pass the MOT along with a cat so I can take it south with me.
Post by warpc0il » Tue Feb 18, 2020 9:25 pm
Mask off the swept area, or at least most of it, before painting.
Yorindesarin
Post by Yorindesarin » Tue Feb 18, 2020 9:28 pm
Yeah. Only really want to hit the edges of the disc and the centre. Don't want brake pads contiminated.
Phil Bate
Has thanked: 35 times
Been thanked: 167 times
Post by Phil Bate » Tue Feb 18, 2020 11:13 pm
The Pagid discs are my choice also, and a full set comes to around 180 from ECP. They come with a silver zinc coating already but I always dust them with HT black paint for aesthetics. I don't mask them, I just do a few rotations aiming at the outer edge and the edge of the bell/hat. The overspray on the friction surface is negligible and causes no problems -
Always follow the bedding in procedure and never sit with your foot on the brakes after a hard stop, and they will be vibration free for life :thumleft:
*provided you don't a stuck piston or slide pin that is
Post by warpc0il » Tue Feb 18, 2020 11:32 pm
One additional advantage of Pagid products (apart from being the OEM supplier to many manufacturers, including Aston Martin) is that they aren't as popular with the fakers; unlike EBC, Brembo, Hawk, Ferodo, and any OEM branded boxed components.
However, https://pagid.com/2016/03/30/beware-of-the-fakes/
New Duke
Post by New Duke » Tue Feb 18, 2020 11:40 pm
I'm currently using the same discs as Phil. Just unpainted and naked :unibrow: . Paint won't 100% prevent the discs rust bonding to the hub (will help tho) and conversely rust bonded brake discs and hubs take all of 10 seconds to separate. Looks cool though as Phil showed. I do miss having black discs even if only for the appearance.
Bigblueknight3k
Has thanked: 116 times
Been thanked: 53 times
Post by Bigblueknight3k » Wed Feb 19, 2020 6:56 am
Am trying these this year as burnt out yellow stuff on track plus need new discs Image
AndyBrad
Post by AndyBrad » Wed Feb 19, 2020 9:34 am
so its looking like the black mtec ones are the ones to go for.
im buying purely for them not going rusty btw. nothing wrong with the old ones just a bit rusty.
Post by warpc0il » Wed Feb 19, 2020 9:44 am
The black mtec isn't proper paint and new ones will be rusty within a few days/weeks/months anyway depending where you drive.
If it's just about cosmetics, then paint your existing discs, in situ.
AndyBrad
Post by AndyBrad » Wed Feb 19, 2020 2:06 pm
oh i thought it was
Ryan Rotary Performance
Sponsor Trader
Sponsor Trader
RX-8: Supercharged
Has thanked: 172 times
Been thanked: 577 times
Post by Ryan Rotary Performance » Wed Feb 19, 2020 3:31 pm
For anyone looking at something perhaps more exotic and also looking to reduce unsprung weight, it wont be long until our floating Front & Rear kits are available :)
Return to “RX-8 Discussion”
