New Cooling Upgrades - Series 1 only
- Ryan Rotary Performance
- Sponsor Trader
- RX-8: Supercharged
- Has thanked: 192 times
- Been thanked: 688 times
Website Links and blurb:
https://www.ryanrotaryperformance.com/s ... ng-upgrade - £180 kit
https://www.ryanrotaryperformance.com/s ... ng-upgrade - £300 Kit
https://www.ryanrotaryperformance.com/s ... ng-upgrade - £330 Kit
Rx8 Series 1 (2003-2008) – Ultimate Cooling upgrade
We have modified the Series 2 Water Pump which has a much improved Impeller design to fit the Series 1 Rx8. Say goodbye to the inefficient impeller design of the Series 1 Water Pump which has not been updated since the Rx7, and say hello to the new Water Pump Cooling Upgrade.
Benefits:
Reduced Engine Temperatures for Fast Road or Track use
More efficient impeller, reduces cavitation, increases cooling over a wider Rpm range.
Custom pulley which now under drives the Water-Pump without under driving the rest of the ancillaries.
More Power to the wheels, reducing pumping losses.
Availalbe in 3 sets:
Modified Water Pump, Gasket and Custom Plain Pulley – £180
Modified Water Pump, paired with Racing pulley kit. – £300
Modified Water Pump, paired with 4 piece Pulley kit. – £330
Benefits:
Last edited by Ryan Rotary Performance on Fri Oct 25, 2019 2:03 pm, edited 1 time in total.
- These users thanked the author Ryan Rotary Performance for the post (total 2):
- PeteH (Wed Oct 23, 2019 2:20 pm) • leeroy69 (Wed Oct 23, 2019 8:29 pm)
Carl
Carl
- Sponsor Trader
Re: New Cooling Upgrades - Series 1 only
different bolt pattern
Carl
Carl
- Scartlead
- Has thanked: 85 times
- Been thanked: 108 times
Hey Carl, is the pump compatible with the pulley set I bought from you? ie can I buy the pump on its own without the pulley if it is ?
- Sponsor Trader
You'll need the S2 pulley and waterpump for this mod.
Carl
Carl
- Velocity_Dan93
- Has thanked: 33 times
- Been thanked: 78 times
Do you have any temperature readings for comparison with or without this kit on cars stock of modified? Just interested to see the difference
Phantom Evolve Mazdaspeed
Brilliant Black PZ
Crystal White R3
lightning yellow racecar
Plus a load of other scrap
Brilliant Black PZ
Crystal White R3
- Scartlead
Thanks, does the belt need replaced?Ryan Rotary Performance wrote: ↑Mon Mar 23, 2020 7:04 pmYou'll need the S2 pulley and waterpump for this mod.
- Sponsor Trader
Yes you can use the same belts.Scartlead wrote: ↑Tue Mar 24, 2020 6:20 pmThanks, does the belt need replaced?Ryan Rotary Performance wrote: ↑Mon Mar 23, 2020 7:04 pmYou'll need the S2 pulley and waterpump for this mod.
Carl
Carl
- Sponsor Trader
Hi DanVelocity_Dan93 wrote: ↑Tue Mar 24, 2020 1:14 amDo you have any temperature readings for comparison with or without this kit on cars stock of modified? Just interested to see the difference
When Ed Stracey did some testing for me ( I gave him one FOC) he noticed a significant improvement in his temps, cruising it was floating at the thermostat around 82-85 and at WOT he noticed that temps being more stable and less prone to spiking and then returning to normal faster so all in all a great improvement!
From memory you bought his car and so should have one?
- These users thanked the author Ryan Rotary Performance for the post:
- Velocity_Dan93 (Fri Mar 27, 2020 7:22 pm)
Carl
Carl
- Velocity_Dan93
I do indeed but don't have any temp logging on itRyan Rotary Performance wrote: ↑Fri Mar 27, 2020 6:48 pmHi DanVelocity_Dan93 wrote: ↑Tue Mar 24, 2020 1:14 amDo you have any temperature readings for comparison with or without this kit on cars stock of modified? Just interested to see the difference
Brilliant Black PZ
Crystal White R3
Brilliant Black PZ
Crystal White R3
- bc-49
- Has thanked: 92 times
- Been thanked: 81 times
Potentially in the market for one of these.
Carl, have you got a price for fitting on the £180 kit?
Cheers!
Cheers!
2006 Galaxy Grey 231
Yokohama V105 | Eibach Pro-Kit Springs | Eibach 20mm Spacers | Mintex 1144 Pads | Racing Beat REV8 Catback | BHR Ignition | K&N Filter | Koyorad Alu Radiator | Mishimoto Thermostat | Greddy Sump | ER Braided Oil Lines | ER Oil Pressure Reg | ER Baffle Plate | Lockwood Front Grills
- Sponsor Trader
Out of stock I'm afraid at the moment.
Carl
Carl
- SprintRX8
- Has thanked: 6 times
- Been thanked: 44 times
Carl.
When are you expecting new stock?.
13BLT Renesis Rotary powered Dolomite Sprint in the making
Balanced Lightened and Tweaked.and going Supercharged.
- M12
Any deals for Black Friday?
Winning Blue 231
Jap Speed Exhaust
Custom Oil Catch Can
Ryan Rotary Performance MK2 Ignition Coils
Hard Race Uprated Engine Mounts
Pro Sport Gauges
Battery Relocated to boot
And too many smiles
per gallon
Jap Speed Exhaust
Pro Sport Gauges
And too many smiles
- SprintRX8
- Sponsor Trader
Sorry guys, the only things we have on sale are on the sale page within the website
Carl
Carl
