Car Ramps and other Access Options
Harrymonk
Has thanked: 14 times
Post by Harrymonk »
Been looking at ways to provide improved access for a while now. I have seen these two Items come up a lot, the first seems like a sturdy option for under-work (exhaust removal maybe even my clutch). The second seems a little more questionable. Just wondered if people have had experience with either as these days online reviews seem to mean very little.
https://www.ebay.co.uk/i/332869495992?r ... 2869495992
https://www.ebay.co.uk/itm/MOBILE-SCISS ... SwcUBYLvBi
Has thanked: 6265 times
Been thanked: 3073 times
Re: Car Ramps and other Access Options
Post by ChrisHolmes »
There is a guy near me in Cheltenham selling some sets of car sales display ramps for £200. The long ones that you drive up and say a prayer whilst they rock into the horizontal position.
AB Bucket seats & 5 point harnesses
Rebuilt 6 port
Pettit SC
Racing Beat alloy flywheel, oil lines & ARBs , REV 8 Full SS Exh
Stg1 Exedy Clutch
AEM Smart Coils & MSD leads
Remote oil filter
Tein MonoSports & EDFC
Fully polybushed
Racing Brake 4 Pot Calipers
MazdaSpeed skirts & Rear Spoiler
Lockwood SS Grills
Harrymonk
Post by Harrymonk »
ChrisHolmes wrote:
Wed Mar 06, 2019 3:32 pm
As much as they sound perfect, thats a bit of a drive and without something to shift them in #-o Assume they would be okay for servicing if you can lock them have seen DIY sets which lock but don't have a welder :-k
Bullet5
RX-8: Nemesis
Has thanked: 40 times
Been thanked: 20 times
Post by Bullet5 »
I've got a black set of the ramp/lift combination ones, although I'm sure I paid much closer to £100 for them. They are sturdy, but are rather poorly put together (no set squares were used during the construction), however for the purpose they serve they are great. You can only reverse up these, as the front of an 8 is far too low to drive up them without either extensions or something under the wheels to lift the nose up a fair bit. Once you've the rear up on them you can lift it up very high as per the below, perfect for accessing the exhaust from the manifold back and especially brilliant for protecting the underside. :thumright:
If you'd prefer a trolley jack and axle stands I can also confirm that the Halfords Advanced 3 Tonne jack manages to reach the diff easily on the flat. I've not tried accessing the front jacking point yet as to be honest I very rarely need to get under the front.
All the best,
Bullet5. :)
P.S. If the images don't load for you use this link: https://photos.app.goo.gl/4t3jcW323EAu38nSA
These users thanked the author Bullet5 for the post:
ChrisHolmes (Wed Mar 06, 2019 8:43 pm)
Dan-Lincs
Been thanked: 11 times
Post by Dan-Lincs »
Whats the brand of these / where did you get them?
Bullet5
RX-8: Nemesis
Post by Bullet5 »
I bought them from eBay a few years back. They were branded "Tech7". Do a search for "Tech7 Vehicle Car Ramp Lift 2 Ton Hydraulic" you'll likely find them. One other thing I should note is that you wouldn't want to go much more than a 235 or 245 profile tyre from memory. I have 225's fitted in the photos, but anything much wider would cause the side walls to begin binding on the angled sides of the plates if not aligned properly.
Cheers,
Bullet5.
Edit: Infact, dig around a little on eBay. I've just come across a new pair that look identical for circa £90. :thumright:
Dan-Lincs (Wed Mar 06, 2019 10:39 pm)
Secla
RX-8: Nemesis
Colour: Stormy Blue
Post by Secla »
how much higher does the hydraulic jack actually get the car? doesnt look like much in the pictures
Has thanked: 575 times
Been thanked: 2438 times
It looks like you couldn't lift the rear wheels that much higher, without the nose of the car hitting the ground, unless you also put something under the front wheels
Has thanked: 370 times
Been thanked: 894 times
Post by Dr. FrankenRex »
I've got a hefty hydraulic race jack that cost me ~£130 from Screwfix which lifts the car mentally high. Only problem is it doesn't fit under my lowered R3 :lol:
I generally use a combination of ramps and jack. Reverse it up a pair of ramps and then jack the front up with the trolley jack. Once jacked up put a single axle stand under the front central jacking point on the crossmember and lower it down. It'll level itself out and sits nice and high
Doc - Club Information Coordinator - Media Team
FrankenRex2 - RR Full Bridge with Race Extension porting, shiny big brakes and lots more besides :D
Eddie_r32
Has thanked: 37 times
Been thanked: 135 times
Post by Eddie_r32 »
I keep looking at these:
https://rover.ebay.com/rover/0/0/0?mpre ... 3390172815
Not sure I'm quite that lazy yet to spend 400 quid on them but I do get tempted now and then. I could save another grand or so and just buy a quikjack from bendpack
2007 Galaxy grey 231.
bigpete8
Has thanked: 190 times
Been thanked: 192 times
Post by bigpete8 »
Harrymonk wrote:
Wed Mar 06, 2019 3:27 pm
WRT scissor lift I looked at them but discounted due to:
viewtopic.php?f=6&t=75573&hilit=scissor#p1120932
In the end bought a halfords advanced low profile jack.
Running on a budget to keep the noise level down - from the missus!
Harrymonk
Post by Harrymonk »
Bullet5 wrote:
Wed Mar 06, 2019 6:59 pm
All the best,
Bullet5. :)
Thanks all for comments, for the time being have opted for a set of these, hoping with the extra lift and swapping front to back I can carry out the clutch replacement and get her back on the road. Definate requirement of by next house to have garage big enough to put 2 post ramp/lift in lol. Sure it will be the same as people who buy pick ups and everyone will want to pop over to use it...
Harrymonk
Post by Harrymonk »
Well after struggling a bit as I’m not the smallest chap I bought a second set, this is the most cost effective and convenient way to get the beast nearly 2ft clear of the deck. Made the job much easier.
Harrymonk
Post by Harrymonk »
A photo to show access, made it so much easier as could drop gearbox and slide her out with ease..The platforms even had an extra pin hole to go so could have gained an extra 2". Even the 255s fitted on with no issue.
ImageIMG-20190408-WA0001 by Martin Harris, on Flickr
These users thanked the author Harrymonk for the post:
Dan-Lincs (Mon Apr 08, 2019 9:50 am)
Has thanked: 172 times
Been thanked: 781 times
Post by PeteH »
What was the process to get the car on the ramps? The front ramps obviously don't fit under the cills of the car. So I assume you reversed up the rear ramps, then jacked the front of the car up and slid the front ramps under. Then jacked all four platforms up. ?? Did you jack the front of the car up on the central jacking point? If so, I guess you had to slide the jack in from behind the front wheel (since I imagine there is no way it would go under the front of the car at the angle the car was sitting.
Phil Bate
Has thanked: 41 times
Been thanked: 183 times
Post by Phil Bate »
I've got a black set of the ramp/lift combination ones...
I'm going to lose sleep over those loosely arranged tiles. How could you leave them like that and not click them together?! :lol:
boosted
Has thanked: 94 times
Been thanked: 449 times
Post by boosted »
Ive got those lifting ramps...been great but i had to make a set of additional assister ramps as anything low will not go up...i made mine outta decking board....and quite easy to forget to let the bottle jack down...i drove straight off them in my scooby and then had to remove bumper as car was beached...
There good for gearboxes servicing exhaust as gets the car quite high...
These users thanked the author boosted for the post:
ChrisHolmes (Tue Apr 09, 2019 9:30 am)
Mondeodog towcar.
Keke
Has thanked: 12 times
Been thanked: 53 times
Post by Keke »
PeteH wrote:What was the process to get the car on the ramps? The front ramps obviously don't fit under the cills of the car. So I assume you reversed up the rear ramps, then jacked the front of the car up and slid the front ramps under. Then jacked all four platforms up. ?? Did you jack the front of the car up on the central jacking point? If so, I guess you had to slide the jack in from behind the front wheel (since I imagine there is no way it would go under the front of the car at the angle the car was sitting.
I an wondering the same thing,
I recently purchased a pair due to this post,
Sent from my E5823 using Tapatalk
Bullet5
RX-8: Nemesis
Post by Bullet5 »
Phil Bate wrote:
Mon Apr 08, 2019 1:39 pm
I've already lost enough sleep over them. Two sets bought at different times years ago for the caravan, and typically they have different locking patterns. ](*,)
I normally throw those down and then put a sheet of cardboard on top so I can still slide around easily, still benefiting from the comfort of the pads underneath. The only downside of these really is the fact that you can't drive up forwards without a ramp extension, then again not many ramps fit under the front of an 8 without them.
Offcuts of vinyl cushion floor are great for working under the car.
They're tough enough that the (smaller) stones don't puncture from underneath, while being softer and warmer than concrete.
Avoid anti-slip finishes as you want them slippery, and a quick spray with furniture polish helps too, to manoeuvre around underneath.
If you really get stuck, or get cramp, then someone can at least drag you out by your feet.
They don't take too kindly to brake fluid or solvent spills, but usually fine if you wipe away and don't let pool.
The uniform surface also makes it easier to find things, nuts, bolts, screws, sockets, etc that you've dropped.
Harrymonk
Post by Harrymonk »
PeteH wrote:
Mon Apr 08, 2019 1:28 pm
Pretty much as above, actually pushed her up onto the rear ramps as couldn't drive her, Then actually as I had access to 2 jacks jacked the front up level onto axle stands until I could get a jack with block under the central jack point then up she went onto front ramps, hence they are the wrong way round but that was to provide better access to gearbox. Then jacked up the platforms one slot at a time. Sound like a bind but only took a few minutes. To get her down was pretty much reverse of that.
As said the ramps were £90 a pair, so for £180 I can get 2ft of level clearance, I struggled to find anything else near that price and that can just sit at the back of the garage piled up.
Bullet5 wrote:
Mon Apr 08, 2019 11:48 pm
A small block of wood did the same job as the ramp extensions, of lifting it high enough to get her on forwards.
Harrymonk
Post by Harrymonk »
warpc0il wrote:
Tue Apr 09, 2019 12:01 am
Something like this would be my next investment as all I had was the 4 boxes the ramps came in so used the old cardboard workshop service tray :roll: lol
Return to “RX-8 Discussion”
