It seemed like a good idea at the time...
Lemon
Has thanked: 29 times
Been thanked: 163 times
Re: It seemed like a good idea at the time...
Post by Lemon » Sun Oct 27, 2019 9:35 pm
Ouch, bad luck mate
Sent from my Nokia 6.1 using Tapatalk
Thanks, Stu
Has thanked: 228 times
Been thanked: 462 times
Post by Honkytonk » Sun Oct 27, 2019 9:37 pm
Oh shoot, what a nightmare! Warranty comes in at this point, and I'm sure RRP will see you right.
The P-Shed Project Thread
Has thanked: 153 times
Been thanked: 536 times
Post by qwakers » Sun Oct 27, 2019 9:54 pm
im sure they will, its why i chose them, i know they'll do the job right, but if something does go wrong, their warranty reputation is one of the best in the business.
ChrisHolmes (Sun Oct 27, 2019 9:55 pm)
Has thanked: 21 times
Been thanked: 203 times
Post by Yorindesarin » Sun Oct 27, 2019 10:27 pm
Ooft oh no! :( Hope it is just a seal failure! Im sure RRP will have it all sorted!
Post by qwakers » Sun Oct 27, 2019 11:47 pm
AAAAND i was just proven right.
11pm at night i get a text then a phone call from scott. the only place i've mentioned it is on here so it seems he reads this thread :D
after a 40 minute chat about what could have gone wrong (his words, that's a weird one) hes told me if i get the engine to him this week ill have it back approx a week later, and no matter what, he'll fix it no worries.
he says its his first engine thats failed so it needs stripping, the only other failures have been front and rear oil seals. that's a impressive record, and as i said to scott, it would be me :D
so i need that engine out of my car asap... i hate doing jobs twice, and now, this is 3 times in 18 months! :shock:
oh and to add to it, i had one of my striplights short out, a shower of sparks from the light and darkness ensued. so i cant even use my workshop now! at least, until daylight so i can look at what went wrong.
however, i see a opportunity to get scott to lob on one or two of their new products, my bank manager is tossing in his bed as we speak!
These users thanked the author qwakers for the post (total 6):
ChrisHolmes (Mon Oct 28, 2019 12:02 am) • GreySilver Beast (Mon Oct 28, 2019 12:20 am) • Honkytonk (Mon Oct 28, 2019 7:03 am) • bigpete8 (Mon Oct 28, 2019 8:03 am) • Paul_13 (Mon Oct 28, 2019 8:07 am) • v-rex (Mon Oct 28, 2019 6:26 pm)
casey
Has thanked: 971 times
Been thanked: 1157 times
Post by casey » Mon Oct 28, 2019 10:31 am
Sorry to hear of your engine woes :( but pleased to see RRP have reacted quickly to get it sorted :thumleft:
These users thanked the author casey for the post:
nightfire10 (Mon Oct 28, 2019 4:57 pm)
Club Secretary
Seibon Carbon Fibre Bonnet
Post by Yorindesarin » Mon Oct 28, 2019 5:55 pm
James' wallet lightens significantly...
qwakers (Mon Oct 28, 2019 6:02 pm)
Ainmhidh
Has thanked: 375 times
Been thanked: 321 times
Post by Ainmhidh » Tue Oct 29, 2019 9:08 am
James' bank manager clearly very excited at the prospect of lending James more money?! :getmecoat:
Post by qwakers » Tue Oct 29, 2019 9:10 am
weeelll.... no not so much. i got a stern talking to about ‘that bloody car’ not long ago! :D
Post by qwakers » Fri Nov 01, 2019 6:16 pm
just to update this, rear rotor had water in it when turned over with plugs out, a little water in front rotor too but i suspect that's mostly fuel.
compression rear
front
Post by qwakers » Fri Nov 01, 2019 7:32 pm
:sigh:
here we go again...
:mrgreen:
Lemon
Post by Lemon » Fri Nov 01, 2019 7:37 pm
qwakers wrote:just to update this, rear rotor had water in it when turned over with plugs out, a little water in front rotor two but i suspect that's mostly fuel.
compression rear
front
How do you manage this?
Best of luck with getting it pulled out though mate.
These users thanked the author Lemon for the post:
nightfire10 (Fri Nov 01, 2019 8:42 pm)
Thanks, Stu
Has thanked: 4645 times
Been thanked: 1955 times
Post by ChrisHolmes » Fri Nov 01, 2019 7:49 pm
compression rear
front
Nice compression tester, I hope the sensor is waterproof!
Bridge Ported 231
MazdaSpeed sills
Short shifter
Post by qwakers » Fri Nov 01, 2019 7:52 pm
i made sure there was no water left in it before using it, i promise :D the sensor was dry after.
its on its way back to you now, should have it monday :D
thanks for the lend chris. its much appreciated.
Post by ChrisHolmes » Fri Nov 01, 2019 8:08 pm
No problems James, fortunate you had it for your own use. Water in both chambers is ominous.
qwakers (Fri Nov 01, 2019 8:10 pm)
Bridge Ported 231
MazdaSpeed sills
Short shifter
Post by qwakers » Sat Nov 02, 2019 9:43 pm
1h 50min over 2 evenings, from jack up to engine on floor
im getting disturbingly good at this......
Post by qwakers » Sun Nov 03, 2019 10:25 pm
got back from scotts place after a leisurely drive home (read stick the cruise on at 90 and still get 55mpg!)
hes going to strip it tomorrow but he's betting on apex seals stuck because its spent the last week sitting with water in the chambers and a hole in the water jacket in the rear housing.
anyone else wanna place bets :D
Post by Honkytonk » Sun Nov 03, 2019 10:26 pm
Tooth from some awful dental appointment rattling about
These users thanked the author Honkytonk for the post (total 3):
Vj4sothername (Sun Nov 03, 2019 10:29 pm) • qwakers (Sun Nov 03, 2019 10:32 pm) • v-rex (Mon Nov 04, 2019 6:26 am)
Post by qwakers » Sun Nov 10, 2019 6:40 pm
so for those that are not already aware my engine is toast. no serviceable parts at all.
so i went a huntin' for a replacement. id love to have another rebuild, and have no reservations getting another RRP bridge, but budget does not allow, unfortunately.
luckily i was able to pick up a haywards stage 2 engine and lightened flywheel today, (kiwigaz's old motor)so im back in the game.
unfortunately the engine is not as complete as i was hoping, as the person who removed the engine decided that instead of unplugging the loom (which would have been quicker!) They would take the time to carefully cut the looms instead.
they also cut one of the fuel pipes.
so that will be a call to scott tomorrow to chuck some money his way to get that lot sent down to me, as i said he could keep whats left of the engine.
still, its got a few additions that i don't need so i will be listing a few bits on here for sale in the next couple of weeks, which should make the bill a bit less painful.
so
im back.png (219.9 KiB) Viewed 125 times
Vj4sothername (Sun Nov 10, 2019 7:46 pm)
Has thanked: 88 times
Been thanked: 275 times
Post by mi60o0 » Sun Nov 10, 2019 6:50 pm
good news
BatRex 192 stock
Post by ChrisHolmes » Sun Nov 10, 2019 6:53 pm
Well done James, I saw your “scrap” on Friday at Scotts, cracked and blued severely
Bridge Ported 231
MazdaSpeed sills
Short shifter
Post by qwakers » Sun Nov 10, 2019 6:55 pm
aye. i think hes going to mount them for display :D
Honkytonk (Mon Nov 11, 2019 1:50 pm)
boosted
Has thanked: 74 times
Been thanked: 385 times
Post by boosted » Sun Nov 10, 2019 7:10 pm
That makes no sense to cut a loom....the engine been rebuilt prior so the security bolts on the ecu wouldve been drilled out then...
Just lazy that and makes you extra work .
My mate bought a 350z engine and it came like that very time consuming stripping engine off blown engine and swapping...
Anyways good luck. Back in the game soon.
Been thanked: 613 times
Post by goodeggbob » Sun Nov 10, 2019 7:28 pm
Good luck James, look upon the bits needing to be replaced as an opportunity to clean and check everything.
qwakers (Sun Nov 10, 2019 7:28 pm)
Lemon
Post by Lemon » Sun Nov 10, 2019 11:54 pm
Has Scott said what the cause of failure was?
Thanks, Stu
