How to fit a Vent Pod and Oil/Water Sensors
Has thanked: 2672 times
Been thanked: 982 times
Re: How to fit a Vent Pod and Oil/Water Sensors
Post by ChrisHolmes » Sun Aug 05, 2018 6:23 pm
Thanks that's healthy, Mazda state minimum 3 bar at 3000rpm
Toyo SS Catback
SS Strakes
Custom Sat Nav 3 Gauge install
Meister Zeta R Coilovers
Whiteline ARBs F&R
Slotted & Dimpled Discs F&R
Mintex 1144 Pads F&R
Full OE Aero Kit
Revolution Alloy Front Strut Brace
Lockwood SS Grills
Passenger Footrest
Lambo doors
Original engine 86000 smiles (169.7 rwhp) and then it died!
Own build Steet ported engine fitted Feb 2018 and running sweet as nut
Has thanked: 54 times
Been thanked: 54 times
Post by Scartlead » Sun Aug 05, 2018 6:23 pm
Mpv2k3 wrote:
Sun Aug 05, 2018 4:32 pm
Really need to sort some gauges out for the R3. And work out what exactly to buy for set up as the sandwich plate won't fit, so from what I read, it's a banjo bolt jobbie. It's beyond me #-o
Thinking of oil pressure, oil temp and water temp gauges.
Also, how sturdy are the vent 3pod holders? :?:
Pretty sturdy :) A little top heavy with everything fitted, but fine and also havent glued it down, just clicked into place.
Aka Mark 8)
My Build :thumleft: viewtopic.php?f=204&t=70916
Has thanked: 222 times
Been thanked: 768 times
Post by warpc0il » Sun Aug 05, 2018 6:28 pm
That looks like you could benefit from a mousemat ;)
viewtopic.php?f=30&t=53888
Getting the oil at (or ideally above) 100C is key to driving any condensed water out.
It also shows how much cooler it's been in NI vs England over the last few days.
Post by Scartlead » Sun Aug 05, 2018 6:30 pm
Heat wave? what? Not over here lol.
Thanks Dave, food for thought :thumleft:
Aka Mark 8)
Ninja_Freak
Has thanked: 29 times
Been thanked: 22 times
Post by Ninja_Freak » Tue Aug 07, 2018 4:04 pm
Scartlead, where did you get your gauge pod?
NF
56 Plate PZ in Galaxy Grey!!
Post by Scartlead » Tue Aug 07, 2018 4:51 pm
Aka Mark 8)
Has thanked: 5689 times
Been thanked: 1387 times
Post by GreySilver Beast » Tue Aug 07, 2018 10:59 pm
I got my Triple Pod Gauge Holder from that Company too :thumleft:
RX-8OC Club Calendar - GBCC & Network Delivery Service
Track Days = 64.5 + 4 session's/Sprint Days = 13/Car Limits 4 person = 4/Skid Pan = 1/Go Karting = 1/Cars Driven = 181
http://npt-communications.webs.com < Click > ****GSB III**** - GT86 Track Days = 55
Ninja_Freak
Post by Ninja_Freak » Wed Aug 08, 2018 1:40 pm
Curious, did it come with the switch?
Post by GreySilver Beast » Wed Aug 08, 2018 2:23 pm
:lol: :lol: :lol: :lol: The switch is for the HUD :thumleft:
Ninja_Freak
Post by Ninja_Freak » Thu Aug 09, 2018 9:46 pm
Sweet! :)
Mpv2k3
Has thanked: 117 times
Been thanked: 301 times
Post by Mpv2k3 » Tue Aug 14, 2018 10:47 pm
What size gauges are these? 52mm or 60mm
Post by Scartlead » Tue Aug 14, 2018 11:01 pm
52 :thumright:
Aka Mark 8)
Post by GreySilver Beast » Tue Aug 14, 2018 11:54 pm
Block8Head can make 52mm or 60mm Holders for the Vents =D>
I went for 60mm :P
