Has thanked: 833 times
Been thanked: 854 times
Post by Shagrington » Sat Apr 29, 2017 2:28 am
SeeJay wrote:By all means hold fire on them there strakes.. ;)
:-$ [-X
johnbb99 wrote:So is it considered a serious [potential] problem, that the oil coolers and radiators are unprotected, as standard?
There is a (small?) chance of a stone going through one - that would be serious. Eventually the fins on the coolers do become very bent from debris hitting them which, I understand, effects the cooling. The mesh grilles do also have the benefit of keeping out dead leaves and crud though.
johnbb99
Has thanked: 340 times
Been thanked: 46 times
Post by johnbb99 » Sat Apr 29, 2017 10:28 am
OK, thanks for the responses; I'm convinced. :)
gareth_1912
Forum Guest
Forum Guest
Post by gareth_1912 » Sat Apr 29, 2017 12:48 pm
Next job twin springs and roof wrap either gloss black or silver grey camo . Then to the track . Car is on 68000 and had all coil packs before I bought it so fingers crossed it's all ok for a while lol
PaulAV
Has thanked: 105 times
Been thanked: 286 times
Post by PaulAV » Sat Apr 29, 2017 3:29 pm
Imagine a stone about the size of a Brussel sprout flying up at your oil cooler at 50 or 60 mph, you'll go from 60 to 0 in as fast as the rx8 brakes can stop you.
gareth_1912
Forum Guest
Forum Guest
Post by gareth_1912 » Sat Apr 29, 2017 3:44 pm
Thanks for the advice I will look into them asap . Do they just clip or stick in or is the and fabrication to fit
PaulAV
Post by PaulAV » Sat Apr 29, 2017 3:48 pm
Generally I think they have a couple of screws, depends what make I think, but I think you will have to remove the front bumper (which takes about 40 minutes)
Has thanked: 457 times
Been thanked: 1841 times
Post by warpc0il » Sat Apr 29, 2017 5:19 pm
I've found that plastic gutter shield works well enough, is dirt cheap, easy to fit and looks good.
See this thread
http://www.rx8ownersclub.co.uk/forum/vi ... er#p764569
johnbb99 (Sat Apr 29, 2017 9:32 pm)
joney
Has thanked: 23 times
Been thanked: 54 times
Post by joney » Sat Apr 29, 2017 6:29 pm
That reminds me ive got a set of the rb oil cooler grills ive been meaning to fit for a year now :roll:
If its not broke I'm sure I can find a reason to take it apart :thumright:
To Do: ?
Want:Ms kit
Sean moore
Been thanked: 22 times
Post by Sean moore » Sat Apr 29, 2017 7:29 pm
Finally fitted my exhaust shrouds to my pz thanks bigpete
Sent from my iPad using Tapatalk
johnbb99
Post by johnbb99 » Sat Apr 29, 2017 9:35 pm
Thanks Dave; I was reluctant to spend nearly 10% of the car's purchase price on grilles... :)
Has thanked: 5309 times
Been thanked: 2430 times
Post by ChrisHolmes » Mon May 01, 2017 8:31 pm
Finished fitting the Lambo hinges.
Well not quite just today as this job actually started on the 18th with a visit to Jays (Frankies Speed Shop) with the intention of getting the whole job sorted there. As often happens with best laid plans time eventually beat us as we encountered some alignment and wiring stretching issues of which I won't bore you with the details we finally just wired the motor direct and put the window up and left it unplugged and I set off home.
Down the motorway slip road changed up into third and heard the most horrible scraping sound, lifted off, noise stopped, accelerated and at 65mph back it came so cruised to the services at 55mph. Muppet me had not screwed on the front edge of the wheel arch liner which is now somewhat shorter, only one thing to do with no tools to hand so and so I brutally just ripped it off!
Anybody got a N/S arch liner they don't want?
Arch liners, spot the difference
Fast forward to this weekend and off came the bumper, headlights and wings. Out came the existing wiring bulkhead plugs, 19 snips on each one and they went in the scrap bin to be replaced by ones from BigPete that effectively lengthened the wiring.
When installed originally the protecting boot points downward but with the lift of the Lambo doors they need to point upward. Simple solution is to rotate the boot 180' and then bend the wiring through 180' to lead down to the cables coming out the door.
38 heat shrink wrapped soldered joints later the job was done!
Drivers side ready to have the longer wiring attached
Passenger side finished wiring
The open protective sleeve was the sealed with clear silicone. The gas shock was also reversed so that the shaft points downward which apparently is how gas shocks are supposed to be installed.
These users thanked the author ChrisHolmes for the post (total 3):
Wozza (Mon May 01, 2017 8:36 pm) • nightfire10 (Mon May 01, 2017 9:34 pm) • Nintendologist (Sat May 06, 2017 8:24 am)
Bridge Ported 231
MazdaSpeed skirts
Short shifter
wgimenes
Has thanked: 118 times
Been thanked: 82 times
Post by wgimenes » Mon May 01, 2017 9:22 pm
Looking good there, sir.
I finally wired my bluetooth interface directly to the 12V/5V inverter so that I leave my cigarette lighter socket free for 2 phone chargers.
Also fixed the led lights on the lit gear knob, much to my wife's delight. I'm not fussed about it, but she seems to find that more important than new brakes on the car :-)
brix79
Has thanked: 109 times
Been thanked: 368 times
Post by brix79 » Mon May 01, 2017 9:35 pm
That's a bit bling Chris.. ;) Looking good though. 8)
johnbb99 wrote:Thanks Dave; I was reluctant to spend nearly 10% of the car's purchase price on grilles... :)
Those were my thoughts John, so I bought some mesh from the bay and did my own. Basically the same way Dave did.
Followed the DIY here: http://www.rx8ownersclub.co.uk/forum/vi ... 30&t=50811 :thumright:
These users thanked the author brix79 for the post (total 2):
johnbb99 (Mon May 01, 2017 11:07 pm) • ChrisHolmes (Tue May 02, 2017 9:23 pm)
Chairman & Forum Admin Team
2017 // 2010 Aurora Blue R3
binghamf6
Been thanked: 25 times
Post by binghamf6 » Mon May 01, 2017 10:06 pm
Welcome to the Lambo door club Chris looking good.
These users thanked the author binghamf6 for the post:
Shane..
HID's + LED'S , Custom Gauge Pod , Piano Black Center Console , Later Interior , Bonnet Struts , Catch Tank
Poly Bushed Front End , Meister R Zeta S coil overs , Braided brake lines , Sohn And 2T Tank
RE-Amemiya short shifter, Show 'N' Go Front No. Plate , R3 Style starter motor.
Racing Beat Silenced de-cat and Rev 8 Cat back , Lambo Doors
Rebuilt and Ported at Hayward rotary
binghamf6
Post by binghamf6 » Mon May 01, 2017 10:18 pm
Well not just today but finished of the boot lid with PZ spoiler and de-badged well only one now
I have fitted the badge now and fitted it to the car will post a picture later.
Shane..
Big-Al
Has thanked: 13 times
Been thanked: 9 times
Post by Big-Al » Mon May 01, 2017 10:25 pm
Covered the front surfaces in dead/dying insects on the way home from the Welsh countryside. Here's a nicer picture before said incident.
These users thanked the author Big-Al for the post:
Nintendologist (Sat May 06, 2017 8:23 am)
Sunlight Silver S1(192)
Black Lockwood grills
Foglight Halo DRLs
LED and custom interior trim(in progress)
BD grooved discs and predator pads
K&N panel filter
RR D585-R ignition
Castrol Power1 racing 2T premix
Dunlop Sportmaxx RT and RT2
Metra kit with aftermarket HU
Work in progress :clint:
SachaP
Post by SachaP » Mon May 01, 2017 10:38 pm
Bling jobs done x 3. Batman decal fixed onto the third brake light, aluminium fuel cap door fitted, and (most satisfyingly) illuminated gear knob fitted.
Sacha
Previously owned - 1979 Lada 1300 :oops: , 1979 Triumph Spitfire, 1979 Mini 1.3, 1981 Golf, 1985 Fiat Panda, 1989 TVR S1, 1991 Alfa 33, 1989 Jaguar XJS, Fiat Coupe x 2, 2005 Galaxy Grey RX8 231.
Currently own - 2006 RX8 PZ, 1971 VW Karmann Ghia, 1980 Triumph TR7 "Premium Edition", 2002 Maserati 3200, 2003 Mercedes ML350.
johnbb99
Post by johnbb99 » Mon May 01, 2017 11:13 pm
Lovely-looking car, great photo!
brix79
Post by brix79 » Mon May 01, 2017 11:14 pm
I do like those Foglight Halo DRL's, Al.. 8)
Post by warpc0il » Mon May 01, 2017 11:23 pm
SachaP wrote:Bling jobs done..(most satisfyingly) illuminated gear knob fitted.
That reminds me, I must check the wiring on mine, as it goes out in 2nd and 4th gears #-o
Sonic KaBoomii
Post by Sonic KaBoomii » Tue May 02, 2017 1:03 am
Didn't make anywhere near the sort of progress I planned to today, but nevermind...
Jacked the front of the car and placed on axle stands ready to fit front suspension...
Removed the wheels
Fitted the bonnet lifters
Removed the old bonnet stay
Removed the airbox not-MAF pipe and tried to fit RR D585s
...3hrs later, still fitting D585s after removing, airbox, alternator lead, checking 'plugs, googling instructions (cos there aren't any) and trying to imagine what the photos would have looked like if they were still on the RR page, dropping a 10mm nut somewhere (and not finding it)
Then I noticed the passenger front arch liner was cut-off at the bottom, so replaced that with a full arch liner to protect/direct airflow through the n/s cooler
Punched a new hole in the arch flap just below where it had split (as they all do)
Gave the suspension up as a bad job and road-tested the new coils to find an - unrelated - airbag fault :roll:
Rick - Follow my trackday misadventures at Sonic KaBoom trackday diaries
casey
Has thanked: 1158 times
Been thanked: 1375 times
Post by casey » Tue May 02, 2017 10:43 am
^^ A fairly average day working on an RX-8 then :lol:
Club Secretary
Seibon Carbon Fibre Bonnet
Has thanked: 526 times
Been thanked: 808 times
Post by 13Black » Tue May 02, 2017 11:11 am
:whathesaid:
Sonic KaBoomii
Post by Sonic KaBoomii » Tue May 02, 2017 3:40 pm
:lol:
Those coils were a bloody nightmare. I need to try and find some pics now I'm sat infront of a proper computer and not trying to do it on my phone; I've got one adapter plug hanging infront of the engine hoist eye, one stuck under it, and the other two jammed in under the elephant trunk
Post by 13Black » Tue May 02, 2017 4:18 pm
The front coil needs the adapter in front of the lifting eye.
Nothing should be trapped though, although they're a little tight in there.
Pics and we will help :D
Return to “RX-8 Discussion”
