DIY - Oil Cooler Grills
- N1xon
We all know that our oil coolers are vulnerable to stone chips and debris. There are aftermarket solutions out there such as the Lockwood Grills, but these come at a price, for what is essentially a cheap piece of mesh. The "Tight Arse" in me got thinking, and I found a simple cost effective, DIY solution to protect your grills for little cash and an hours work.
1] Start out with some Mesh, There are lots of options on size and shape and colours of meshes. I chose a [urlw=http://www.ebay.co.uk/itm/140653665091]"KAMEI" style oblong shaped asymmetric mesh in 12mm x 5mm at 2mm thick; powder coated in black.[/urlw] Don't be put off by them being based in Poland, the quality is great and delivered via UPS in 3 days.
Pay attention to what size openings in the mesh you choose, too small and you will restrict air flow, too large and you will allow debris through to damage the rad.
Each grill will require a 360mm x 180mm rectangle of mesh so ensure you buy a sheet large enough. A 1000mm x 400 sheet will be enough to make these oil cooler grills and the Bumper Grill
2] Remove the Bumper, for a detailed guide try: [urlw=http://www.rx8ownersclub.co.uk/forum/vi ... =30&t=6713]Here for S1[/urlw] or [urlw=http://www.rx8ownersclub.co.uk/forum/vi ... 30&t=27907]Here for R3[/urlw]
3] Expose the oil grill and remove the rubber cover. You can see the damage caused by 7 years of life already. At this stage with a soft brush clear out the fins of debris leaves and dirt, and inspect the condition of the radiator.
4] Start cutting your mesh, take into consideration the angles if you are using asymmetric mesh like the Kamei style.
You will need to cut two rectangles of 360mm wide by 180mm high, but do them one grill at a time.
5] Take your rectangle and place it against the radiator, it will be held in place by the top and bottom supports. The mesh may require a little flexing to fit flat.
6] With one hand hold the mesh flat against the radiator. With the other gently bend the mesh around the curved edge. I would recommend wearing some sort of glove for this , either a gardening glove or a work glove, the small sharp edges of the mesh are less than pleasant.
7] Repeat for the other side ensuring the mesh is tight and secure.
You should now have a radiator grill wrapped in mesh that is secure vertically by the posts and horizontaly by the curves.
8] Refit the rubber, ensuring there is no fouling.
Repeat the same process for the other side, and refit your bumper when ready.
Because the grill is over the radiator and not attached to the bumper it looks very OEM and will still allow you to use [urlw=http://www.rx8ownersclub.co.uk/forum/vi ... 88&start=1]Warpcoil's Mouse Mat trick[/urlw].
There may be a degree of airflow reduction with this method, but there is with any grill, sensible choices of grills should minimise any negative effect.
The beauty of this method is that it is cheap, quick, and relatively easy. Mesh can be had from as little as £7 compared to the £70+ currently charged by Lockwood.
Whilst the Bumper is off why not protect your air conditioning and coolant radiators with my Bumper Grill DIY
- N1xon
Re: DIY Oil Cooler Grills
Note: This is for the S1 RX8, not the R3. I can't imagine the method is any different, but the sizing may be. If you have an R3 and would like to try this and give me the correct sizes I will update the original and give you the credit, because I'm nice like that
Rotary Revs Porting, Rotary Revs Coils, RB Oil Pressure Upgrade, Depo gauges, 10w40, AEM Induction, Tubular Manifold, Walbro 255, De-Cat, KR2T Premix, Bosch S4, N3Z1, Blistein coilovers, Vredestein, Red Stuff Pads, Sparco harness.
- olyoz
Re: DIY - Oil Cooler Grills
A very nice diy! Will give this a go at some point.
Premix and Nitro +
Led interior/side lights, synth gearbox/diff oil, square plate, catch can, powder coated strakes/crest, illuminated gear knob, plastidip badges/indicators, mouse mat mod, Rotary Revs coils, race pipe, custom blueflame backbox pz tips, carbon wrap mirrors, project rx8 engine mounts, ebc ultimax disks, yellow stuff pads, goodridge ss hoses, rb revi duct, spax springs,
- Phil Bate
- Has thanked: 52 times
- Been thanked: 221 times
Excellent job!
- Delanor
- Has thanked: 57 times
- Been thanked: 321 times
Good job - you can straighten some of the damage out of the core using a thin flat blade screwdriver as the fins are only aluminium so its nice and clear before fitting the grills.
- liambeattie1
- muly
Top stuff,great write up I'll definitely be adding this to my "To Do List"
This looks great!
Brilliant idea and a great write up.
How'd you get on with ordering them from poland? Did it take long to arrive?
- N1xon
Thanks for the feedback guys, glad you like it.
The mesh arrived in less than a week , via UPS. great condition and well packaged, would definitely recommend them.
- duckula67
- Has thanked: 9 times
- Been thanked: 10 times
Just did this today as I had the nose off anyway to fit an AEM.
Dead easy to do, great guide cheers.
Mods:Black wheels.Start button.AEM CAI.D585Coils.EBC ultimax discs.Yellowstuff pads.Racing fluid.Stainless brake&clutch lines,Stainless vents.Cobra Catback.Bonnet struts.Auxmod.Custom Gauge pod.Eibachs&Fast road setup.Shortshift.Sohn adapter.Comp clutch&Flywheel.N/plate offset.Red calipers.Leather Gaiter.LEDs in&out.Smoke LED rear lights.LED 3rd brake.
- Superslicks
brilliant guide just done mine this morning, 2 and a half hours later, all done
I also over order'd by 2 sheets 40X100cm, one was more than enough to do both oil coolers and bumber grill, this is were i got it from
http://www.ebay.co.uk/itm/140653665091? ... 1436.l2649
so if anybody would like any, just pm me
Will also like to add get some back to black and a small paint brush and brush back to black over your oil coilers before adding the mesh, looks even better when completed.
Completed: New upgraded coils plugs leads: Engine rebuild: Re-sprayed new spoiler, petrol cap cover, wing mirrors: Dotz hanzo new wheels and tires: sohn adapter added
