Great news. Paul is a diamond.Peterovicz wrote: ↑Sun Jun 19, 2022 2:54 pmThankfully to Paul my rx8 made a sound of life It comes out that I've had a coils to replace, so I also replaced my ignition leads and spark plugs. After about 11 times of deflooding procedure it makes a sweet sound of BRAP
All thanks to Paul and his magic hands hah.
- Has thanked: 60 times
- Been thanked: 37 times
- These users thanked the author RichT_Derby for the post (total 2):
- PaulAV (Sun Jun 19, 2022 5:16 pm) • Peterovicz (Sun Jun 19, 2022 9:19 pm)
2004 Winning Blue, Black Leather, 192
Minimap, K&N Air Filter, RRP Mk3 Coils, Racingbeat Catback, Krown protected
Based in Long Eaton
Based in Long Eaton
- Has thanked: 18 times
- Been thanked: 81 times
Probably go for the last oneChrisHolmes wrote:Brave, very capable or stupid
Sent from my FIG-LX1 using Tapatalk
- These users thanked the author Keke for the post:
- ChrisHolmes (Sun Jun 19, 2022 6:39 pm)
- Has thanked: 87 times
- Been thanked: 177 times
Just had to move Flos 4tf to make space for a transit that was being recovered in
Took half an hour and 1/8 tank of fuel
- These users thanked the author Cscameron for the post:
- New Duke (Tue Jun 21, 2022 12:11 pm)
You can call me Madam Secretary
- Has thanked: 174 times
- Been thanked: 524 times
Just performed an oil change, on my gearbox, the redline that came out looked fairly clean considering its been in around 40,000 miles, a few sparkles a little build up on the magnetic plug but that's it, let's see how the rocket dog racing oil performs, box currently has 105,000 miles on it, redline kept in a clean container just in case.
- ChrisHolmes (Tue Jun 21, 2022 7:03 pm)
Car has been stood for a few days, started easily, idled well and drive without any issues for 10 mile bit of exercise.
Oil temp was c85’ and coolant c98’ in an ambient of 22’ so pretty normal really.
- Has thanked: 569 times
- Been thanked: 526 times
I sneezed again! apparently my sneeze was incidentally made of primer and white paint over multiple days
Getting there though!
- These users thanked the author HarSc for the post (total 3):
- ChrisHolmes (Tue Jun 21, 2022 8:40 pm) • LeeW (Tue Jun 21, 2022 8:52 pm) • warpc0il (Wed Jun 22, 2022 12:32 am)
Vactan arrived, replenishing my supply ran out of kurust yesterday, makes me glad I had already ordered this big tub
Time to get de-rustifying again!
- Has thanked: 694 times
Found a coolant leak coming from the expansion tank breather hose, right down where it attaches to the thermostat housing. For now, until I can get a replacement hose, I've trimmed the hose back past the damaged bit and reattached it.
Only problem is I can't for the life of me get the opened spring clip back over the end of the hose. Can't get it over the bulge at the join. Anyone have any tips for getting it over there? I've tried straightening the hose and even used silicone lubricant to no effect. For now I've moved the spring clip up away from the join.
While the hose feels wedged on I'm nervous to drive it like that. In case I can't get the clip back in the right place is there an alternative fastening someone could recommend?
Also ordered a replacement front lower control arm from Mazda this week, due to a failed bushing. As usual there's no stock in the UK so place your bets when they'll ship it in.
- Been thanked: 2087 times
You need to squeeze the ends of the overlapped clip together, to make it a larger diameter, slide it in place and release.
You can get a special tool to do this, though slip-joint pliers, or even ordinary pliers also work.
- Has thanked: 219 times
- Been thanked: 350 times
I have done this with a cable tie before. squeeze together off the car, cable tie the 2 ends, reassemble joint, slide clip to correct place and cut cable tie whilst holding in place.
- These users thanked the author goodeggbob for the post:
- warpc0il (Thu Jun 23, 2022 7:09 pm)
Rob
- Been thanked: 169 times
Just some build pics from the latest
- These users thanked the author MadTaz for the post (total 6):
- bc-49 (Fri Jun 24, 2022 1:47 pm) • rotatopotato (Fri Jun 24, 2022 1:47 pm) • ChrisHolmes (Fri Jun 24, 2022 3:07 pm) • MARKTHOMASBRAND (Fri Jun 24, 2022 5:20 pm) • hachiroku (Fri Jun 24, 2022 8:44 pm) • New Duke (Fri Jun 24, 2022 10:08 pm)
15th year of ownership and still here
Picked up a new front lower control arm from Mazda to fit. Was a reasonable £250 inc VAT.
Never ceases to surprise me how weird their pricing is. They quoted me £66 + VAT for a new coolant breather hose. That's maybe 50cm of hose. Paying that seems silly so I'll make my own. Can anyone recommend a quality hose supplier?
Pic of the new front right lower arm below in case anyone needs one for an R3 and wants the part number.
- Has thanked: 90 times
At last getting the damages repaired from previous owner dents taken out best as they can little skimming hopefully done before the show day cutting it close
Sent from my M2102J20SG using Tapatalk
- These users thanked the author Bigblueknight3k for the post (total 2):
- GreySilver Beast (Sat Jun 25, 2022 8:08 pm) • ChrisHolmes (Sun Jun 26, 2022 8:01 am)
- Has thanked: 742 times
Gave it a clean ready for combe as we're off to corfu early Monday
Sent from my SM-G991B using TapatalkYou do not have the required permissions to view the files attached to this post.
- These users thanked the author nightfire10 for the post (total 2):
- GreySilver Beast (Sat Jun 25, 2022 8:08 pm) • ChrisHolmes (Sun Jun 26, 2022 8:04 am)
Makes me scared to think what the price would be for all arms front and rear as I might be tempted to do that at some point.... ouch!
- These users thanked the author HarSc for the post:
- ChrisHolmes (Sun Jun 26, 2022 8:04 am)
- Has thanked: 38 times
- Been thanked: 116 times
I have very clean r3 10k bargain for you mr all arms are like new
Can't keep trying to sell me all your cars you just bought the damn thing
Have a look at this(series 1)
- Club Discount Manager
- Has thanked: 66 times
- Been thanked: 70 times
These are the ones to have, especially having to work on an R52 Cooper S Draper 89793 Remote Hose Clip Pliers https://amzn.eu/d/4c7OUjl
RX-8 PZ: viewtopic.php?f=104&t=85661
RX-8 40th: (Charlotte's)
Daily: BMW 330D
RX-8 Evolve (Banger Rally project) gone : viewtopic.php?f=104&t=86460
Old daily (Alfa MiTo - gone too ): viewtopic.php?f=36&t=85722
Daily: BMW 330D
Went for a pub lunch today, on the way back managed to red line in 2nd and 3rd on a nice long straight, my old engine managed 82 by the end of the third gear, today the new engine was at 88 on the cars speedo (which in the real word is 79 and 85) respectively but that's a big difference between the 2 engines and is an increase of 2mph in the last 1000 miles on the new one, I don't take the engine to the beep often prefaring to change at about 8k but the beep is a good benchmark of the available speed.
It could just mean that old engine was showing its age.
I know there could be many variables but is this what others are getting in 3rd at the beep for a 231?
On track 3rd gear beep is around 115mph
If the hose is not moulded with a tight bend anywhere then a straight length of the relevant diameter from a motor factors will be fine.New Duke wrote: ↑Sat Jun 25, 2022 1:51 amPicked up a new front lower control arm from Mazda to fit. Was a reasonable £250 inc VAT.
Wow laws of physics changes on tracknightfire10 wrote: ↑Sun Jun 26, 2022 7:07 amOn track 3rd gear beep is around 115mph
Downhill, with a good wind behind...
Beep is between 90-95mph in third on a 6-speed box with standard diff and tyres. If you're seeing 115mph then you're speedo is very optimistic or you've changed the diff.
Smaller diameter tyres, as sometimes used on track, would lower the gearing but the speedo would over-read by the same amount; so it would still be showing ~95mph on the beep, though you'd actually be going slower.
- ChrisHolmes (Sun Jun 26, 2022 5:52 pm)
