Pod gauges!
- Colour: Metropolitan Grey
- Been thanked: 37 times
Re: Pod gauges!
Ah, I see. Cheers. Any gauge recommendations that are 52mm?
Re: Pod gauges!
Right, after some research, I'm going for the following setup I think!
https://www.ebay.co.uk/itm/383689805357
https://www.ebay.co.uk/itm/193377269118
https://www.ebay.co.uk/itm/193334594154
https://www.ebay.com/itm/164220023518
Before I go ahead, is there anything obvious I'm missing here?
Cheers as always,
Joe
Cheers as always,
Joe
Re: Pod gauges!
Also, he is printing me one that Is deeper so the prosport pods fit in.
- Has thanked: 750 times
- Been thanked: 175 times
Re: Pod gauges!
That sandwich plate looks the same as one I ordered awhile back and was crap. I ordered one a while back to test for my set up and none of the threads weren't cut straight causing the temp sensor to hit the wall of the plate.
Edit, bloody autocorrect were = weren't
Re: Pod gauges!
Right, will look at alternative plates.Vj4sothername wrote:That sandwich plate looks the same as one I ordered awhile back and was crap. I ordered one a while back to test for my set up and none of the threads where cut straight causing the temp sensor to hit the wall of the plate.
- Former Trader
- RX-8: Supercharged
- Has thanked: 46 times
- Been thanked: 153 times
Re: Pod gauges!
I'm not sure how robust that pod will be, to me it looks like its printed on a home 3D printer. What you could do if you do not mind paying a bit more is get the supplier to print via a Selective Laser Sintering (SLS) process which will not only provide a better finished product but also provide something that is more robust.Jeags wrote: ↑Tue Sep 01, 2020 3:21 pmRight, after some research, I'm going for the following setup I think!
Cheers as always,
Joe
We do alot of 3D printing for prototype work and its fantastic for this, just not 100% convinced its up to the final product requirement.
- These users thanked the author Ryan Rotary Performance for the post:
- Jeags (Tue Sep 01, 2020 6:15 pm)
Carl
Carl
Re: Pod gauges!
I mean, for the budget I have, it doesn't really bother me too much. I just need something functional. Will look into the SLS though, cheers
- Has thanked: 12 times
- Been thanked: 104 times
Re: Pod gauges!
That's pretty cool, can easy be smoothed over with a little bit of body filler then a light sand followed by rattle can spray over.
Re: Pod gauges!
Yeah, nice idea! The fella said he uses ASA in his FDM printer, which holds up better with regards to UV and is most cost effective whilst still being quality. I haven't a clue really but willing to take a chance!
Re: Pod gauges!
Right, so pretty much everything has arrived now so will hopefully install this weekend! Just a quick question, the pod gauges has a dim function when you connect the extra wire to a positive wire. I assume I should splice this in with a wire to turn the main beam headlights on, but where would be the best location for this?
Cheers as always,
Joe
Cheers as always,
Joe
- Has thanked: 17 times
- Been thanked: 7 times
Re: Pod gauges!
Wondered if you could show me a link to your ashtray three pod insert, as i cant find it on your site thanks.Ryan Rotary Performance wrote: ↑Tue Sep 01, 2020 6:10 pmI'm not sure how robust that pod will be, to me it looks like its printed on a home 3D printer. What you could do if you do not mind paying a bit more is get the supplier to print via a Selective Laser Sintering (SLS) process which will not only provide a better finished product but also provide something that is more robust.Jeags wrote: ↑Tue Sep 01, 2020 3:21 pmRight, after some research, I'm going for the following setup I think!
Cheers as always,
Joe
- Has thanked: 2567 times
Re: Pod gauges!
Don’t forget that you could be looking at c£50 or more shipping and clearance costs if customs decide to charge you VAT. A gift below £135 won’t attract VAT.
Re: Pod gauges!
For a really tight budget. https://www.carbuilder.com/uk/search?q= ... &sid=false
- Has thanked: 3 times
- Been thanked: 25 times
Re: Pod gauges!
Simple solution of location of engine oil temp. meter (12,6 degr. C. on picture) with probe in sump........ashtray lid can be closed.....ashtray can be re-installed if required...
I have a similar solution with my Mazda 2 1,5 GT-M......oil temp. meter located in "coin box".....
- These users thanked the author Rudolph for the post (total 2):
- New Duke (Fri Nov 27, 2020 5:18 pm) • GreySilver Beast (Fri Nov 27, 2020 5:28 pm)
- Has thanked: 68 times
- Been thanked: 131 times
Re: Pod gauges!
A little late to this thread but you could go down the road of making your own air vent pod gauge holder I did it for the MX~5 as there where at that time none available and none I liked just two 52mm pods at an angle put together, with holes for cables pre drilled sprayed up then cover with alcantara fabric. the base is on 4 very strong magnets so you can adjust them to suit and remove them to clean the window space...
the larger 52mm pod is for the extra wiring as the lighting, earth, ignition wires are on an umbilical from one gauge to another I just added the two small sun shades for effect the gauges are from PROSPORT a little pricey but worth it and come with white, green ,blue, red, orange illumination backgrounds ....
- These users thanked the author exiled--viking for the post:
- GreySilver Beast (Sat Nov 28, 2020 3:09 pm)
- Forum Guest
- Been thanked: 3 times
Re: Pod gauges!
HiRyan Rotary Performance wrote: ↑Mon Aug 31, 2020 9:46 pmJust gone into production; will be finished in Gloss Black and priced at £99.99 plus P&P
Will fit into the Ashtray:
I don´t know if finally this awesome pod has been produce or don´t, I couldn´t find it on your website, but I really want one of this if is possible.
Thanks in advance.
- Has thanked: 410 times
- Been thanked: 91 times
Re: Pod gauges!
I took a diy route and modified the original ash tray. I think pictures talk for them selves
- These users thanked the author Milos_Balunovic for the post (total 2):
- warpc0il (Fri Jan 28, 2022 10:58 pm) • GreySilver Beast (Fri Jan 28, 2022 10:59 pm)
Re: Pod gauges!
That's very neat
- Milos_Balunovic (Sat Jan 29, 2022 5:22 pm)
