Has thanked: 173 times
Been thanked: 523 times
Post by PaulAV »
New Duke wrote:
Fri Nov 20, 2020 5:43 pm
I maintain my position that the RX8 is one of the most reliable and punishment-friendly cars out there. Stop proving me wrong! :p
Never let me down in 13 years of ownership, I daily driver it and used it when I was a regional technician (34,000 miles in 20 months)
ChrisHolmes (Fri Nov 20, 2020 6:02 pm)
Been thanked: 220 times
Post by Neilparry »
Went out in the rain this morning to check the battery is holding charge so connected it up and straight off the key vvvvvroooom
Pity it’s kept on the trailer as I’d have been tempted to take her for a “spin”.
nightfire10 (Fri Nov 20, 2020 9:02 pm)
Not really a good idea to run the engine without driving.
The amount of time running rich from the cold start is much longer on no load.
The condensation from starting the cold engine doesn't get purged.
The oil pressure at idle is much lower.
The stress on bearings etc is actually higher at idle because the engine isn't running smooth.
All in all, more harm than good running the engine :(
Has thanked: 741 times
Been thanked: 283 times
Post by nightfire10 »
warpc0il wrote:Not really a good idea to run the engine without driving.
But it made Neil feel good ImageImage
Has thanked: 150 times
Been thanked: 162 times
Post by bigpete8 »
Yorindesarin wrote:
Fri Nov 20, 2020 5:40 pm
😂 Hopefully not frequent! Just seems to be my luck.. Do one thing something else plays up.
I know that feeling... Some time away from the car sometimes helps you think things through.
Post by Neilparry »
Got it up to temp whilst going through a moderate Rev range and waited till the condensation subsided before turning it off.
And yes what a great feeling
And when it’s worn out I’ll just put another engine in. With Wayne’s help lol
nightfire10 (Sun Nov 22, 2020 7:25 am)
Has thanked: 318 times
Been thanked: 256 times
Post by MARKTHOMASBRAND »
Neil how dare you start up your own car :lol:
Post by Neilparry »
I’ll be taking it for a shake down and an mot shortly so I’ll be sure to let you all know before hand.
HarSc
Has thanked: 569 times
Been thanked: 525 times
Post by HarSc »
Bilstein B12 kit arrived yesterday (finally after a few weeks waiting :shock:) - many thanks to craigy for the heads up on the model number of the kit - so that is going on the car ASAP next week, and in the meantime i've been taking apart the dash and test fitting a Sony double din radio that i picked up. Already had the metra high gloss fascia and a harness, I just need to figure out what wiring is needed to make my own "custom" harness between the mazda connector and the ISO leads from the head unit, i'll be browsing the electrical schematics for the R3 on the OC tonight! Still think i need a PAC RP4 MZ11 can bus adapter and maybe a line level converter as i'm keeping the bose amp? Still got more to figure out hah!
Hopefully going to be pulling the headliner to wire in a front and rear dashcam tomorrow - any tips on where to run the wire on the pillars? I'm hoping to get it all buried and just wire the usb power straight into the ignition power somewhere under the front dash or into a connector somewhere?
These users thanked the author HarSc for the post:
craigy85 (Sun Nov 22, 2020 8:13 am)
Some guy from oooop north ;) | Harry | Membership Secretary | Media Team
- My Main RX-8 R3 [MHZ 3800] thread here
- My Project Banana [GL04 MXU] thread here
- My Mazda 2 DE daily thread here
- My engine disassembly shenanigans here
Post by PaulAV »
Fitted my new starter motor today in the hope it would help with my spurious check engine light, result is no it doesn't help.
Pippypip (Sat Nov 21, 2020 9:40 pm)
Pippypip
Has thanked: 116 times
Been thanked: 78 times
Post by Pippypip »
So I have discovered that my seats I fitted can recline all the way back meaning that my Rx8 is basically a camper now Image
Also on my way to work I had an issue where my power steering went and the light came on after going over a bump but it after I restarted the car the light had gone.... I’m hoping that a connector might just be loose otherwise that’s another thing to fix Image
For my rear and front dash cam cables I just slid them under the trims I think I removed the door step trim also just got a piggyback fuse and connected in the passenger footwell fuse board.
These users thanked the author nightfire10 for the post (total 2):
ChrisHolmes (Sun Nov 22, 2020 9:15 am) • HarSc (Sun Nov 22, 2020 10:19 pm)
SmuttyHutty
Has thanked: 252 times
Been thanked: 206 times
Post by SmuttyHutty »
Pippypip wrote:
Sat Nov 21, 2020 11:08 pm
Oh, I think you can be FAR more creative than that...
Markl17
Colour: Stormy Blue
Has thanked: 35 times
Been thanked: 73 times
Post by Markl17 »
Last night really
I cleaned and checked all the AC components really to put back on,as running a car down here with no ac was a big mistake.
At a track day it was 38 degrees air temp I nearly melted in the car.
These users thanked the author Markl17 for the post (total 3):
V8 Power (Sun Nov 22, 2020 9:06 am) • ChrisHolmes (Sun Nov 22, 2020 9:16 am) • nightfire10 (Sun Nov 22, 2020 10:40 am)
Has thanked: 93 times
Been thanked: 165 times
Post by V8 Power »
Although my car is stripped out I could not bring myself to sacrifice the air con. So I pleased I didn’t as much for its dehumidifying affect as its cooling.
Removed the rear light cluster to empty put the contents and fix the seal. When I rotated it to pour the water out it poured out of the top edge seam so no wonder it filled up when the gasket is actually sound and the gully clear. I am going to seal that top edge and leave everything else "as is" to see if the problem is returns.
ChrisHolmes wrote:Removed the rear light cluster to empty put the contents and fix the seal. When I rotated it to pour the water out it poured out of the top edge seam so no wonder it filled up when the gasket is actually sound and the gully clear. I am going to seal that top edge and leave everything else "as is" to see if the problem is returns.
Led ones or oem
Luke0611
Has thanked: 82 times
Been thanked: 60 times
Post by Luke0611 »
Finished painting the MS bumperImage
Sent from my SM-G988B using Tapatalk
These users thanked the author Luke0611 for the post (total 4):
MARKTHOMASBRAND (Sun Nov 22, 2020 3:59 pm) • V8 Power (Sun Nov 22, 2020 4:01 pm) • v-rex (Sun Nov 22, 2020 4:03 pm) • HarSc (Sun Nov 22, 2020 10:23 pm)
R3-40th Anniversary [97/400] R3 face conversion in Ford Frozen White (originally Met Grey)
Engine Rebuild at 96,###.
Full bridge port
Tuned by Rotary Revs @209whp
Lightweight flywheel
Mazda Rev C Coils
AEM CAI
Racing Beat catback
Dual Res Decat
R-Magic Exhaust Manifold
Rota Pro R 18"/9.5
Yokohama AD08RS 255/40/18
TEIN Flex Z Coilovers
Whiteline ARBs
Post by V8 Power »
That is going to look awesome!
Luke0611 (Sun Nov 22, 2020 4:07 pm)
Post by PaulAV »
Ordered a varta E23 yesterday, did a battery test today, measured voltage at rest 12.1 volts when cranking I'm sure it dropped below 10 volts (this car is driven basically every day, work is a 40 minute drive each way) so I'm glad I ordered the battery now (I know it should be the other way around, test before replacement is ordered, but had a feeling the battery was suffering a bit)
nightfire10 wrote:
Sun Nov 22, 2020 3:46 pm
Led ones or oem
OEM on the Nemesis.
Ryan Rotary Performance
Former Trader
Former Trader
Has thanked: 46 times
Been thanked: 153 times
Post by Ryan Rotary Performance »
Some interior mods
These users thanked the author Ryan Rotary Performance for the post (total 5):
ChrisHolmes (Sun Nov 22, 2020 7:28 pm) • HarSc (Sun Nov 22, 2020 10:23 pm) • craigy85 (Sun Nov 22, 2020 10:40 pm) • New Duke (Sun Nov 22, 2020 11:57 pm) • Rafael (Thu Nov 26, 2020 11:33 pm)
Has thanked: 114 times
Been thanked: 158 times
Post by mrspiller »
Washed it and started it up in this Evenings cool
Air Image
Post by Neilparry »
How dare you.
Watch you don’t get told off.
These users thanked the author Neilparry for the post (total 3):
nightfire10 (Sun Nov 22, 2020 7:58 pm) • 30405 (Sun Nov 22, 2020 8:11 pm) • MARKTHOMASBRAND (Sun Nov 22, 2020 8:11 pm)
Post by mrspiller »
Neilparry wrote:How dare you.
Watch you don’t get told off. Image
He has a point
Probably why mine is still steaming after half hour
I do let oil get up to temp before a turn it off
Anglesey preparation ImageImageImageImageImage
