- Colour: Metropolitan Grey
- Has thanked: 75 times
- Been thanked: 34 times
Removed trackday wheels/tyres and decat in readiness for this months MOT.
Got a call from Mazda Saturday, the parts for the recall work that was scheduled for Monday haven't come in, so no trip to the dealers for me.
40th Anniversary RX8
- Been thanked: 220 times
Hopefully nothing more than dew on the windows.warpc0il wrote:Expecting rain?
- Has thanked: 170 times
- Been thanked: 115 times
Not started her for a good 4 days and it was not good, struggled to get her going and when she did spin sat at 300rpm with a bit of juddering and vibrating up and down to 1k then jumped up to 2,500ish drove normally, hot start went much better but still took a few cranks, looks like the new starter really helped with hot start (not perfect but okayish) but cold starting is very bad now.
Emailed Rotary Revs to see about getting a compression check / get them to look at the issue. Anyone know how long it usually takes for them to reply? or would it be better to phone them?
40th Anniversary Edition 369/400 203rwhp
Engine Rebuild + Street Port - 24/09/2021
Lightened and balanced rotors
Pettit Catback
Smoked Rear S2 Style Taillights
Exedy Clutch
CC Ultra Lightweight Flywheel
CC Counterweight
Tein S.Tech Lowering Springs
Racing Beat Ram Air Intake
Footwell LEDs
Build thread: viewtopic.php?f=104&t=83328
Pettit Catback
Exedy Clutch
CC Counterweight
Footwell LEDs
- Been thanked: 2086 times
The new starter will be taking quite a bit more current, which puts more load on the battery and makes good battery and earth connections even more critical.Nanotrox wrote: ↑Wed Oct 14, 2020 2:35 pmNot started her for a good 4 days and it was not good, struggled to get her going and when she did spin sat at 300rpm with a bit of juddering and vibrating up and down to 1k then jumped up to 2,500ish drove normally, hot start went much better but still took a few cranks, looks like the new starter really helped with hot start (not perfect but okayish) but cold starting is very bad now.
It would be worth removing, cleaning and tightening the battery connections, plus the main body earth.
Also check that the battery is fully charged and the electrolyte level is over the plates, in all cells.
Note that these are what makes the most difference on a cold start, as a hot start is easier on the battery.
- Nanotrox (Wed Oct 14, 2020 3:13 pm)
Cheers for the advice Warp! I've done all of them bar cleaning the earth where abouts is the earth located? battery is in really good nick even got the new one tested at halfords and the report came back good, I've even changed the battery connectors as they were quiet worn. However now you've mentioned it my battery within a day seems to go down to 12.4v sometimes as low as 12.1 - 12.2 withing a couple to a few days but never goes below that, I have tested for a dark current / parasitic draw with a multimeter and pulling fuses and nothing.warpc0il wrote: ↑Wed Oct 14, 2020 3:07 pmThe new starter will be taking quite a bit more current, which puts more load on the battery and makes good battery and earth connections even more critical.Nanotrox wrote: ↑Wed Oct 14, 2020 2:35 pmNot started her for a good 4 days and it was not good, struggled to get her going and when she did spin sat at 300rpm with a bit of juddering and vibrating up and down to 1k then jumped up to 2,500ish drove normally, hot start went much better but still took a few cranks, looks like the new starter really helped with hot start (not perfect but okayish) but cold starting is very bad now.
Pettit Catback
Exedy Clutch
CC Counterweight
Footwell LEDs
Pettit Catback
Exedy Clutch
CC Counterweight
Footwell LEDs
Follow the thick cable down from the battery -ve to the earth connection.
Try switching the internal alarm sensor off, using the 4th button on the fob, just after locking the car. This reduces battery drain.
- Has thanked: 71 times
- Been thanked: 90 times
Booked the afternoon off work and was going to change my fluids and fit Autumn tyres but due to the enhanced Covid lockdown in London means there's no in household mixing after Saturday (even though the borough I live Bromley is lower than the UK average) so had to sort out my mates suspension today instead.
I recommend him JOM's earlier in the year which unfortunately weren't up to the job so got some Bilstien B12's instead.
Using the timelapse function on the doorbell to record.
- These users thanked the author untakenname for the post:
- nightfire10 (Fri Oct 16, 2020 7:01 am)
Sneaky and effective, I like thatuntakenname wrote: ↑Thu Oct 15, 2020 11:43 pmUsing the timelapse function on the doorbell to record.
Should post it here too
viewtopic.php?f=22&t=80684
- untakenname (Sat Oct 17, 2020 11:20 pm)
Did the 6 hour return drive back to Krown Rustproofing for a touch up. Posted details here:
viewtopic.php?f=144&t=80393&p=1288455#p1288455 At first I planned to improve my fuel economy personal best. Then chastised myself and had a fun day being a twonk and generally scaring dozy road users. Waaaaaay more satisfying and brightened up dreary Birmingham.
- Dr. FrankenRex (Mon Oct 19, 2020 4:08 pm)
- Has thanked: 121 times
- Been thanked: 202 times
God every time I drive through Brum I feel like it exists just so other places like Scotland or Wales can have nice views. Just focus all the drearyness in one place and it takes it away from other ones.
Good on you for enjoying yourself.
- 30405 (Fri Oct 16, 2020 7:59 am)
- Has thanked: 742 times
Anyone got any dimpled and grooved mtec discs (or similar) for sale?
- Has thanked: 173 times
- Been thanked: 523 times
Honkytonk, the best thing about Brum is the road out of it. At least that's what we say in Coventry. Amazingly Birmingham had only been a city for just over 150 years where as Coventry had been a city for adding 750 years, something happened to Birmingham very quickly, but unfortunately it didn't receive massive remodeling in the mid 20th century unlike Coventry
- Honkytonk (Fri Oct 16, 2020 1:59 pm)
Checked battery grounds today and still no let up on the issues at hand.
Phoned Rotary Revs and she's booked in for the 60 point health check up and a compression test on the 7th, I live 130 mile away so it's worth killing two birds with one stone.
Just saying RR were really good on the phone so can't wait to get down their and hopefully find some answers.
Pettit Catback
Exedy Clutch
CC Counterweight
Footwell LEDs
Pettit Catback
Exedy Clutch
CC Counterweight
Footwell LEDs
That's the 'civic planners' of the Luftwaffe for you.PaulAV wrote: ↑Fri Oct 16, 2020 12:45 pmHonkytonk, the best thing about Brum is the road out of it. At least that's what we say in Coventry. Amazingly Birmingham had only been a city for just over 150 years where as Coventry had been a city for adding 750 years, something happened to Birmingham very quickly, but unfortunately it didn't receive massive remodeling in the mid 20th century unlike Coventry
- These users thanked the author Honkytonk for the post (total 3):
- PaulAV (Fri Oct 16, 2020 3:14 pm) • exiled--viking (Sun Oct 18, 2020 4:43 pm) • johnbb99 (Fri Oct 23, 2020 1:25 am)
- Has thanked: 93 times
- Been thanked: 165 times
Written about Coventry not Birmingham
- These users thanked the author V8 Power for the post:
- Honkytonk (Fri Oct 16, 2020 3:24 pm)
- Has thanked: 57 times
- Been thanked: 31 times
Dropped her off at The Performance Shop, sills being replaced, undersealed, tyres, new engine mounts, service & MoT on the cards.
So it's Shanks Pony for me for a couple of weeks.
Sent from my SM-T550 using Tapatalk
- These users thanked the author chriskirkham for the post:
- exiled--viking (Sun Oct 18, 2020 4:42 pm)
- Has thanked: 68 times
- Been thanked: 131 times
Had a Day In the Garage Loft with four Large RX~8 boxers of old mods and sods Now committed to the grey waste Bin But that makes way for the New relabelled MX~5 parts Boxers Now Making a double Fin spoiler out of FRP and aluminium mounts for MX~5 along the lines of the one ~~I had on the RX~8 but only better
- These users thanked the author exiled--viking for the post (total 2):
- GreySilver Beast (Sun Oct 18, 2020 5:49 pm) • ChrisHolmes (Sun Oct 18, 2020 7:29 pm)
- Has thanked: 116 times
- Been thanked: 78 times
Started working on a 3D model for a gauge pod holder based on the racing beat design
Someone has already made a design for something else using the same panel which has made it nice and easy
- These users thanked the author Pippypip for the post:
- Rafael (Sun Oct 18, 2020 6:29 pm)
- Has thanked: 114 times
- Been thanked: 158 times
Could you do a gauge pod for the centre of the dashboard ?Pippypip wrote:Started working on a 3D model for a gauge pod holder based on the racing beat design
I have one RB ashtray one in my garage if you want to copy it
- RX-8: Evolve
- Has thanked: 12 times
- Been thanked: 15 times
Phil, I've got FEED center dash one if you would like to take some measurements for design. I think its best one on the market but price tag of £280 its insane. That will be great idea to try make one like that.
- These users thanked the author Rafael for the post:
- mrspiller (Sun Oct 18, 2020 6:34 pm)
Cooper Red Evolve, Pettit Racing Exhaust, Racing Beat Lightweight flywheel, AEM Intake, Tein Flex Z, RRP COFS, RRP Lightweight pulley kit, RRP MKIII Coils, RRP Full Bridgeport, RRP engine mounts
I would have made myself one for the centre but I have an android tablet installed in my sat Oe sat Mac holder that I like too much to get rid of.
I can have a look at making one later but right now I can only use either the racing bear style or one that pops into the drivers vent above the cluster.
As said , I have one you can copy if your stuck
I was just thinking a neat 3 gauge holder that would stick on centre of dash and follow and the contour of the dash . Not a rough cut one like I currently have
It’s only a track car so it’s no big deal
- Has thanked: 750 times
- Been thanked: 175 times
LED side markers! Drying ready to install.
- These users thanked the author 30405 for the post (total 2):
- Pippypip (Sun Oct 18, 2020 7:05 pm) • v-rex (Mon Oct 19, 2020 7:44 pm)
- Been thanked: 283 times
Is that single LED or LED strip? I want some but I want them so they do that thing where they flash sequential lines lmao.
