Jeags
Has thanked: 150 times
Been thanked: 37 times
Post by Jeags »
Finally got round to fitting the gauges to the car. Took most of the day, bit well worth it in the end. Considering the gauge holder (vent) cost me around £65, I think it's great! (Tape and cloth to hold it down whilst silicone sets). Image
These users thanked the author Jeags for the post (total 2):
rotatopotato (Sat Sep 19, 2020 8:28 pm) • GreySilver Beast (Sat Sep 19, 2020 9:00 pm)
rotatopotato
Has thanked: 448 times
Been thanked: 201 times
Post by rotatopotato »
Pippypip wrote:
Sat Sep 19, 2020 8:14 pm
rotatopotato wrote:
Pippypip wrote:
Sat Sep 19, 2020 8:09 pm
Looks good mate.
When did you order it though because I tried to order one the other day and they didn’t have anything on their eBay store.
About a month ago, though he didn't have one advertised. I sent a message asking for one, didn't get a response, but then a listing showed up, so probably worth just doing the same.
At the moment for RHD he's got the full kit advertised (w/ sohn adapter): https://www.ebay.com/itm/203106313997 - which was all there was for RHD when I messaged him.
Oh okay nice thanks. I think I will have to pop him a message then too as I only need the “support kit” tank bit.
Yeah just keep an eye on his listings after you do - like I say he didn't actually respond to me, and I happened to notice a listing for the RHD support kit popped up a couple days later. You don't have to worry about the customs bill on the way in either as it goes through the global shipping program (so you pay it all up front).
nightfire10 wrote:
Sat Sep 19, 2020 7:04 pm
warpc0il wrote:Drain the diff oil and check for any broken bits coming out.
What diff oil do I need dave and how much? Cheers
The diff, unlike the 6-speed 'box, is quite happy with GL-5 transmission oil.
Even though it's an LSD, the design means that it doesn't require any special "LSD oil"
1.3L* of any of these should suit https://opieoils.resultspage.com/search?secure=1&w=GL-5
My personal choice is https://www.opieoils.co.uk/p-983-fuchs- ... r-oil.aspx
Used code CAR10 for 10% off
*strangely this has remained at 1.3L despite the gov'mint changing all our V5s [-X
30405 (Sat Sep 19, 2020 8:59 pm) • nightfire10 (Sat Sep 19, 2020 9:18 pm)
Has thanked: 741 times
Been thanked: 283 times
Post by nightfire10 »
Cheers dave
rotatopotato
Started looking at removing the air pump pipe (I have a blanking plate from Essex rotary), however I can't see myself getting this done without destroying the studs:
...p**** of a spot to get to, and those nuts don't even have defined sides anymore. Think I'll leave that for the next engine rebuild.
Also tried out the jacking/axle stand pads for this, unfortunately the jacking pad is too big (I think there was a smaller size but it wasn't available):
With a tiny bit of trimming the axle stand pads seem to work OK:
BTW, when installing the sohn tank yesterday, I needed to remove the battery box, and of course the two bolts holding it in snapped off with ease 😑 so hopefully it sits in there snug enough without them!
Has thanked: 173 times
Been thanked: 523 times
Post by PaulAV »
Possibly the best option for your hard pipe stud's is to cut the hard pipe, remove the manifold, remove the nuts whilst off the car then bolt your plate on. I had to do this to remove my old manifold when fitting a teaching beat one.
rotatopotato (Sun Sep 20, 2020 11:52 am)
Goobie
Has thanked: 12 times
Been thanked: 104 times
Post by Goobie »
Jeags wrote:
Sat Sep 19, 2020 8:21 pm
Like that, looks good!
These users thanked the author Goobie for the post:
Jeags (Sun Sep 20, 2020 2:23 pm)
rotatopotato
Next tasks done:
Fitted a shoft (no pics).
Did a headlight restore with the Armourall wipes kit, didn't get a before pic but they were noticeably yellow, so I'm pretty happy with how this turned out for £9:
After getting a hold of the stone guard strips off Bigpete, I discovered that they can't be fitted as a few of the plug holes have been patched over at the rear of the sills, so I've cut the heads off the plugs ready for a coat of plastidip or similar at some stage:
While doing this, I jacked up the drivers side rear (had already done the passengers side from the same point without issue), as it was jacking it went crunch and the car slipped down onto a jack a bit, so I quickly dropped it back to the ground and discovered this gaping hole that I'd just punched:
...which is depressing. Looks like the cancer is more extensive than I expected in this car, but I feel like I've already invested so much into it that I may as well look at getting this repaired (assuming it is possible to repair). I'll comfort myself in doing it in the name of keeping one on the road instead of reducing their numbers even further.
Has thanked: 114 times
Been thanked: 158 times
Post by mrspiller »
rotatopotato wrote:Next tasks done:
Ouch that’s nasty
rotatopotato wrote:
Sun Sep 20, 2020 2:34 pm
Sorry to see that and glad you were unhurt. This is why I always jack from the diff or the front central jacking point. Given that all our sills are a weak spot.
rotatopotato (Sun Sep 20, 2020 5:15 pm)
rotatopotato
From the Diff, should have thought of that 🙄
Just hoping it's repairable.
Also place your axle stands on the subframe mounts at the front and tie down lug at rear or subframe mount again.
Post by mrspiller »
ChrisHolmes wrote:Also place your axle stands on the subframe mounts at the front and tie down lug at rear or subframe mount again.
I normally Jack it up on the rear lug which attaches to the subframe
Can normally get 3 wheels off the ground
rotatopotato
ChrisHolmes wrote:
Sun Sep 20, 2020 4:34 pm
Ahh so using the usual place on the sills is actually just not a great idea full stop?
And here's where I start showing my ignorance when it comes to cars vs motorbikes - where are the subframe mounts / tie down lug?
At the front just behind where the lower are rear mount is bolted you will see a bolt head and a stud with a nut which is the rear mount. To Jack the car centrally at the front look at the rear edge of the under tray and you will see it has a cut out around a raised section if the subframe, this is a central jacking point.
At the rear you can jack on the rear most suspension arm chassis mounting bracket at either side. You will see a big lug sticking down from the chassis just in from the front edge of the inner wheel arch and your axle stand can go on there.
rotatopotato (Sun Sep 20, 2020 5:29 pm)
rotatopotato
Cheers, I'll keep that in mind for the future.
Taking it back to preserve & Protect on Friday so they can take a look over it. I'm definitely going to prioritise sorting out the body before any other major work (such as porting - though I'll be waiting for RRP to release their semi-pp upgrade anyway).
Pippypip
Has thanked: 116 times
Been thanked: 78 times
Post by Pippypip »
Finally got the engine out..... took so much longer than it should have because of the stupid riveted in Ecu and the fact I didn’t want to drill it out....
These users thanked the author Pippypip for the post:
30405 (Sun Sep 20, 2020 5:43 pm)
The ECU (aka PCM) is held in by shear-head security bolts.
In production the bolts are fitted as normal but torqued until top of the heads shear off, leaving a cone section protruding.
This is unique to the UK market and is part of the Thatcham-Approved Security required by UK insurers, and is designed to prevent physical tampering with the PCM.
To remove the bolts you can either;
- cut a slot across the top with an angle grinder or Dremal, and use a screwdriver
- centre-punch the head and drill the head off
- " " " " " with a left-handed bit, that usually spins the bolt out once the bit starts to bite (my preferred method)
- drill with a smaller bit and use an Easi-out (this has never worked for me).
When refitting replace with allen bolts.
Pippypip (Sun Sep 20, 2020 5:58 pm) • ChrisHolmes (Sun Sep 20, 2020 6:48 pm)
Pippypip
Post by Pippypip »
warpc0il wrote:The ECU (aka PCM) is held in by shear-head security bolts.
Ah I probably should have looked into it more before removing the engine.... May have been a bit too impatient I think...
rotatopotato
Managed 27.5mpg driving to Inverness, which I'm pretty chuffed with 😁
Honkytonk (Mon Sep 21, 2020 9:56 pm)
Average speed cameras certainly cause fuel savings!
rotatopotato (Mon Sep 21, 2020 9:22 pm)
geofftl1000r
Has thanked: 75 times
Been thanked: 34 times
Post by geofftl1000r »
Struts for the bonnet arrived finally. No more playing with sticks trying to hold the thing open in the wind.
These users thanked the author geofftl1000r for the post (total 2):
30405 (Mon Sep 21, 2020 9:31 pm) • Bigblueknight3k (Mon Sep 21, 2020 9:32 pm)
40th Anniversary RX8
Bigblueknight3k
Has thanked: 90 times
Been thanked: 45 times
Post by Bigblueknight3k »
Yep it is the best thing that lol worthy job and so worth doing
Sent from my LM-Q630 using Tapatalk
Media Team
Media Team
Has thanked: 121 times
Been thanked: 202 times
Post by Honkytonk »
ChrisHolmes wrote:
Mon Sep 21, 2020 8:50 pm
God those bloody things along the A9 are hateful I want to meet whoever put them in and strangle them with a length of haggis.
rotatopotato (Mon Sep 21, 2020 10:03 pm)
rotatopotato
Aye!
