Hi,
So I've had my RX-8 for about three and a half years now and have not had any issues with starting at all. She's always fired up immediately and never turned over before starting.
However two days ago and I turned the key to start her and the engine actually turned over two or three times before firing up and starting. I have since started and drove her a few times and have the same thing every time I start the engine.
I'm kind of hoping that someone might be able to give me a heads up as to what could be the cause for this.
Thanks.
Hi, new here and have a starting question!
- Has thanked: 144 times
- Been thanked: 282 times
Re: Hi, new here and have a starting question!
Could be low compression the symptoms of which are the car struggling to start when hot.By the way were those starts hot or cold? If cold then it could well be your battery needs replacing,if they were hot starts then it would be a good idea to get a compression test done by a rotary specialist
Mods so far..
BBR 200 PACKAGE
COBRA " RACE " BACK BOX
MEISTER COILOVERS
DROPLINKS
Mods planned..
BBR STAGE 2 SUPERCHARGED
WILWOOD 6 POT BBK
FULL UNDRBODY SEAL
ATOTO HEAD UNIT
Mods so far..
BBR 200 PACKAGE
MEISTER COILOVERS
DROPLINKS
Mods planned..
WILWOOD 6 POT BBK
FULL UNDRBODY SEAL
ATOTO HEAD UNIT
- Has thanked: 170 times
- Been thanked: 521 times
Could be anything from poor ignition, bad battery or starter, bad connections, dirty sensors or just heat soak
- Been thanked: 310 times
Hi and welcome to the forum,
It is probably down to coils or plugs ( but could be something else as well )
I would advise : Run a bottle of Cataclean through the fuel tank and then get the plugs ,coils and leads checked.
Regards
Regards
- Forum Guest
Hi, thanks for the quick responses. So it's the same whether the engine is hot or cold, same turning over two or three times before firing up. The battery was replaced about 12 months ago so shouldn't be that I don't think.
Clean your maf and eccentric shaft sensors, cheap and easy to do, then start looking into plugs, leads and coils (when were they last replaced?)
- Forum Guest
Ok cheers, I'll try that first. Plugs, leads and coils haven't been done recently to my knowledge so could be them.
I would recommend Ryan rotary performance coils (don't go cheap or you'll regret it) they also do all your service parts
Worth checking that the battery terminals are tight.
It's also possible that the starter is dying.
How old is the car?
How many miles?
Has the starter ever been replaced?
How old is the car?
How many miles?
- Forum Guest
2006
64, 278
Not sure on the starter being replaced, I would guess at no just because most of the general stuff I've had done has been the original parts that have been replaced.
64, 278
Use an ODB2 reader ( like Torque app and a dongle) to check the engine revs on the starter.
