PZ springs
- Colour: Metropolitan Grey
- Been thanked: 37 times
PZ springs
Hi all,
Put the 8 into local garage today to get tracking done and he said he couldn't do it yet due to a broken rear spring (driver's side). I know these are common faults and would like to replace them with the OEM PZ springs. I looked on the shop here and it says the rears are out of stock, any ideas where I can pick a good new set up from?
Cheers,
Joe
Cheers,
Joe
Re: PZ springs
The Club shop was the only stockist for these parts.
Your only remaining options are if someone bought a set in the group buy and is prepared to sell as their plans have changed, or someone replaced their original springs with new and still have one unbroken original spring you could buy.
- Has thanked: 2567 times
Re: PZ springs
Do you have PZ suspension on the car already? If not then you cannot fit the PZ springs as seats are different.
Re: PZ springs
One of the problems with Tapatalk is that it doesn't show the profile info, so I'd assumed you had a PZ.
Unless you're running the bespoke Bilstein dampers from a PZ then "PZ springs" aren't an option.
If you're running the original UK-spec suspension then that's actually "Mazda Sports Suspension" and you need springs to match that.
Don't go near motor factors, ECP, or anyone else that lists "replacement springs", as they will try and sell you the same spring regardless of which suspension you have.
Having had one rear spring break then both should be replaced, since the other would have been over-stressed.
I would recommend looking for a good, low-mileage, used pair from someone who has either upgraded to something totally different, or breaking the car for other reasons. Start with a call/message to BigPete.
You could fit complete PZ suspension, though this would have to be front and back, since the ride heights, spring and damping rates are different.
- Jeags (Tue Jul 28, 2020 8:19 pm) • ChrisHolmes (Tue Jul 28, 2020 9:30 pm)
Re: PZ springs
Yeah, the car is a prodrive version. Will hopefully find a solution soon, don't really want to change the suspension from OEM.ChrisHolmes wrote:Do you have PZ suspension on the car already? If not then you cannot fit the PZ springs as seats are different.
- These users thanked the author Jeags for the post:
- ChrisHolmes (Tue Jul 28, 2020 9:31 pm)
Re: PZ springs
Looks like our posts crossed - and you really need to update your profile
Back to Plan A then
Back to Plan A then
- Jeags (Tue Jul 28, 2020 8:33 pm)
- Been thanked: 310 times
Re: PZ springs
pick up emails
- Ainmhidh (Wed Jul 29, 2020 10:03 pm)
Re: PZ springs
Just a thought, but would it be worth asking if a garage would weld the break? It's at the very bottom of the spring. Just a thought but I'm not sure on how that would affect the spring?
Re: PZ springs
You can't repair springs by welding, since the heat means they don't "spring" any more.
- Has thanked: 97 times
- Been thanked: 539 times
Re: PZ springs
I know someone that had a leaf spring on the back of their motorhome welded.
Thankfully it collapsed before he even got it out of the workshop.
Re: PZ springs
Ah, kinda defeats the purpose of it then! I'll just have to keep an eye out for one before mot time in November!warpc0il wrote:You can't repair springs by welding, since the heat means they don't "spring" any more.
Re: PZ springs
What do we think about this?
http://essexrotarystore.com/product/tei ... -for-rx-8/
I doubt I'll be able to get any springs so it looks like I'll have to go for a new suspension. Just not sure whether to go for the above, or opt for the full PZ kit on the oc?
Cheers,
Joe
Cheers,
Joe
- Has thanked: 741 times
- Been thanked: 282 times
Re: PZ springs
You could email conan a few posts up he might have one or two
Re: PZ springs
Ah, missed that one. Cheers!nightfire10 wrote:You could email conan a few posts up he might have one or two
- nightfire10 (Wed Jul 29, 2020 2:39 pm)
- Has thanked: 38 times
- Been thanked: 116 times
Re: PZ springs
I had the street basiz then went with meister atm tein flex z. All have plus and minus.Jeags wrote: ↑Wed Jul 29, 2020 2:10 pmWhat do we think about this?
Cheers,
Joe
But street basiz is good for the money but not adjustable damping. If you spend a bit more you can have coil with more adjustability.
- These users thanked the author mi60o0 for the post:
- Jeags (Thu Jul 30, 2020 7:13 am)
- Been thanked: 280 times
Re: PZ springs
I'll have a set of tein Street basis z in decent condition for sale soon. 180 quid including p&p
- Jeags (Thu Jul 30, 2020 10:08 am)
Re: PZ springs
Nice! I'll have to assess all options, but sounds decent!Yorindesarin wrote:I'll have a set of tein Street basis z in decent condition for sale soon. 180 quid including p&p
Re: PZ springs
I don't think the springs are too bad for like the outer covering. But I won't know until I have them off the car. No clue what the mileage is like but I found them to be an excellent ride on the road etc. They'll be without top mounts and possibly gaiters/dust covers as I'll née those for the replacements.
- Jeags (Thu Jul 30, 2020 10:34 am)
Re: PZ springs
That's fine, send me a few pics if you can when you get them off the car!Yorindesarin wrote:I don't think the springs are too bad for like the outer covering. But I won't know until I have them off the car. No clue what the mileage is like but I found them to be an excellent ride on the road etc. They'll be without top mounts and possibly gaiters/dust covers as I'll née those for the replacements.
Re: PZ springs
It does seem a shame to compromise a PZ, if there's any way to avoid it.
Not that there's anything wrong with the Teins but the suspension is absolutely a key element in what makes a PZ a PZ.
Re: PZ springs
It is indeed. I'm sure once jeags isn't on apprentice wages he'll be in a better situation to sort that out. I'll tlbe taking them off after the cars actually moving again. Either next week or the week after probably if you aren't in much rush?
Re: PZ springs
Yeah, not in too much of a rush. Mot November so needs to be done by then. Plenty of time. Does the oc still stock any PZ suspension sets after they bought some? Was considering that, but not sure if I've been a member for long enough or can afford it. The teins are about £400 new so if it's only a bit more for a PZ set from the shop, I think I'd prefer that, was obviously why I favoured a PZ. Again though, don't know if I've been a member long enough yet! Just wondering whether it may be best to buy a new set, at least I them know it'll last well and hopefully, make the car feel like new.
- Events Team Member
- Has thanked: 507 times
- Been thanked: 451 times
Re: PZ springs
The club still has PZ full suspension sets in stock (we had 4 sets on May 27 and we haven't sold them all, to my knowledge.
Price £995 non-members, £595 for paid up members of 12+ months standing (bargain!!) - ex shipping, £47 UK mainland.
Further details here:
https://rx8ownersclub.co.uk/forum/viewt ... 42&t=79158
- These users thanked the author casey for the post:
- Jeags (Thu Jul 30, 2020 4:39 pm)
- Been thanked: 50 times
Re: PZ springs
i may have a used rear spring somewhere,not ideal changing 1 but the other was broken and i put the good one away just incase.
- These users thanked the author xamtex for the post:
