This is with Mazda On Track; Price £139 Inner & Outer Circuits, one will be AM and then one will be PM
GSB-TDU will be doing this Track Day and others are welcome to join me.
This is an equally brilliant event for anyone who is experienced on track or has never been on a track before. You really cannot (safely) explore the superb handling of the RX-8 to its limits on public roads.
The Blyton Park circuit is not a race track. It was specifically designed and laid out as a test and trackday venue. This means it doesn’t have lots of intimidating “Armco” and tyre walls around the circuit. It has an excellent smooth tarmac surface and, should you try a little too hard there is concrete run-offs on most of the circuit. At other areas you worst you are likely to do is to run off into a field of cabbages. However, this is HIGHLY unlikely to happen unless you make a HUGE error, as the RX-8 is so forgiving and the DSC so good.
With acknowledgement to other RX8OC members, here’s a couple of videos of what it’s like to drive at Blyton
Don’t worry about massive tyre wear during the day. As long as you’ve got 3mm+ of tread at the start of the day and your tyre pressures are correct, you are good to go.
Blyton Park is situated 1 mile from Blyton village on the B1205. Here's a LINK to the Blyton Park website where you can get more details.
Address
Blyton park
Old blyton airfield
Kirton road
Gainsborough
DN21 3PE
List
- GSB-TDU (Nigel)(GT86) - Booked/Paid
