Individual Throttle Bodies - Pros and Cons
Any form of normally aspirated power mods.
Dom-PZ
Has thanked: 16 times
Been thanked: 15 times
Post by Dom-PZ » Mon Jun 22, 2020 5:45 pm
It doesn't seem to have been covered much, and that's probably because the OEM intake system is pretty good, but in order to fit the engine into my Westfield the way I want to fit it, I need to lose around 60mm of height... and that means losing the standard setup. That leaves me with two options - a custom intake manifold that takes a different route but keeps the lengths of the OEM setup (so I essentially lose the benefits of the valves changing the intake tract), or a custom intake manifold that's considerably shorter and has a set of ITBs sat on top of it. I'm thinking the latter, but largely because I'm childish.
The first set of negatives that pop to my head I think I can mitigate quite well:
  • Lose low end and mid range performance - it will only ever have a maximum of 600kg to shift, and will spend most of its life on track
  • Will need an aftermarket ECU - will be using an aftermarket ECU anyway
  • Vacuum feeds will be a pain - I don't think I'll need any, certainly no brake servo
  • Packaging constraints will leave a curved route for the intake manifold - I have plenty of space width-wise and even have a cold air feed roughly where the brake servo would be in an RX-8
The next set of negatives I'm not so sure about
  • It's not peripheral ported so the intake won't be that straight
  • All ports being open all the time, may not be that efficient at low rpm... emissions for MOT?
  • Mapping - venturing off the beaten track means less in the way of base maps, more time on the rollers.
  • Still going to have a decent cost - la la la I can't hear you
  • The off-the-shelf racing beat parts would mean using an IDA fitment set of throttle bodies - less choice.
And off the top of my head, positives:
  • Whilst I'll lose some low and mid range performance, I don't think I'll be worse off when it comes to track rpms
  • Lose the drive by wire, meaning I don't need to fit a DBW throttle pedal
  • Throttle response - should be awesome
  • Noise - should also be awesome, but hopefully not too loud
  • Being able to fit the engine flush to the floor, I won't have a sump sticking out the bottom waiting to hit something
  • Simple - without the valves there will be less wiring, less to go wrong, and marginally less weight
So, I'm intrigued, as it's a good way of making the engine fit and delivering performance benefits as well. On piston engine'd cars. I'd think the same would apply to rotary engines, but the fact it's not common on the RX-8 is, well, it's a bit of a warning sign. It seems common on older RX-7s and 20B builds, but not the RX-8. I'd be interested to hear the opinions of others on this - it's not a path I want to go down if there's an obvious downside I've missed!
Has thanked: 24 times
Been thanked: 159 times
Re: Individual Throttle Bodies - Pros and Cons
Post by 350matt » Mon Jun 22, 2020 10:13 pm
Its certainly possible and I see no reason why it wouldn't work
what do you mean by having the engine flush to the floor? are you doing a dry sump conversion too?
Dom-PZ
Post by Dom-PZ » Tue Jun 23, 2020 12:18 am
No not dry sump. This is where the modified sump of the MX5-engine sat:
If I fitted the engine so the OEM inlet manifold was just shy of the bonnet, the RX-8 sump would be slightly lower than that, by about 20mm. It would be very prone to hitting speed bumps or kerbs on a track when I've been a bit enthusiastic.
It's purely for safety purposes. Whilst having the sump tucked inside the engine bay would be good aerodynamically - the rest of the car will still be pretty awful on that front!
Has thanked: 490 times
Been thanked: 1999 times
Post by warpc0il » Tue Jun 23, 2020 12:21 am
Wouldn't a bonnet hump be easier?
Dom-PZ
Post by Dom-PZ » Tue Jun 23, 2020 12:36 am
Definitely! I'm irrationally fond of my bonnet though. I did have the project priced up to change from my current bonnet to a separate nosecone and bonnet that could be humped (ahem)… but now I man mathing that cost towards throttle bodies.
Post by warpc0il » Tue Jun 23, 2020 12:41 am
Dom-PZ
Post by Dom-PZ » Tue Jun 23, 2020 12:47 am
The vent isn't wide enough, the intake manifold would be on one side of the vent, the throttle on the other.
Slightly old photo but I have this bonnet:
So my bonnet and nosecone are one piece and it's a flip front
Post by 350matt » Tue Jun 23, 2020 8:55 am
OK so if you were to biff off the original inlet manifold entirely and make up an angled / straight run into the ports you could have the ITB's poking through a vent on the LHS
kind of the opposite of what you have now
or make up another inlet that has the inlet 'U' bend tighter than original so the ITB's lie flat over the top of the engine pointing out sideways where the Duratec inlet trumpets would be
Dom-PZ
Post by Dom-PZ » Tue Jun 23, 2020 12:09 pm
I don't think I'd go back over the engine unless I needed the length. In my head, I'd look to emulate where it all ended up when I fitted bike throttle bodies to the MX5 engine:
I think it would be further towards the left hand side than those, but you can see a bulge in the side of the bonnet in the previous photo... there's one on both sides and that's where I'd look to park the filter. I think I'd need to shield it from the exhaust heat though.
Giving it a bit more thought this morning, I think I'll try throttle bodies, but not do any porting and keep expectations low. Rather than the traditional bridgeporting on the 231 engine, it would be better to await the intake peripheral porting that Ryan Rotary is developing. That would suit the ITBs quite well I think. If I can keep them quiet.
Post by 350matt » Tue Jun 23, 2020 1:21 pm
shutting up intake roar is often harder than exhaust
perhaps a solution like this
cosworth intake.jpg (57.29 KiB) Viewed 213 times
Dom-PZ
Post by Dom-PZ » Tue Jun 23, 2020 1:37 pm
I agree - I think something to seal it against the bonnet would be suitable from a noise and heat perspective. So like the enclosed box there (Caterham one?), but the bonnet becomes the top and side face of it.
Return to “Naturally Aspirated”
