Has thanked: 174 times
Been thanked: 524 times
Post by PaulAV »
Have moved on to my next project, front and rear mudflaps, were fairly fast pink, now sunlight silver, filled, primed and first coat of silver applied. At some point I'm going to have to fit these, along with the aero skirts, managed to download pdf files for oem fitment, any hints and tips? Searched already and there was a post about fitting, but it's no longer available.
Mog1
Been thanked: 15 times
Post by Mog1 »
Took the RX8 to the garage for repairs and MOT. Needs new drop links, rear coil spring, two tyres and discs and pads. First time driving it since the summer. Total mileage covered since last MOT, 260 miles. Too busy last year to really enjoy it. But me and the wife intend to enjoy it this year
johnbb99
Has thanked: 316 times
Been thanked: 53 times
Post by johnbb99 »
Cue GSB....
dvs
Post by dvs »
I can't really take credit for "doing" this but managed to fix up a bunch of issues yesterday (credit to Luke Murdoch):
- replace engine mounts
- replace exhaust/cat gasket
- fix oil leak
- fix rear droplinks
- fix rear ns shock
- fix os front ABS wiring
- fix os wing mirror (not pitching up/down)
- replace interior passenger lamp
- fix handsfree kit (mic unplugged :D)
- fit custom plate
chuffed!
2004 Sunlight Silver 231
Calibrated the EDFC and it bleeps away merrily doing its work invisibly.
Has thanked: 150 times
Been thanked: 162 times
Post by bigpete8 »
Fitted new battery terminals.
Didn't all go to plan as think I've messed up fuel trims.
viewtopic.php?f=6&t=74918&p=1248881#p1248881
EDECOA Battery Terminals Connectors with Wing Nut 12 / 24V Battery Clamps (1 pair)
Been thanked: 220 times
Post by Neilparry »
ChrisHolmes wrote:Calibrated the EDFC and it bleeps away merrily doing its work invisibly.
Does this mean I’ll see you next Thursday Image
Has thanked: 53 times
Been thanked: 76 times
Post by Scartlead »
looked at my 8, said hello but got no reply :)
Neilparry wrote:
Sat Feb 01, 2020 4:37 pm
Certainly does as I presumed you had swapped me and Dan around.
Post by Neilparry »
Yep I’m picking his up Wednesday so is Thursday ok
ChrisHolmes (Sat Feb 01, 2020 9:56 pm)
Davred
Post by Davred »
Removed rear offside light cluster. Dried out the water spots inside with hairdryer. Fitted new gasket which I covered with silicone grease then re-fitted and torqued up.
Hopefully will stay dry this time, third time of doing!
231 now gone, I'm likely to regret it.
Chilli Red MR2 Roadster[/color]
Daily car MB GLA 4matic amg line
Based in Leamington Spa.
RED's the Thing!!! (Mostly) :thumleft:
shroom
Has thanked: 16 times
Been thanked: 87 times
Post by shroom »
Scartlead wrote:looked at my 8, said hello but got no reply :)
Image similar to me , noticed an albatross has plopped all over it so gave it a jet wash didnt thank me or even acknowledge me. I'm sure its upset but it ain't going anywhere until the AGM
Sent from my SM-N960F using Tapatalk
Post by Scartlead »
The Nerve of it :)
Post by PaulAV »
So while fitting the front aero splash guard, I couldn't help being nosey and I looked behind the plastic expecting to see rust, all I can say is the rust treatment guy must of got some the night before.
Drove over to meet Gary Deery at Peartree Services, Oxford. Car ran well, fiddled with the EDFC.
Parked for about an hour then set off to 30405's place.
The dreaded rear end vibration returned, like driving with a badly flat spotted tyre you can hea4 and feel it plus the rear spoiler visibly vibrates. After a couple of miles thinking the car would shake itself apart the vibration suddenly stopped!
Hmm! Maybe because the tyres are a few years old the PS rear had “set” with a flat section whilst parked and then once some heat got into the tyre it levelled out.
Anyone experienced anything similar to this?
Techathy
Has thanked: 9 times
Been thanked: 18 times
Post by Techathy »
Failed hub bearing on a BMW 1 series, but that would also appear as suddenly as it disappeared.
These users thanked the author Techathy for the post:
ChrisHolmes (Sun Feb 02, 2020 6:32 pm)
Techathy
Post by Techathy »
Took the rear brakes apart as best I could without a new 'rebuild' kit cleaned everything, put in back together and bleed the brakes. Also, look at and despaired at the amount of corrosion behind the rear arch liners.
Has thanked: 100 times
Been thanked: 548 times
got a similar issue with the laguna at the moment. caused by a sticking caliper and warped disk. its also very random.
Has thanked: 186 times
Post by Dr. FrankenRex »
Test fit of the track wheels!
Ordered tyres too, some cheap Accelera 651s in soft!
Post by PaulAV »
Continued with the aero kit install, today was side skirt/deflector day, again I'm surprised at how well my car is resisting the dreaded rust, definately wasn't a Friday car in the rust treatment department.
shroom
Post by shroom »
Dr. FrankenRex wrote:Test fit of the track wheels!
I like the bales in the background gives it that barn look Image
Somewhat controversially that is why I called it the Auto Barn ;) :lol:
Well hello there 265/35R18 tyres!
Picture won't upload properly for some reasons, but they're tasty meaty bois
Loaded the car ready for Thursday at Neil’s.
Ainmhidh
Has thanked: 233 times
Been thanked: 146 times
Post by Ainmhidh »
think you need to put a bit more weight on the front end Chris. Looks like the steering will be light at that angle.
These users thanked the author Ainmhidh for the post (total 2):
30405 (Tue Feb 04, 2020 3:39 pm) • johnbb99 (Tue Feb 04, 2020 7:38 pm)
