New Cooling Upgrades - Series 1 only
Engine builds, Modification, Mapping, Products, Online store
Ryan Rotary Performance
Sponsor Trader
Sponsor Trader
Has thanked: 192 times
Been thanked: 688 times
Post by Ryan Rotary Performance » Wed Oct 23, 2019 12:57 pm
Website Links and blurb:
https://www.ryanrotaryperformance.com/s ... ng-upgrade - £180 kit
https://www.ryanrotaryperformance.com/s ... ng-upgrade - £300 Kit
https://www.ryanrotaryperformance.com/s ... ng-upgrade - £330 Kit
Rx8 Series 1 (2003-2008) – Ultimate Cooling upgrade
We have modified the Series 2 Water Pump which has a much improved Impeller design to fit the Series 1 Rx8. Say goodbye to the inefficient impeller design of the Series 1 Water Pump which has not been updated since the Rx7, and say hello to the new Water Pump Cooling Upgrade.
Benefits:
Reduced Engine Temperatures for Fast Road or Track use
More efficient impeller, reduces cavitation, increases cooling over a wider Rpm range.
Custom pulley which now under drives the Water-Pump without under driving the rest of the ancillaries.
More Power to the wheels, reducing pumping losses.
Availalbe in 3 sets:
Modified Water Pump, Gasket and Custom Plain Pulley – £180
Modified Water Pump, paired with Racing pulley kit. – £300
Modified Water Pump, paired with 4 piece Pulley kit. – £330
Last edited by Ryan Rotary Performance on Fri Oct 25, 2019 2:03 pm, edited 1 time in total.
These users thanked the author Ryan Rotary Performance for the post (total 2):
PeteH (Wed Oct 23, 2019 2:20 pm) • leeroy69 (Wed Oct 23, 2019 8:29 pm)
Paul_13
Has thanked: 86 times
Been thanked: 170 times
Re: New Cooling Upgrades - Series 1 only
Post by Paul_13 » Wed Oct 23, 2019 1:26 pm
Why do you supply a gasket when the R3 has a built in gasket?
Sponsor Trader
Sponsor Trader
Post by Ryan Rotary Performance » Wed Oct 23, 2019 3:59 pm
different bolt pattern
Has thanked: 85 times
Been thanked: 108 times
Post by Scartlead » Sun Mar 22, 2020 9:31 am
Hey Carl, is the pump compatible with the pulley set I bought from you? ie can I buy the pump on its own without the pulley if it is ?
Sponsor Trader
Sponsor Trader
Post by Ryan Rotary Performance » Mon Mar 23, 2020 7:04 pm
You'll need the S2 pulley and waterpump for this mod.
Velocity_Dan93
Has thanked: 33 times
Been thanked: 78 times
Post by Velocity_Dan93 » Tue Mar 24, 2020 1:14 am
Do you have any temperature readings for comparison with or without this kit on cars stock of modified? Just interested to see the difference
Phantom Evolve Mazdaspeed :)
Brilliant Black PZ :D
Crystal White R3 8)
lightning yellow racecar :lol:
Plus a load of other scrap
Post by Scartlead » Tue Mar 24, 2020 6:20 pm
Thanks, does the belt need replaced?
Sponsor Trader
Sponsor Trader
Post by Ryan Rotary Performance » Fri Mar 27, 2020 6:39 pm
Yes you can use the same belts. :)
Sponsor Trader
Sponsor Trader
Post by Ryan Rotary Performance » Fri Mar 27, 2020 6:48 pm
Hi Dan
When Ed Stracey did some testing for me ( I gave him one FOC) he noticed a significant improvement in his temps, cruising it was floating at the thermostat around 82-85 and at WOT he noticed that temps being more stable and less prone to spiking and then returning to normal faster so all in all a great improvement!
From memory you bought his car and so should have one?
These users thanked the author Ryan Rotary Performance for the post:
Velocity_Dan93 (Fri Mar 27, 2020 7:22 pm)
Velocity_Dan93
Post by Velocity_Dan93 » Fri Mar 27, 2020 7:23 pm
Hi Dan
I do indeed but don't have any temp logging on it :P just wondering if you had any details to hand save me starting a study into it ! cheers !
Crystal White R3 8)
SAS
Been thanked: 70 times
Post by SAS » Sun Aug 09, 2020 9:16 am
Hi Carl. When do you think the water Pump would be back in stock?
Supercharged :thumleft:
bc-49
Has thanked: 92 times
Been thanked: 81 times
Post by bc-49 » Thu Nov 12, 2020 2:19 pm
Potentially in the market for one of these.
Carl, have you got a price for fitting on the £180 kit?
Cheers!
2006 Galaxy Grey 231
Yokohama V105 | Eibach Pro-Kit Springs | Eibach 20mm Spacers | Mintex 1144 Pads | Racing Beat REV8 Catback | BHR Ignition | K&N Filter | Koyorad Alu Radiator | Mishimoto Thermostat | Greddy Sump | ER Braided Oil Lines | ER Oil Pressure Reg | ER Baffle Plate | Lockwood Front Grills
Sponsor Trader
Sponsor Trader
Post by Ryan Rotary Performance » Sun Nov 15, 2020 10:42 am
Out of stock I'm afraid at the moment.
SprintRX8
Has thanked: 6 times
Been thanked: 44 times
Post by SprintRX8 » Sun Nov 15, 2020 1:44 pm
Carl.
When are you expecting new stock?.
13BLT Renesis Rotary powered Dolomite Sprint in the making😏.
Balanced Lightened and Tweaked.and going Supercharged.
M12
Post by M12 » Fri Nov 27, 2020 2:08 pm
Any deals for Black Friday?
Winning Blue 231
Jap Speed Exhaust
Custom Oil Catch Can
Ryan Rotary Performance MK2 Ignition Coils
Hard Race Uprated Engine Mounts
Pro Sport Gauges
Battery Relocated to boot
And too many smiles :) per gallon
SprintRX8
Post by SprintRX8 » Fri Nov 27, 2020 9:07 pm
Any Deals for Super Saturday 👍
Sponsor Trader
Sponsor Trader
Post by Ryan Rotary Performance » Sat Nov 28, 2020 10:41 am
Sorry guys, the only things we have on sale are on the sale page within the website
Return to “Ryan Rotary Performance”
