johnbb99
Has thanked: 316 times
Been thanked: 53 times
Post by johnbb99 »
Honkytonk wrote:
Wed Oct 16, 2019 7:00 pm
You're right about the cable tube, but I found a section of flexible heat-shrinkable ribbbed plastic hose in my local The Range's aquarium section to cover it with, then heated and hot glued the ends to form a seal. It's not quite OEM but it's close enough...
Am I right in thinking that you cut right through any remaining cable and protective tube so you had loose ends on which to thread the tube from the Range?
Low-temperature solder joint with heat shrink?
https://www.ebay.co.uk/itm/100Pcs-Water ... 3360878363
johnbb99
Post by johnbb99 »
warpc0il wrote:
Thu Oct 17, 2019 12:22 am
Have you ever used or seen them 'in the flesh' Dave?
Yup, used them a few times.
The wire ends need to be bright clean and I dip in flux paste first, just to be sure.
johnbb99 (Thu Oct 17, 2019 12:36 am)
johnbb99
Post by johnbb99 »
When a website is that short on detail I tend to get a bit worried. 😉
Media Team
Media Team
Has thanked: 121 times
Been thanked: 202 times
Post by Honkytonk »
johnbb99 wrote:
Thu Oct 17, 2019 12:19 am
No, I split the tube addition down the middle (like a subway sandwich) and then when it heat shrunk it closed the gap, which I made sure of with a little extra hot glue (for the bodgiest of jobs)
I'll try and find what I used next time I'm in there. If you Google corrugated heat shrink you should see the type of stuff I'm talking about.
johnbb99 (Thu Oct 17, 2019 9:06 am)
Dentist
Has thanked: 22 times
Post by Dentist »
I am totally satisfied with rear speakers swap
Worth every penny :thumright:
It’s 15 min job I used jbl p963
Two engine disassembled one 231 other street
Ported. I literally surprised by amount of shaved
Port. I was thinking they shaping better! Also I
Discover ugly truth about coloured engines as
The color splash oils injectors and cause oil leaks
Hence damaging engine and so on...
Image Image Image Image Image Image
Close up photos of the ports will help us understand what you are referring to
Received a message today that Dean in LA has located a pair of orange front side marker lenses for me. Power to forums and Facebook for bring people together.
warpc0il (Thu Oct 17, 2019 10:58 pm)
exiled--viking
Has thanked: 68 times
Been thanked: 131 times
Post by exiled--viking »
ChrisHolmes wrote:
Thu Oct 17, 2019 10:51 pm
Wish I known you needed some I sure I got some in my mod box I check it out for you Let you know at the weekend ;) they should fit the ATH bumper the ones from USA you find that they will NEED SOME OF THE PLASTIC AT THE REAR trimming off to give you a good fit ;)
These users thanked the author exiled--viking for the post:
ChrisHolmes (Fri Oct 18, 2019 12:25 pm)
SprintRX8
Been thanked: 50 times
Post by SprintRX8 »
Nearly finished stripping the RX out.
Just a few more bits to remove.
Then it’s off to RX8 heaven 😂
RedCorn Collecting Monday hopefully..
13BLT Renesis Rotary powered Dolomite Sprint in the making😏.
Balanced Lightened and Tweaked.and Supercharged.
30405
Has thanked: 750 times
Been thanked: 175 times
Post by 30405 »
Replacement engine in and running!
Fluids changed so I'm starting from fresh. Just a coolant light on the dash now
Also found a new spot for my number plate. Just the undertray and wheel dressings to go.
Nickp47
Has thanked: 175 times
Been thanked: 326 times
Post by Nickp47 »
Not sure if I’m telling you what you already know John but the coolant light is a very common thing , most just unplug the sensor and check the level periodically.
30405 (Fri Oct 18, 2019 9:57 pm)
30405
Post by 30405 »
Nickp47 wrote:Not sure if I’m telling you what you already know John but the coolant light is a very common thing , most just unplug the sensor and check the level periodically.
Yeah i've been googling around. I'm just sad as it wasn't an issue before.
Dentist
Post by Dentist »
ChrisHolmes wrote:
Thu Oct 17, 2019 6:59 pm
aha didnt take pic as my hands were dirty.
will make pc or try to find it online
Dentist
Post by Dentist »
finally manage to correct pcv system to full active
I used mx5 pcv valve + 0.5mm long restrictor
air goes to bottom of factory catch (filler tube is factory oil catch can) via oil deep stick whole and coming out filler neck to
2ndry after market catch, then to pcv valve+restrictor then to Y pipe, finally two 3mm pipe to each main rotor port.
pros
all air are meter air from map sensor so no false fuel trim
air circulate actively to clean any moist and/or oil vapour
drain of system after all ssv and other valves so no carbon/ dirty/ sticky valve
addition lube for rotors
low pressure in sump reduce oil leaks, improve oil return to sump !?
cheap retro fit
cons
negative effect on octane
taking off deep stick
Lemon
Has thanked: 10 times
Been thanked: 59 times
Post by Lemon »
Gone back to my standard wheels and fitted a full set of pagid road pads
Sent from my Nokia 6.1 using Tapatalk
These users thanked the author Lemon for the post:
ChrisHolmes (Sat Oct 19, 2019 6:22 pm)
Thanks, Stu
Mad as anything
Has thanked: 93 times
Been thanked: 165 times
Post by V8 Power »
Will be interesting to see how you get on with the Pagids Stu
Lemon (Sat Oct 19, 2019 4:24 pm)
Lemon
Post by Lemon »
the rear pads on the car were pagids anyway and the fronts were 1144's but i've gone back to a road pad for when i'm not on track as i'm not liking the "pause" you get on the 1144's when they are cold.
i'll keep you posted once they are bedded in, but i't will be a few weeks as i'm using the parents cars as my dailies whist they are away.
Thanks, Stu
Mad as anything
Has thanked: 38 times
Been thanked: 116 times
Post by mi60o0 »
Has thanked: 318 times
Been thanked: 256 times
Post by MARKTHOMASBRAND »
mi60o0 wrote:
Sat Oct 19, 2019 4:59 pm
What is this when is back to normal?
Converted to KGF & 250 rpm :thumleft:
1st pic
First Chamber [6.9,8.5] : 6.2
Second Chamber [6.9,8.5] : 6.27
Third Chamber [6.9,8.5] : 6.2
Chambers Difference [<1.5] : 0.07
2nd pic
First Chamber [6.9,8.5] : 6.52
Second Chamber [6.9,8.5] : 6.45
Third Chamber [6.9,8.5] : 5.95
Chambers Difference [<1.5] : 0.56
Rotors Difference [<1.0] : 0.24
What's happened to your pics Mihail :?:
Post by mi60o0 »
I move it away I will make new test
These users thanked the author mi60o0 for the post:
MARKTHOMASBRAND (Sat Oct 19, 2019 5:36 pm)
Did you not like those results :?: :lol:
These users thanked the author MARKTHOMASBRAND for the post:
nightfire10 (Sat Oct 19, 2019 6:52 pm)
Post by mi60o0 »
Is spinning alot faster than the last test is wierd
