Vj4sothername wrote:
Fri Sep 13, 2019 5:45 pm
Broke this bent that...Image what should I be searching for to replace the hose connector? I'm hoping I can straighten out the plate.ImageImage
Hard to tell from the photo but it looks like the back of your accordion pipe might be cracked. Maybe worth a closer inspection if you haven't already.
30405
Has thanked: 750 times
Been thanked: 175 times
Post by 30405 »
Thanks New Duke, I'll take a close look at it tomorrow. I'm hoping its just where my hands been rubbing on the edge.
New Duke wrote:
Fri Sep 13, 2019 6:19 pm
Devon_Fourie
Been thanked: 18 times
Post by Devon_Fourie »
Vj4sothername wrote:Broke this bent that...Image what should I be searching for to replace the hose connector? I'm hoping I can straighten out the plate.ImageImage
I broke that same elbow joint. I bought a couple from big Pete with swift delivery. Drop him a message. He sells them as pairs so I keep one safe Image
Has thanked: 93 times
Been thanked: 165 times
Post by V8 Power »
Changed the oil and filter on the R3
It should be an easy job using the Pella but the location of the filter makes it a right pain.
I probably write the same on here every time but as I get older it gets more and more difficult crawling under the car to get at the filter.
Used my axle stand jacking pads for the first time and they worked well.
shroom
Has thanked: 16 times
Been thanked: 87 times
Post by shroom »
V8 Power wrote:Changed the oil and filter on the R3
I'm 28 and find it a nuisance getting under the car my back and knees hate it lol so God knows what I will be like when I'm older!
Phil Bate
Has thanked: 25 times
Been thanked: 96 times
Post by Phil Bate »
Set some sensible camber for an unsensible ride height
These users thanked the author Phil Bate for the post:
Paul_13 (Sat Sep 14, 2019 8:51 am)
Has thanked: 114 times
Been thanked: 158 times
Post by mrspiller »
Phil Bate wrote:Set some sensible camber for an unsensible ride height
Looming good Phil - completion must be imminent
johnbb99
Has thanked: 316 times
Been thanked: 53 times
Post by johnbb99 »
Many thanks to Wayne (Mr Spiller) for providing replacement oil cooler pipes and coolers at short notice.
He did a five-star job of labelling everything, sealing open ends, and wrapping everything up into a tidy package to be picked up. Much appreciated!
The brackets have suffered the predictable corrosion, so should I I leave them as they are (probably not), accept that they are weaker and just derust and repaint, or do I need to buy replacements at about £25 each?
And do I need to worry about the corrosion inside this pipe joint?
Thanks.
johnbb99
Post by johnbb99 »
...oh, and, any point in cleaning up and repainting the cast aluminium pieces?
Been thanked: 220 times
Post by Neilparry »
I’d Clean the inner part of the fittings with wire wool and clean out with wd40 or a solvent cleaner
Could do the same to the outside if your fussy.
johnbb99 (Sat Sep 14, 2019 4:24 pm)
NeMFO
Has thanked: 23 times
Post by NeMFO »
I am intending to do a compression test tomorrow morning but need to know how to isolate the ignition and injection systems. Can any one help with that please? What fuses do I pull?
Also, what is the best workshop manual? I am used to working out of Haynes manuals which I like but I haven’t been able to find one for the 8.
Has thanked: 741 times
Been thanked: 283 times
Post by nightfire10 »
NeMFO wrote:I am intending to do a compression test tomorrow morning but need to know how to isolate the ignition and injection systems. Can any one help with that please? What fuses do I pull?
Ess disconnect you will need airbox out turn your left hand back to front to pull connector off then your sorted for compression test! Image
NeMFO (Sat Sep 14, 2019 10:03 pm)
Thumb one side of the belt and fingers the other
NeMFO (Sun Sep 15, 2019 4:53 pm)
Dave2112
Been thanked: 93 times
Post by Dave2112 »
I find it easier to disconnect the ESS from underneath, as the car is already jacked up (on axle stands) with the wheel off to access the plugs. Saves stripping the air box out.
Kamikaze
Too many to list.
30405
Post by 30405 »
Checked the pipe and all is well. It's just a clean bit ImageImage
These users thanked the author 30405 for the post:
New Duke (Sun Sep 15, 2019 4:22 pm)
NeMFO
Post by NeMFO »
I got some intriguing results from the compression test today. One rotor exceptionally good on a 65000 mile car by my way of thinking and the other not so good at all so it looks like I am in the market for a rebuild. Love the sound of Carl’s 192 special bridge although I need to check the rest of the car over to make sure it is worth spending the money on first.
30405
Post by 30405 »
Continued getting everything ready for engine removal for a home rebuild. Only top bell housing bolts and engine mounts to go. Found someone's done a lovely job on "fixing" the secondary exhaust O2 sensor. ImageImage
Had the cable been routed wrong, so it wouldn't reach, or was it an aftermarket cat with the sensor mount in a different place?
Has thanked: 265 times
Been thanked: 359 times
Post by 13Black »
Irregardless, all the aftermarket cats/decats I've seen with sensors mounted in a different place still allow the factory O2 sensor cable to reach it without a problem.
30405
Post by 30405 »
warpc0il wrote:Had the cable been routed wrong, so it wouldn't reach, or was it an aftermarket cat with the sensor mount in a different place?
13Black wrote:Irregardless, all the aftermarket cats/decats I've seen with sensors mounted in a different place still allow the factory O2 sensor cable to reach it without a problem.
Not sure about the routing tbh as I've only ever seen this one. It's defo a cheap aftermarket one. I've not found a heat shield attached to it either that will explain the scorching seat mounts in the cabin. It should have one right?
Nickp47
Has thanked: 175 times
Been thanked: 326 times
Post by Nickp47 »
The seat mounts do get very hot with cheapo cats
30405 (Sun Sep 15, 2019 7:20 pm)
johnbb99
Post by johnbb99 »
I've been cleaning up my replacement oil coolers as they may be needed and found one of the fixings was so badly corroded that I sheared the bolt trying to unthread it.
Here:
And in detail:
Are these clips (that rusty bit, with a nut welded on underneath) a standard part that I might find elsewhere or be able to buy?
Has thanked: 173 times
Been thanked: 523 times
Post by PaulAV »
Not me personally, but Nick swapped out my leaking rear main oil seal, inspected rear stationary bearing whilst replacing O ring, minimal wear with no copper showing (engine has about 25k on it since rebuild) so all I have to watch out for now is rust as the oil leak was doing a good job at keeping the corrosion at bay
Has thanked: 38 times
Been thanked: 116 times
Post by mi60o0 »
Parked my rx8 in my Inlaws house and sorn it.
One more drive to come is mallory and then sorn again
Hello rx8 2020 summer after this.
One job to do is to replace the radiator and expansion tank I ordered from Japan.
So for mallory nice shiny koyorad and expansion tank that actually can be plugged in.
Jdm planet 80 quit new if I remember.
