- Been thanked: 283 times
Ooft thats come up a treat. Might have to look into doing that myself at some point. My shrouds are unsurprisingly grey like everyone elses. Would be nice if they matched the rest of the plastics! But at the same time I may wait until I get a different bumper as mine has some damage to it. Though thats on the back burner for "when I respray to a different colour." So quite far down the line as of yet.
- Has thanked: 121 times
- Been thanked: 202 times
Took it for a Razz tonight as it had been sat around for a week and a half, poor thing
Time away makes the heart grow fonder, and boy did I miss it. Gave it a proper good thrashing and saw a winning blue one stuck behind someone else going the other way - my hands were too firmly glued to the wheel to wave
- Has thanked: 24 times
Took it for a nice long journey. Fun though Mintex pads are so squeaky that I've had enough of them. Back to ebc redstuff for me.
The 1144s should not squeak at all if the bedding in procedure has been followed. Do you have the anti squeal shims fitted to the back of the pads.
Hmm, good question about the shims, I'll double check. CheersChrisHolmes wrote:The 1144s should not squeak at all if the bedding in procedure has been followed. Do you have the anti squeal shims fitted to the back of the pads.
A thin wipe of Ceratec on the back of the pads also helps prevent squeaks.
- Forum Administrator
- Has thanked: 47 times
- Been thanked: 155 times
They do look the business, will be interesting to see how it lasts compared to DTP (Direct to Plastic) as I was very pleased with the results from that too.
Forum Admin Team
2021- // 2009 Sparkling Black R3 | Pettit Exhaust | 20mm Eibachs
2017-21 // 2010 Aurora Blue R3 | Gone, never to return, never to be forgotten.
2011-17 // 2005 Titanium Grey 231 | Gone. But Lives(d?) on.
Forum Admin Team
The Pettit is now on the car. At last!
The tips don't quite line up in terms of their protrusion, not sure how to deal with that.
Sounds great though, instant grin. Now where's the nearest tunnel..
Forum Admin Team
Forum Admin Team
- RX-8: Import
- Colour: Black Cherry
- Been thanked: 119 times
""The tips don't quite line up in terms of their protrusion, not sure how to deal with that. ""
Worry not, the flames will even out the bodywork around them for you.
It's tru dat!
It's tru dat!
- RX-8: Import
eBay £11Devon_Fourie wrote: ↑Sun Sep 01, 2019 7:40 pmThat looks wicked, I suffer the same issue, where did you get that black dye from? I could do with some.Juey wrote:
Finally took the plunge and bought some bumper dye - results are pretty remarkable. Took many coats to cover the blue/grey but very pleased with how it's turned out.
Time will tell how long it lasts.......
Used MLM bumper dye - came with a foam applicator (but this makes the dye go bubbly) and a micro fibre cloth - best to use this by dabbing into a small pot of the dye as it goes on more evenly without the bubbles
a google search for mlm bumper dye brings up options for applicators with the bottle.
I put on many coats to the bumper and shrouds and only used a quarter of the bottle - loads left for topping up when it needs it, but hoping it doesn't all run off in the first shower
- These users thanked the author Juey for the post:
- Devon_Fourie (Mon Sep 02, 2019 9:37 pm)
- Has thanked: 90 times
Hello everyone need a bit of help want to fit oil pressure and oil temp sensors heard banjo bolts can be changed to put sensors in the top not got a clue what size etc any help would be great
Simplest way is to use a sandwich plate under the oil filter and put both sensors there.Bigblueknight3k wrote: ↑Mon Sep 02, 2019 6:45 pmHello everyone need a bit of help want to fit oil pressure and oil temp sensors heard banjo bolts can be changed to put sensors in the top not got a clue what size etc any help would be great
You can buy modified banjo bolts from the USA but your other option if your practical is get done banjo bolts from a breaker and drill and tap them yourself to suit the senders.
- Bigblueknight3k (Mon Sep 02, 2019 8:56 pm)
- Has thanked: 82 times
- Been thanked: 60 times
Looked at it, sad that I'm no longer insured on it. Going to miss it when it goes
Sent from my SM-G960F using Tapatalk
R3-40th Anniversary [97/400] R3 face conversion in Ford Frozen White (originally Met Grey)
Engine Rebuild at 96,###.
Full bridge port
Tuned by Rotary Revs @209whp
Lightweight flywheel
Mazda Rev C Coils
AEM CAI
Racing Beat catback
Dual Res Decat
R-Magic Exhaust Manifold
Rota Pro R 18"/9.5
Yokohama AD08RS 255/40/18
TEIN Flex Z Coilovers
Whiteline ARBs
Full bridge port
Mazda Rev C Coils
AEM CAI
Racing Beat catback
Dual Res Decat
Rota Pro R 18"/9.5
Whiteline ARBs
- Been thanked: 220 times
Set the alignment with our trusty gauge.
Maxed out on the negative camber and set the toe 1.5 ish out.
Rears already set as the rear end came off “Bully”.
And fitted the splitter
Why have you "set the toe 1.5 ish out" ?
FWD cars normally run some Toe Out, as the wheels are trying to pull ahead of the car, so when all the slack is taken up under power, the result is nearer zero.
RWD cars normally run Toe In, as the car is being pushed from the rear, between the front wheels, so when all the slack is taken up under power, the result is nearer zero.
The Mazda specification for the 8 is Toe-In 1.4 +/-2.8,, which would allow you to to be 1.4 Out, but it still doesn't make any sense to me, unless you're planning to do something very unusual with the car.
- Has thanked: 112 times
- Been thanked: 74 times
Maybe to get that "early turn in" feeling?warpc0il wrote:Why have you "set the toe 1.5 ish out" ?
I had my alignment done recently and it was toe out on the front. It did have an early turn.
Now it's been set to stock again and I notice it's slightly heavier to turn in although straight lines seem to be more... Straight and cornering seems to be smoother
Kia-ora!
'09 R3 Aurora Blue Mica
When mine was setup recently for track we put on some toe out. The idea was indeed to improve cornering. But in our case that meant reducing the toe out as it was previously in snowplough. The sweet spot we found was an angle that would give a nice sharp turn in, but not kill the tyres or create any tangible parasitic loss through increased drag. Which is likely where you'll want a motorsport engineer with lots of experience, hence why I didn't argue and just helped.
We also went as maximum as possible on the camber for the same reason, but were limited by the design of the PZ suspension and height of the car.
My castor bolts were rusted solid (like will-need-to-be-cut-out solid) but thankfully both sides were perfectly even and at an OK angle.
I was planning to go back for a tweak now it's been tested on track. But it's very good already tbh.
- warpc0il (Wed Sep 04, 2019 12:49 am)
Interesting...
I played with zeroing the toe on my Alfa, to improve turn-in, but found that the trade-off in rolling resistance (obvious by the tyre wear) and the increased tendency to tramline, didn't make it worth while, on the road.
It’s going on track and most of the tracks I go on are quite tight.
Looking for a positive turn in hence the toe. And you don’t get the tram lining on track that you do on the road.
It’s more a case of trial and error, so a tweet here and there is easily sorted.
Alignment is always contentious
What works for one !!!
- Has thanked: 93 times
- Been thanked: 165 times
My car was set with toe out (can’t remember how much) it definitely improves corner turn in on track.
wiped the baked bean juice off the passenger seat....
Early start picked up breakfast on way in - didnt notice till back out at car at lunch
Luckily leather seats dont absorb much but could do with buying more leather wipes!
Got some headlight restorer off amazon. Going to probably polish up my spare set of headlights off the car and swap them over when its a decent day!
Which one did you plump for?Yorindesarin wrote: ↑Wed Sep 04, 2019 12:33 pmGot some headlight restorer off amazon. Going to probably polish up my spare set of headlights off the car and swap them over when its a decent day!
Went for this in the end:
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
From what I gather most of them around the same price work just as well as each other.
Also currently waiting for a pilot bearing I ordered from Rotary Revs last friday... Rang up to enquire about the progress of it get told it'll be packaged up and sent out today... Seems a bit slow if they ship 7 days a week... :/ Waiting for it to get my clutch changed...
been having issues with the daily driver recently (not the rx8 but it is a car so sorta ok in here? . long list of issue with it but today it started using a lot of oil at full throttle and it cut out on me dead 3 times on the way home. thatll be the turbo just let go then
just going out to the garage to confirm, but this MIGHT put paid to me attending the ramp and bbq meet
