How to use cataclean?
- Been thanked: 6 times
How much fuel should I have in my tank to pour the whole 500ml bottle of cataclean? Is it okay to add some pre-mix 2T oil in too as the same time?
- Has thanked: 101 times
- Been thanked: 83 times
Re: How to use cataclean?
About a quarter tank spirited driving and then empty the tank prior to filling again
Does Cataclean have any tangible benefits? Is it recommended on this forum or a snake oil?
- Has thanked: 219 times
- Been thanked: 350 times
the bottle says put it all in to about a quarter tank and run at least 15 miles to be effective.
Rob
You really should join the Club as a full member, as nearly all the info that is useful is in the members section along with the techy stuff.
You are restricted to certain topics as a guest, plus you will recover the membership cost easily and then some with the available discounts from Traders .. and why are you using it anyway?
I used Cataclean when I first got my car, back in 2008, and it made a huge difference to how responsive the car was.
When I repeated 6 months later there was a perceptible difference, but nothing like the first time.
Repeated treatment, about a year later, really just in case for the MOT, and I couldn't tell any difference at all.
Same the following year, so I haven't bothered since.
My assumptions are;
- the car had been driven very gently before I took it over, having been owned by my parents for the previous 2.5 years, so there was probably a fair bit of carbon build-up internally.
- the last invoice for servicing in 2007 included a £240 charge for new spark plugs, though they clearly hadn't been changed since the car was built, given the state they were in in 2008. I fitted new plugs just after the first Cataclean treatment, which also made a noticeable difference.
- the car has been driven "as designed" all the time I've owned her, and been treated to premix, and for the last 8 years she's also had a sohn - all this means that there's very little opportunity for new carbon to get a hold.
My assumptions are;
- Been thanked: 332 times
I've used it on many cars
its hard to believe but it really does work and the dose is meant to be a full bottle in a 50ltr tank so bung the lot in
- Been thanked: 50 times
1/4 tank...15 l.
- Been thanked: 74 times
Had good results with CataClean
My method for use:-
Add cataclean when petrol light comes on and fill up with about a 5-10 quids worth of petrol
Drive like you stole it until petrol light comes back on
Add petrol and return to normal
My method for use:-
- Been thanked: 310 times
As above, follow the instructions on the bottle
Cataclean is a very good product for carbon removal on a Rotary and has been used for many years.
I would always run a bottle through after getting an 8 even if it was decated.
Just echoing above really, most members on here with sing the praises of cataclean for the RX8.
Bung it in at a 1/4 tank and go have some fun until you've nearly run out of petrol. Then put petrol in and live the dream.
If you've already got the petrol in the tank it will have been pre-mixed (if you premix of course) so I wouldn't worry
- Has thanked: 147 times
- Been thanked: 288 times
Yeah must get a few bottles of it,never used it before,can't get it over here so Amazon will have to come to the rescue...
Mods so far..
BBR 200 PACKAGE
COBRA " RACE " BACK BOX
MEISTER COILOVERS
DROPLINKS
Mods planned..
BBR STAGE 2 SUPERCHARGED
WILWOOD 6 POT BBK
FULL UNDRBODY SEAL
ATOTO HEAD UNIT
Mods so far..
BBR 200 PACKAGE
MEISTER COILOVERS
DROPLINKS
Mods planned..
WILWOOD 6 POT BBK
FULL UNDRBODY SEAL
ATOTO HEAD UNIT
It's usually available in Halfords.ie https://www.halfords.ie/motoring/engine ... lean-450ml# but currently out-of-stock
ECP have stock https://www.eurocarparts.com/en_ie/ecpi ... &0&cc5_169
Otherwise, these guys should point you to a local stockist https://www.qualvecom.com/products/cons ... n-reg.html
Cheers Dave,spotted it on Amazon for about 14 euros delivered which is a good price,I'll pick up a few bottles soon.
Seeing as I've never used it in my car can I expect a good result? By that I mean a noticeable difference?
Quick question,seeing as my cat is gutted I'm assuming this won't have any bearing on cataclean being able to do it's thang?
Mods so far..
BBR 200 PACKAGE
MEISTER COILOVERS
DROPLINKS
Mods planned..
WILWOOD 6 POT BBK
FULL UNDRBODY SEAL
ATOTO HEAD UNIT
Mods so far..
BBR 200 PACKAGE
MEISTER COILOVERS
DROPLINKS
Mods planned..
WILWOOD 6 POT BBK
FULL UNDRBODY SEAL
ATOTO HEAD UNIT
- Has thanked: 30 times
- Been thanked: 92 times
Make sure you use the fuel with the cataclean in it fairly quickly too, you don't want it sat around in the fuel system for too long, it's extremely aggressive solvents.
- Has thanked: 51 times
- Been thanked: 20 times
Ian , I certainly noticed a difference with Cataclean on my R3 ……
- These users thanked the author CLOVERLEAF159 for the post:
- kopite72 (Fri Mar 01, 2019 3:37 pm)
So it's fine to add in around 50ml 2T premix oil along with the entire bottle of Cataclean in the quarter 15 litre fuel?
Just use the cataclean
It's not a lot of fuel to run through the car it will survive without any 2T
Get the car warm first, add the cataclean and show her the beep
Going to give this a go tomorrow,see what all the fuss is about
Mods so far..
BBR 200 PACKAGE
MEISTER COILOVERS
DROPLINKS
Mods planned..
WILWOOD 6 POT BBK
FULL UNDRBODY SEAL
ATOTO HEAD UNIT
Mods so far..
BBR 200 PACKAGE
MEISTER COILOVERS
DROPLINKS
Mods planned..
WILWOOD 6 POT BBK
FULL UNDRBODY SEAL
ATOTO HEAD UNIT
- Has thanked: 5 times
- Been thanked: 28 times
and has it suddenly increased your compression? made it super fast or anything else
Bought it yesterday but haven't used it yet, working long days this week so won't get a chance til the weekend but I'll let the masses know as I know y'all be waiting with baited breath
Mods so far..
BBR 200 PACKAGE
MEISTER COILOVERS
DROPLINKS
Mods planned..
WILWOOD 6 POT BBK
FULL UNDRBODY SEAL
ATOTO HEAD UNIT
Mods so far..
BBR 200 PACKAGE
MEISTER COILOVERS
DROPLINKS
Mods planned..
WILWOOD 6 POT BBK
FULL UNDRBODY SEAL
ATOTO HEAD UNIT
