What is the purpose of this plug? + a request for bolts
- RX-8: Evolve
- Has thanked: 14 times
I was doing some maintenance today and came across this strange conector. It comes straight out of the loom and sits just below the SSV actuator, but the connector is just a bridge. What purpose could it possibly have? Is it meant to be connected to something and a previous owner decided not to use it so bridged it?
Also if anyone on here has any upper manifold bolts they dont need, please PM me as 2 of mine are absolutely sha**ed and I can't seem to find any, even when searching for the part number :/
Re: What is the purpose of this plug?
its factory, i believe it was for a connection that was removed in later cars.
- RX-8: Evolve
That is very perculiar isn't it. Just leaving a random plug in the engine bay. Mine is an 06 so not too new in terms of these cars
but new enough to have the updated inlet manifold etc.
- MX-3fan (Mon Jun 13, 2022 4:58 pm)
Post Sat Feb 05, 2022 4:59 pm
That's for the ssv some have plugs on, the others just have the loop
- Has thanked: 71 times
- Been thanked: 90 times
Re: What is the purpose of this plug? + a request for bolts
Would this have an impact on SSV operation if you swapped an older engine into a newer car keeping the newer cars wiring loom?
- RX-8: Evolve
My guess would be that this is a simple power and gnd which may have been needed for the oldest type of SSV so if you swapped to an older engine, the SSV would have a male plug to connect this to
- These users thanked the author MX-3fan for the post:
- untakenname (Thu Jun 16, 2022 9:11 am)
Some PCM loads support the MIL code P2070 [SSV stuck open] which uses a position sensor on the SSV.
If the SSV doesn't have the position sensor then the link plug prevents the MIL
- Milos_Balunovic (Thu Jun 16, 2022 11:35 am) • MX-3fan (Thu Jun 16, 2022 5:30 pm)
