Sandwich plate
- Has thanked: 35 times
- Been thanked: 73 times
Sandwich plate
Hi
Can anyone recommend a good quality sandwich plate for oil pressure and oil temperature gauges that will not leak.
Thanks mark.
Thanks mark.
Re: Sandwich plate
Saw the title and thought...
- These users thanked the author bigpete8 for the post:
- poor_lackey (Fri Nov 26, 2021 8:16 am)
Re: Sandwich plate
Give over you are making me hungry
- These users thanked the author Markl17 for the post (total 2):
- 30405 (Thu Nov 25, 2021 9:39 pm) • bigpete8 (Fri Nov 26, 2021 7:34 am)
- Has thanked: 113 times
- Been thanked: 158 times
Re: Sandwich plate
Just make sure it’s got decent O ring
Not a rubber gasket
Not a rubber gasket
- These users thanked the author mrspiller for the post:
- Markl17 (Fri Nov 26, 2021 6:15 am)
- Been thanked: 327 times
Re: Sandwich plate
No need for a sandwhich plate to install gauges
you can add a pressure tapping into the existing pressure switch port on a piece of hose to move it away from the engine
and modify an oil cooler bolt to screw the temp sensor directly into the back so you get oil exit temp of the engine
- These users thanked the author 350matt for the post (total 2):
- Markl17 (Fri Nov 26, 2021 6:14 am) • GrantRL (Wed Dec 01, 2021 4:59 am)
Re: Sandwich plate
Totally agree Matt350matt wrote:No need for a sandwhich plate to install gauges
I tried that F*** it up big time being an amateur
Re: Sandwich plate
That sounds better is there a thread on how to do this as it sounds perfect.350matt wrote: ↑Thu Nov 25, 2021 9:34 pmNo need for a sandwhich plate to install gauges
Thanks mark
Re: Sandwich plate
see here for modifying the oil cooler bolt
viewtopic.php?f=6&t=83250&p=1320884&hil ... t#p1320884
and note the issue with going too deep with a NPT tap, best off doing it a bit checking with your gauge sensor and then re-cutting deeper as required as the metal on machine is far harder to operate than the metal off machine
for oil pressure on mine I used a 3/8BSP Banjo bolt and -3 hose to take off from the oil pressure sensor port and then fitted a Tee Piece up by the washer bottle with the gauge sensor and original low pressure light sensor screwed into that
- Milos_Balunovic (Fri Nov 26, 2021 8:26 am) • Markl17 (Fri Nov 26, 2021 9:02 am)
- Has thanked: 410 times
- Been thanked: 91 times
Re: Sandwich plate
you can take the pressure also from a banjo bolt the one last in line before the engine. the oil temp should be measured before cooling not after. a temp sensor after cooler is measuring what the oil coolers are doing without knowing anything what is happening in engine.
Sandwich plate is very bad solution for our engines for temp sensing because of it (unless you have 2 temp sensors)
- These users thanked the author Milos_Balunovic for the post:
- Markl17 (Fri Nov 26, 2021 9:02 am)
- Sponsor Trader
- RX-8: Supercharged
- Been thanked: 110 times
Re: Sandwich plate
Here we go Mark,
We have in stock the Racing Beat adaptor and with hundreds sold never had an issue. Plus today you get a Black Friday discount .
https://www.racingbeateurope.com/racing ... 1274-p.asp
Hope this helps
Hope this helps
REgards
Clive
http://www.racingbeateurope.com
We aim to help and assist our customers make the right choices for their Rotary, whether they be standard or modified. If you need further assistance, please do not hesitate to contact us:-
sales@racingbeateurope.com or call 01474 777 800
Clive
- Forum Guest
- RX-8: Prospective Buyer
- Has thanked: 3 times
- Been thanked: 3 times
Re: Sandwich plate
Alright, we will try that when we start working on buddy's new RX8 project. We will just finish installing the suspension, headache rack and bakflip cover on the truck this week before we can take her in.350matt wrote: ↑Thu Nov 25, 2021 9:34 pmNo need for a sandwhich plate to install gauges
- Has thanked: 265 times
- Been thanked: 359 times
Re: Sandwich plate
I made a whole bunch of modified oil banjo bolts to take sensors (got a pair on mine for pressure & temp) that I sent to SmuttyHutty FOC so that he could dish them out to members as he pleases.
Instead, he just swiftly left the forum never to be seen again.
- These users thanked the author 13Black for the post:
- Milos_Balunovic (Wed Dec 01, 2021 7:26 pm)
Re: Sandwich plate
Before I buy this tap is it the right one for the sensors
Thanks mark
Re: Sandwich plate
From specs on page I would say that the one. You should be able to find it most tool stores local to you.
Dont forget don't cut the tread all the way through as its cone shaped. But cut and test with the sensor so its getting enough engagement. Noo need to have the whole threat in (few can be left exposed) as if there is no thread the "cone" will not be tight and wont seal ..
- Markl17 (Sat Jan 01, 2022 6:04 pm)
Re: Sandwich plate
Thanks,I have ordered it now I thought it was right but wanted to make sure,thanks for the advice,I have 4 spare bango bolts so it takes the pressure off.
Happy new year
Mark
Happy new year
Mark
- These users thanked the author Markl17 for the post:
- Milos_Balunovic (Sat Jan 01, 2022 10:36 pm)
