...still awaiting my wooden spoon for having the least WHP whilst an auto on the dyno day.
Let's say the auto box losses were greater than 15%.
220whp +
- RX-8: Import
- Colour: Black Cherry
- Been thanked: 119 times
Re: 220whp +
- Has thanked: 86 times
- Been thanked: 38 times
Re: 220whp +
One of the things on my list of things to diagnose and sort is also a cough/misfire always between 4-5k. Even on light/medium/full throttle I usually get this misfire, no fault codes but a repeatable misfire. Also a slight hesitation up around 8k. Mine is standard engine by the way but has been custom tuned with logs (it actually seemed to be start happening around the same time as tuning) so I wouldn’t just assume it’s a “Bridgeport thing” and go through the logical and systematic troubleshooting as anyone else would.osman wrote: ↑Fri Oct 01, 2021 2:13 pmThe car drives well, only real issue is the a misfire kind of feeling around 4-5k rpm mark that Bridgeports seem to make.
Done some gps runs using draggy for 100-200 kph and it's done it in 16 seconds gps
It's as fast as stage 2 mk6 gti,
Faster than full bolt on Mugen dc5 type r without a map
They do a calculation of hp x 1.15 to get the fly HP so around mid 250 range
Kuro 174/500.
RRP midpipe (single resonator) w/ Pettit/Milltek cat-back, RRP MK2 Coils and MSD leads, AEM Cold Air Intake, RRP Custom Map, Royal Steering Wheels custom wheel. Mazdaspeed bodykit, Team Dynamics Pro Race 1.2s, Smoked LED rear lights, Stoney Racing Hose Kit, Lots of red in the engine bay.
#174’s journey: viewtopic.php?f=104&t=78506
- Has thanked: 23 times
- Been thanked: 17 times
Re: 220whp +
LeeW wrote: ↑Fri Oct 01, 2021 7:44 pmOne of the things on my list of things to diagnose and sort is also a cough/misfire always between 4-5k. Even on light/medium/full throttle I usually get this misfire, no fault codes but a repeatable misfire. Also a slight hesitation up around 8k. Mine is standard engine by the way but has been custom tuned with logs (it actually seemed to be start happening around the same time as tuning) so I wouldn’t just assume it’s a “Bridgeport thing” and go through the logical and systematic troubleshooting as anyone else would.osman wrote: ↑Fri Oct 01, 2021 2:13 pmThe car drives well, only real issue is the a misfire kind of feeling around 4-5k rpm mark that Bridgeports seem to make.
That's what I've been told by rr, it's how the Bridgeport is cut
I've showed rr and they said it would take too long to fine.tune.it and remove it.
Mine only happens on light throttle, otherwise it's seemless throughout the rev range
- Events Team Member
- Has thanked: 507 times
- Been thanked: 453 times
Re: 220whp +
I also get a very slight hesitation on going through 4-5k rpm with my bridgeport on light throttle. It's not noticeable on medium/heavy throttle and therefore does not impact on track driving
Back on topic.....
Back on topic.....
