Fitting wheel spacers
- Been thanked: 28 times
So im going to fit some hub centric spacers this weekend. Is there anything specific i need to know? i.e locktight the nuts etc?
Re: Fitting wheel spacers
What size spacers?
Some spacers leave the ends of the original studs protruding in between their studs for the wheels.
This is fine if your wheels have recesses in the back between the stud holes.
Mazda used different suppliers for their wheels, which all look the same from the front but some have recesses, while some don't. Some cars even have a mixture of wheels.
If the stud end protrudes and you don't have recesses, then you either have to grind/cut/file the ends of the studs, or create recesses in the wheels to provide clearance.
- GreySilver Beast (Mon Sep 06, 2021 4:17 pm)
- Has thanked: 147 times
- Been thanked: 287 times
You'll be fine, I had 20 mil spacers on mine with no issues, just uee some copper grease on each stud and work away
im going to fit the rears first to see if there are any issues then order a front set
When I had my R3 the Studs for the Spacers had to be cut down to size to fit the R3 Wheels
I had 15mm on the back and 20mm on the front
- Has thanked: 25 times
- Been thanked: 96 times
Fit the open ended nuts from the spacers over the studs first and then cut with a cutting disc or a good hacksaw blade, file off the edges and then remove the nuts to repair the end of the threads. Just be aware if you then fit aftermarket wheels at a later date and they are thicker where the studs pass through, you might need to replace the studs to get enough thread engagement. Easy enough on the fronts but the rears require a press and new bearings.
- Club Chairman
- Has thanked: 52 times
- Been thanked: 298 times
Do the studs definately need cutting? I was hoping to put some on but dont want to cut studs. I was looking at freaky parts 20mm bolt on ones
It all depends on the wheels - the only way to tell is to pop them off (all of them, as they can differ as Dave mentions) and measure the depth of the recesses. Check this is greater than the stud length minus 20mm or whatever thickness spacer you are fitting.
- These users thanked the author Phil Bate for the post:
- DrewR3 (Mon Sep 06, 2021 5:23 pm)
The Freaky parts spacers that Smedley bought for his RX8 had screw in wheel studs as opposed to flanged splined studs which are found on other spacers. Apparently these screw in stud spacers have been used on numerous track cars without any problem.
It is vital however that the wheel nut torque specified by the supplier for the spacers is used if they are not flanged studs.
- Been thanked: 310 times
I'm not a fan of cutting the wheel studs as I've seen what some people have done to them and then fitted oem wheels without the spacer after.
It really is very easy to drill the recess in the back of the wheel slightly so the stud doesn't foul the wheel
- These users thanked the author Conan for the post (total 3):
- ChrisHolmes (Mon Sep 06, 2021 8:24 pm) • DrewR3 (Mon Sep 06, 2021 9:00 pm) • Milos_Balunovic (Sat Nov 06, 2021 9:10 pm)
Right. All fitted and much better looking. Drives well apart from uneven surfaces cause a bit of side to side diving under breaking.
Any idea why.?
Any idea why.?
- Been thanked: 330 times
Quite possibly there was a bit of geometry error before you fitted the spacers thats now being amplifed
get the car 4 wheel aligned I 'd say
by the way is there any handling benefit to fitting spacers or is it just for looks?
There was when I had them fitted to the R3, as it made the car feel tighter when corning on the track
- Club Chairman
What tyres have you got on? I got tramlining on Kumho Ecstas on my PZ. I do unfortunately have them on my R3 at the moment which is a different size and no issues this time. On the PZ though a quick tyre change and all was good
Wheel spacers, or aftermarket wheels with less offset, not only increase the track but they also move the contact patch further away from the (near) vertical axis that the hubs turn on while steering.
This means that tram-lining is increased, as the tyre now had more leverage.
It also slightly reduces the effective spring rate of the suspension, for much the same reason.
- New Duke (Sun Oct 03, 2021 9:02 pm) • Milos_Balunovic (Sat Nov 06, 2021 9:11 pm)
Adjustable drop links and a proper professional set up with a suspension specialist will sort all those issues.
And improve the handling beyond belief.
What Simon said above.
I don’t have any “wandering” issues with my set up.
I have 20mm spacers all round, 245/35 tyres all round adjustable drop links seized so they are what they are, alignment by traditional string method at F W Motorsport for fast road / track use.
- Has thanked: 33 times
- Been thanked: 22 times
Who else runs spacers on track?
I’m running 20mm Eibach hubcentric spacers front and rear.
When/how often do you check the torque on these? I haven’t touched them since they went on a few years back.
2006 Galaxy Grey 231
Nankang NS-2R | Eibach Pro-Kit Springs | Eibach 20mm Spacers | EBC Discs + Bluestuff Pads | Racing Beat REV8 Catback + High Flow Cat | BHR Ignition | K&N Filter | Koyo Rad | Mishimoto Thermostat | Greddy Sump with ER Lines | Lockwood Grills
I run the same setup and have always found the nuts tight when checked.
- bc-49 (Sun Nov 07, 2021 10:19 am)
