Coolant Puddle Passenger Footwell
- Has thanked: 451 times
- Been thanked: 202 times
As the title says, I've discovered a large pool of coolant (judging by the taste) in the passenger footwell, which I can only assume is a leaking heater matrix.
So.... how much of a bitch is it to replace, assuming it is replaceable?
Additionally, I think I will probably be putting the car up for sale once this issue is fixed - it's passed my threshold of patience, though ironically I've not had a single problem with the engine (it has performed faultlessly!). Of course, that view will change if sorting out this heater issue isn't the end of the world.
Re: Coolant Puddle Passenger Footwell
It could be the matrix, or it could just be a hose.
What it won't be is the heater control valve, as the RX-8 always runs the coolant through the matrix, and controls cabin heat with the airflow, unlike many early cars that would control the coolant flow, via a valve that often seized/leaked.
Also double check that it isn't screen wash, or a/c condensate.
- rotatopotato (Tue Jun 01, 2021 3:56 pm)
A/C is dead/disconnected so definitely not that. Screen wash Reservoir hasn't dropped enough to account for the volume of water, and I forgot to mention the coolant level does appear to have dropped. I've had a sloshing noise on and off when starting the car since owning it, so I guess air has been getting in for a while. Its possible this has been happening steadily for a while and I haven't noticed it.
If it's a hose, do you mean a hose coming into the cabin to the matrix? Can I get at them to check without a full dash disassembly?
- Has thanked: 173 times
- Been thanked: 172 times
It's a pig of a job to do either and yes the dash has to come out.
- rotatopotato (Tue Jun 01, 2021 5:57 pm)
I had a feeling that might be the case
Any recommendations for an RX-8 friendly mechanic in/near Glasgow? I think I've reached the end of my tether of constantly fixing problems and I'm not keen on trying to sell it as-is!
If you're not apart of the RX8 Scottish Owners club FB page. I'd ask on there for a bit of a more local idea. I know that Ben Taylor on there use to live near Glasgow and does mechanic RX8s. If not then someone else might be able to point you elsewhere.
- rotatopotato (Tue Jun 01, 2021 6:10 pm)
Cheers, I'll blow the dust off my fb login and join them to see what I can find
I'd only ever use something like that if I were stranded and it were the only option - those products ultimately ruin your cooling systen/engine.
- Been thanked: 50 times
k seal in my experience is wonderful stuff that will fix most leaks...ive been using it for years with no short or long term problems.
- These users thanked the author xamtex for the post:
- rotatopotato (Wed Jun 02, 2021 3:21 pm)
- Been thanked: 332 times
that is the case wth some of them I would agree ( rad seal)rotatopotato wrote: ↑Wed Jun 02, 2021 9:42 amI'd only ever use something like that if I were stranded and it were the only option - those products ultimately ruin your cooling systen/engine.
however k-seal has no ill effects and I've used it many times
OK, K Seal does appear to be a bit different from the usual stop-leak sh*t that fills your cores/galleries with mush. I'm still a bit hesitant to use it, but if there really is no long term issue then I guess it can't hurt to try. I see a few heater cores were blocked on the amazon reviews, I'm guessing they didn't open their heater up while running (and yes I know we don't need to turn our heaters on as coolant is always flowing through). There are also just as many/more people saying it fixed their heater core.
i left water in my suzuki offroader over winter and put a 9 inch long crack in the block across the core plugs...put k seal in and i ran it hard overheating it on a regular basis and it was still sealed 3 years on when i sold it...its in norway now and as far as i know its still ok.
- rotatopotato (Wed Jun 02, 2021 9:12 pm)
I've given K Seal a go - replaced the coolant bottle at the same time with one that has a working level sensor. No dice, still droplets hitting the passenger side carpet running up the back length of the centre console.
Going by some of the reviews for K Seal I've ordered a second bottle to see if thats the extra help it needs, otherwise back to square one.
Cheers for the recommendation/reviews folks.
it will take a some time for the K-seal to work I've found you have to run the engine with the leak for at least 30 mins once its at temp
- rotatopotato (Sun Jun 06, 2021 10:34 am)
Aye that'd be at least how long I ran it yesterday, including a drive with several beeps. Hopefully it is just a delayed effect, really not keen on taking that all apart
So still a piddle?
I've found that 2-3 drive cycles are needed to form a reliable seal.
- rotatopotato (Sun Jun 06, 2021 10:30 am)
Aye, it's just the odd droplet while running, though I haven't checked what it's like this morning - i remember from my youth having coolant leaks that piddle while running and then dump once the car shuts off and the pressure drops (or maybe it peaks for a moment when the engine is shutoff and the coolant stops circulating?).
I'll give it a few more runs and dump in the second bottle of K Seal, see where I get to. It certainly seems like the kind of leak K Seal should handle judging by the reviews, as I say it's just droplets.
Second bottle doesn't seem to be necessary, some more driving and the drips appear to have stopped. Hurrah K Seal!
