Old member after R3
- Has thanked: 15 times
- Been thanked: 13 times
Old member after R3
Hi all! I am in the market for an R3. Currently looking at one that Kent Rotaries have for sale, compression test has just been under taken by The Performance Shop results coming in at:
Front 6.3-6.0-6.1
Rear 6.2-6.4- 6.1
Crank 250
Apparently this R3 has been last owned by club member, private plate RX08 RAG in red.
I've been away from the club for years now and can't really remember how these numbers stack up, maybe a little on the border line.
Any advise would be much appreciated.
Looking forward to rejoining the club!
Darren
Front 6.3-6.0-6.1
Rear 6.2-6.4- 6.1
Crank 250
Darren
- These users thanked the author DJonesy for the post:
- Richrx (Sat May 08, 2021 3:18 pm)
Old member after R3
Hi Darren & back to the RX-8OC
- DJonesy (Sat May 08, 2021 4:24 pm)
- Has thanked: 53 times
- Been thanked: 76 times
Re: Old member after R3
Yeah the numbers are borderline, but the wear is reasonably even too. Depends on the price, but even with those numbers, you should get a good few miles out of it
- These users thanked the author Scartlead for the post (total 2):
- Richrx (Sat May 08, 2021 3:18 pm) • DJonesy (Sat May 08, 2021 4:25 pm)
- Has thanked: 566 times
- Been thanked: 520 times
On autotrader - 46,418 miles at £6,995 for that compression... it can be a good car, and as said above, the compression is very even so that's a good thing - although it is on the lower side of things, still ok numbers. Just depends on what you're comfortable paying for it, I'd probably be wanting to be lower than the asking, but then again we can all say that one hah!
Does look a tidy car though, so definitely a good contender
- Has thanked: 98 times
- Been thanked: 9 times
At them compression figures what kind of milage is he likely to get before rebuild ?
I know it's hard to say but around ? We talking 1000s or 10000s of thousands ? I've drove a few with them compression results drove/started perfectly
- These users thanked the author YORKSHIRE777 for the post (total 2):
- Has thanked: 19 times
My honest thoughts as a prospective Rx8 owner/serial Rx7 owner would be that's priced high for my liking with low 6 compression. 8's being a new engine. 5 being rebuild stage it's obviously now at the lower end of the scale.
The readings are quite low for the mileage on the engine too which shows possible lack of correct oil etc in it's past at some stage.
If it was be buying the car I would be prepared to rebuild in 10/15k.
All based on my own opinions of course.
But if your asking nthe question I guess the doubt is there.
Rich
Rich
- Been thanked: 2080 times
It could have just been driven wrong, holding the revs low by changing up too soon, causing a build-up of carbon and reducing the measured compression.
If this is the case then an "Italian Decoke" followed by a few more miles driven properly might be all it needs to get those numbers back up in the green, as many on here have proved.
- These users thanked the author warpc0il for the post (total 3):
- YORKSHIRE777 (Sat May 08, 2021 11:56 am) • Richrx (Sat May 08, 2021 3:18 pm) • DJonesy (Sat May 08, 2021 4:25 pm)
This is what I was thinking after reading that quite a few have had compression tests of 6s then after driving it as should a later compression test in 7swarpc0il wrote: ↑Sat May 08, 2021 11:49 amIt could have just been driven wrong, holding the revs low by changing up too soon, causing a build-up of carbon and reducing the measured compression.
- These users thanked the author YORKSHIRE777 for the post:
- Richrx (Sat May 08, 2021 3:17 pm)
- Colour: Diamond Grey
- Has thanked: 52 times
- Been thanked: 31 times
When I first tested my R3 one chamber reading was low at 5.9 and the others were mid to high 6's. It was suggested to drive it hard as it could be just a build up from the previous owner.
I drove it hard and subsequent testing each year showed improvements of high 6's and 7s.
It was 3 years before a side seal actually went after approximately 20k miles and numerous trackdays.
- These users thanked the author Mpv2k3 for the post (total 3):
- YORKSHIRE777 (Sat May 08, 2021 1:14 pm) • Richrx (Sat May 08, 2021 3:17 pm) • DJonesy (Sat May 08, 2021 4:25 pm)
- Been thanked: 327 times
I'd get the price down using that compression figure as a bargaining point say £5500 ? as a decent rebuild is 2K at least
I think it's interesting to hear of such a big swing in compression numbers and for some could make the risk of certain cars worth while, given the right price ? Although with this example £7k is alot to gamble on.
The only figure we have is compression in the low 6's. It might come up or it might not.
Darren, what are you thinking of doing?
Rich
Rich
- These users thanked the author Richrx for the post (total 2):
- YORKSHIRE777 (Sat May 08, 2021 4:04 pm) • DJonesy (Sat May 08, 2021 4:24 pm)
- Has thanked: 23 times
- Been thanked: 32 times
We also don't know how she starts. If she starts on the nose, hot or cold then I'd be less concerned.
Also if the prospective owners mileage is only going to be 2/3k per year, it might be a good 5/6 years before there is even a chance of a rebuild.
I'd go and see the car, if it all adds up then see if you can get a good deal. Only you will know if its worth walking away from.
- These users thanked the author Jester* for the post (total 2):
- Richrx (Sat May 08, 2021 3:17 pm) • DJonesy (Sat May 08, 2021 4:25 pm)
Mazda RX8 R3 - Aurora Blue
Mini Cooper S - Dark Silver
Thank for your responses
I’ve just brought today an R3 from Nick from Enjoyable Cars in Berkshire in Sparking black.
Compression in the high 6’s low 7’s.
Just driven it back to the West Midlands (in heavy rain) and its perfect! It’s great to be back!
I have rejoined the club sent my PayPal payment yesterday morning just still awaiting for admin to upgrade my account which will hopefully be soon
Ill update my avatar etc soon and say hello in the “i’m new year pages”
Looking forward to meeting up with people again
Cheers
Darren
Cheers
Darren
- These users thanked the author DJonesy for the post (total 9):
- GreySilver Beast (Sat May 08, 2021 3:44 pm) • Richrx (Sat May 08, 2021 4:03 pm) • YORKSHIRE777 (Sat May 08, 2021 4:03 pm) • Jester* (Sat May 08, 2021 4:07 pm) • nightfire10 (Sat May 08, 2021 4:17 pm) • v-rex (Sat May 08, 2021 4:35 pm) • MARKTHOMASBRAND (Sat May 08, 2021 8:45 pm) • New Duke (Sat May 08, 2021 10:35 pm) • HarSc (Sun May 09, 2021 6:57 am)
I literally hate you. It looked an excellent car. Sounds like a better place to start from compression wise..DJonesy wrote: ↑Sat May 08, 2021 3:43 pmThank for your responses
Cheers
Darren
Time to get out enjoying it. And photos are also a welcome addition to the thread
Rich
- Been thanked: 323 times
Always good to sell a nice example to someone who is going to look after it well
- These users thanked the author Nickp47 for the post (total 2):
- DJonesy (Sat May 08, 2021 4:33 pm) • GreySilver Beast (Sat May 08, 2021 5:13 pm)
- Has thanked: 301 times
- Been thanked: 253 times
- These users thanked the author MARKTHOMASBRAND for the post (total 2):
- DJonesy (Sat May 08, 2021 8:48 pm) • GreySilver Beast (Sun May 09, 2021 2:04 am)
- Forum Administrator
- Has thanked: 47 times
- Been thanked: 155 times
All done for you Darren, that looks like a keeper right there.
- These users thanked the author brix79 for the post:
- DJonesy (Sun May 09, 2021 5:38 am)
Forum Admin Team
Forum Admin Team
Photos credit to Nickp47
- These users thanked the author DJonesy for the post (total 3):
- 30405 (Sun May 09, 2021 1:23 pm) • MARKTHOMASBRAND (Sun May 09, 2021 5:13 pm) • GreySilver Beast (Sun May 09, 2021 9:30 pm)
2010 R3, Toyosport high flow, Racing big Brake kit, K&N panel filter - sold
2004 (53) 231 Winning blue - sold / gone
She's a beaut
Uprated discs/calipers too
- DJonesy (Sun May 09, 2021 5:49 pm)
Yeah, looks a lovely car! Nick always seems to manage to dig out the good examples Nice plate too, you keeping that bad boy on?
- DJonesy (Mon May 10, 2021 12:50 pm)
Old member after R3
Wow looks in pretty good shape
Loving it!!
Rich
Rich
- These users thanked the author Richrx for the post:
Old member after R3
Darren you car is now registered on our club list over here : What colour's your R3???? Colour and name only.....
Yes
Thank youGreySilver Beast wrote: ↑Mon May 10, 2021 12:22 pmDarren you car is now registered on our club list
