Turbo kit
- Been thanked: 169 times
Turbo kit
Just thought I'd post up some progress here:
- These users thanked the author MadTaz for the post (total 3):
- HarSc (Sun Apr 04, 2021 5:29 pm) • New Duke (Mon Apr 05, 2021 6:27 pm) • wreeve (Sat Sep 11, 2021 4:15 pm)
- Been thanked: 331 times
Re: Turbo kit
good looking manifold
what turbo are you thinking to with it ? Borg warner EFR range ?
- Been thanked: 47 times
Re: Turbo kit
Where did you get the design from and what is it made of?
Ian
Re: Turbo kit
Isn't that RRPs take on the manifold for a turbo?
- Has thanked: 319 times
- Been thanked: 257 times
Re: Turbo kit
Well
That's Carl Ryan in the avatar above
- PaulAV (Mon Apr 05, 2021 10:08 am)
Re: Turbo kit
There's a chap on the US forum who's done a low mount turbo kit and interestingly enough he's only fed the outer ports to the turbo and the centre ports are plumbed to the seperate wastegate
looking at his dyno graphs he's gotten a good result
hmm now I've read his latest results he's gone away from that design mind you his power figures are with 40 % ethanol and off the mazda edit power reading so not a 'real' dyno
Re: Turbo kit
The US have the advantage that they don't have the steering column getting in the way. BTW which thread is that? I had a quick look on RX8club and couldn't find it. I used to spend a lot of time on the major horsepower upgrades and engine swaps threads but am a bit out of touch now.
Ian
Re: Turbo kit
its the adventures of Brettus
https://www.rx8club.com/series-i-major- ... 81/page91/
a very inventive chap
Re: Turbo kit
and his dyno pull on pump gas ( as they say)
Re: Turbo kit
Brettus? I know him and his previous projects well. He’s in NZ and has the same RHD restrictions as us.
His manifold looks interesting. The manifold’s dynamics for the turbo and wastegate are not for purists, forced by the cramped available space, but it seems to be working well enough for him despite all the inefficiencies and flow restrictions.
Although all dyno results should be taken with suspicion over the parameters used, that looks impressive. I wonder how responsive it is on the road and whether the wastegate’s position will make it slow to affect over boosting. On a wider point, I’m wary of a turbocharged Renesis’s ability to last before going bang and at that power level I’d much rather spend time and effort on a 13B REW conversion, but then I don’t have his skill, enthusiasm and resources.
Carl’s design doesn’t have the wastegate port, so he must be looking at an internal wastegate turbo.
Ian
Re: Turbo kit
another big difference is the Brettus design is for a twin scroll turbo so the small scroll is fed all the time and the large scroll is on the wastegated side
I suspect this is the main reason for the healthy low speed torque its showing
but yes I feel a 400Whp renesis is either a consumable or its been built for boost with 3mm apex seals etc
Re: Turbo kit
I’ll have a look at his thread later on my PC so I can see what he’s doing.
For now, be careful of applying info on twin scroll turbos without allowing for the peculiarities of Wankel engines. Each scroll must have a wastegate, so the 2 turbo ports must be interconnected (I cant see well enough on my phone to check). That must reduce the impact of the twin scroll, although spool times will still be an improvement.
Ian
Re: Turbo kit
I had a quick look at the latest page. It has a discussion on Carl’s set-up. They don’t like it and have alternative suggestions.350matt wrote: ↑Mon Apr 05, 2021 11:47 amits the adventures of Brettus
Ian
Re: Turbo kit
well the the two scrolls are connected via the siamesed centre port so both rotors are plumbed to the wastegate just not via the same pointWildMan10 wrote: ↑Mon Apr 05, 2021 2:17 pmI’ll have a look at his thread later on my PC so I can see what he’s doing.
looks like he's also on a 4 port engine
the dyno plots ( now a real dyno) do look good
- Has thanked: 18 times
- Been thanked: 34 times
Re: Turbo kit
I've been watching this progress since it broke cover on the Boosted Renesis Facebook page. That was a err, interesting post.
Curious to see how an internally gated turbo will cope.
Already have a friend lined up to knock up a top mount turbo manifold and downpipe. Even after being told several times that "Top mounts are only there for bling" I don't understand paying thousands for a turbo system, to then hide it.
HX35, 16cm housing and a big external gate. Attempting to route it without cutting up any engine mounts or removing the OMP like certain American solutions.
Re: Turbo kit
Love the love on this, always haters out there and the Rx8club is the worst of them all. If you're not in the click then......
Well I think they are missing the point we arent aiming for maximum power, 330-380whp will be just fine and this set up will be more than capable.
The idea being quick spool, and a good mannered road car, not a drag or race car.
As for the turbo, its a very capable turbo which retails at £1900, comparing to Greddy which flows quite a bit less is, well, a bit silly..
It won't be long I'll just let the results do the talking when its ready.
- These users thanked the author MadTaz for the post (total 6):
- MARKTHOMASBRAND (Mon Apr 05, 2021 9:47 pm) • HarSc (Mon Apr 05, 2021 9:53 pm) • ChrisHolmes (Mon Apr 05, 2021 10:25 pm) • New Duke (Tue Apr 06, 2021 2:56 am) • Elmotheewokking (Tue Apr 06, 2021 12:12 pm) • Luke0611 (Wed Apr 07, 2021 10:56 am)
Re: Turbo kit
Greddy vs XONA
- These users thanked the author MadTaz for the post:
- Frostorm (Wed Apr 07, 2021 11:42 am)
- RX-8: Prospective Buyer
Re: Turbo kit
Hey, I noticed on the kit's product page that it utilizes a Xona XR5448. I would strongly recommend choosing a UHF model from the Xona range instead (i.e. models that end w/ "S"). I believe that would be the XR5451S. It should help reduce backpressure and improve spool at the same time. The UHF turbines are kind of Xona's "thing", so it'd be quite the missed opportunity not using their new turbine design, imo. Looking forward to the results!
Re: Turbo kit
I thought I'd add a little more information to this for following this thread with interest;
So the Greddy kit I believe used the the TD06-18g the TD06 housing with 18g compressor wheel, this turbo flows 685CFMs which is broadly calculated to 46.5Lbs/min. The Xona for comparison flows 54lbs/min so c15% more than that of the Greddy. The Greddy TD06 while a great turbo is pretty old hat these days and turbo technology is moving so fast, we bought our X2C 5448 over a year ago and that now has been superseded in the Xona range.
Lucky for us though there are plenty of turbos to choose from which are dimensionally identical to one another (same compressor and exhaust housings) so we will be able to offer more choice for your needs.
I still believe the 5448 (5451s new turbo) will make a nice mannered road car, spooling very early and producing 330WHP, this will become our benchmark, in addition to this we will be running the kit with the 7864s (largest in the range) which flows a whopping 78lbs/min, this turbo also boasts the new UHF turbine. (again all this was not available when we bought the original turbo.) It will not spool as fast as the 5448 but it'll certainly give a bit more power mid to top end and reach c370WHP pretty easily.
The issue is when you start to go too big and powerful then you have to start introducing more supporting modifications, meth injection etc. The idea behind the original concept was to deliver an OEM+ style kit with drivability at the heart. The Greddy nearly did it but was let down by quite a few area including:
Manifold Design - Cracks
Turbo choice - was a little too small and had a narrow efficiency band, although has achieved 290Whp on some modified set ups. (so I hear)
Intercooler - restrictive and certainly not optimal, reports of quite a pressure drop across it.
Filter location - Inside the engine bay which is not ideal.
We have some neat features for out intercooler design and something not seen in the Rx8 market before, the demo car will be off the fabricators in 5 weeks for a full kit out of the prototype, this is going to be something special!
Now for anyone wanting silly power then perhaps a twin turbo REW swap (our latest development)
- These users thanked the author MadTaz for the post (total 4):
- ChrisHolmes (Tue Apr 06, 2021 10:49 am) • Nanotrox (Tue Apr 06, 2021 12:25 pm) • Luke0611 (Wed Apr 07, 2021 10:56 am) • Frostorm (Wed Apr 07, 2021 11:41 am)
Re: Turbo kit
Hello BrettFrostorm wrote: ↑Tue Apr 06, 2021 9:03 amHey, I noticed on the kit's product page that it utilizes a Xona XR5448. I would strongly recommend choosing a UHF model from the Xona range instead (i.e. models that end w/ "S"). I believe that would be the XR5451S. It should help reduce backpressure and improve spool at the same time. The UHF turbines are kind of Xona's "thing", so it'd be quite the missed opportunity not using their new turbine design, imo. Looking forward to the results!
- These users thanked the author MadTaz for the post (total 2):
- ChrisHolmes (Tue Apr 06, 2021 10:49 am) • Frostorm (Wed Apr 07, 2021 11:42 am)
Re: Turbo kit
Heh, I'm actually not Brett. But I got the link from his thread... Btw, why the decision to go with IWG instead of EWG? Can't wait to see how this turns out...5 weeks can't come fast enough haha.MadTaz wrote: ↑Tue Apr 06, 2021 10:33 amHello BrettFrostorm wrote: ↑Tue Apr 06, 2021 9:03 amHey, I noticed on the kit's product page that it utilizes a Xona XR5448. I would strongly recommend choosing a UHF model from the Xona range instead (i.e. models that end w/ "S"). I believe that would be the XR5451S. It should help reduce backpressure and improve spool at the same time. The UHF turbines are kind of Xona's "thing", so it'd be quite the missed opportunity not using their new turbine design, imo. Looking forward to the results!
- Has thanked: 694 times
Re: Turbo kit
Nice overview Carl. Your plans sound right up my street.
I've seriously considered FI in the past but aside from yours and SAS' supercharged cars every other one I've seen has had ongoing issues at great cost, and long periods in the workshop. Particularly the turbo ones. A testament to you and SAS doing it right I'm sure.
Personally I couldn't give a toss about a peak dyno readout. All I'd want is increased performance from stock, without having to wait an age for the turbo to kick in and minimum mods required. With some semblance of reliability. So this sounds the best approach for me I've seen so far. Will keep my fingers crossed on the cost (and that it'll work on an R3)
- These users thanked the author New Duke for the post (total 4):
- GreySilver Beast (Wed Apr 07, 2021 12:42 pm) • MightyCondor (Wed Apr 07, 2021 1:09 pm) • MadTaz (Wed Apr 07, 2021 1:15 pm) • geofftl1000r (Thu Apr 08, 2021 12:45 pm)
- Been thanked: 28 times
Re: Turbo kit
So when we pop round for an engine rebuild how much extra is this going to cost us? Im hoping for 500 quid
Re: Turbo kit
The turbo alone costs £2k
I really hope they can find a way to do it for £5-6k and it still be worth their while. If that's an 'all in fitted' price, and doesn't require a fresh rebuild, then I think it would be a very competitive offering. That may just be wishful thinking on my part though. I was quoted double that by a motorsport company for a custom turbo fitted to my R3 a couple of years ago.
- Has thanked: 48 times
- Been thanked: 60 times
Re: Turbo kit
Surely you're not trying to retain the OEM twin turbo setup? From what I gather, there isn't space in the RX-8s engine bay.MadTaz wrote: Now for anyone wanting silly power then perhaps a twin turbo REW swap (our latest development)
Interested to see how your plans develop though, as I really want to do this at some point and would love to see a viable offering
Sent from my IN2013 using Tapatalk
The new 2022 Rotary Fleet - RX-8 PZ - Purple Helmet Warrior
Previous Threads:
2004 Sunlight Silver 231 Impulsive Panic Buy Rotary Shed - Sold & lesser seen RX-7 FD3s - R.I.P.
2005 Winning Blue 231
Previous Threads:
