Hi. I've got a seal in my caliper rebuild kit that I can't find a location for.
https://photos.app.goo.gl/1zDniEatJaavPY3B6
Any ideas?
I've got the 2 pin boots, piston seal and boot oring for the handbrake mech and boot fir the handbrake mech.
So I'm bit stuck really.
Seal in rear brake caliper rebuild
- Been thanked: 283 times
Re: Seal in rear brake caliper rebuild
If Im not incorrect (which I maybe Im not entirely sober...) that seal you should have 2x of? If thats the case then its one that fits to the rear calliper after you've wound the piston out.. That bit was a bit too complicated for me so I left it how it was when I dissassembled my spare calliper set.
- Been thanked: 28 times
Yup back of the piston. Cheers folks.
- These users thanked the author AndyBrad for the post:
- SmuttyHutty (Sun Mar 28, 2021 1:02 pm)
just following on from this. whats this anti rattle clip for on the front?
https://photos.app.goo.gl/6kzyNUEcxH2DP16o8
Poss a wear clip? i cant find its location thats for sure.
- Has thanked: 252 times
- Been thanked: 206 times
The square part should sit in the channel where the brake pad goes.
like so?
https://photos.app.goo.gl/cWXM9Gxza9jfiF4e7
ive never seen these clips before when ive replaced pads etc.
yup its a wear indicator. not an anti rattle sprint as thought. ill be leaving those off.
So managed to get everything swapped over this weekend. Fairly straight forward and the DIY tutorial on here was great. Many thanks for that.
https://photos.app.goo.gl/nvKu88CFNwxBrQhb9
Let me know of anyone wants a set of calipers cheap to refurb.
The seal kit pistons and all bits were from frentech and were of good quality. Only thing to note is the bolt heads on a lot of the bolts were the next size down from the original ones.
- Forum Administrator
- Has thanked: 47 times
- Been thanked: 155 times
This is my next job, refurbing the front calipers. Kit is BrakeParts/Budweg though, pistons are BiggRed. Even replacing the clips..
Forum Admin Team
Forum Admin Team
