Anyone Know What this Is?
- Has thanked: 170 times
- Been thanked: 115 times
it looks like it's sheared off somewhere? can't see where and it's really firm can't move it? dunno if it's something of concern or not? car turns etc fine
Lightened and balanced rotors
Pettit Catback
Exedy Clutch
CC Ultra Lightweight Flywheel
CC Counterweight
Tein S.Tech Lowering Springs
Racing Beat Ram Air Intake
Footwell LEDs
Pettit Catback
Exedy Clutch
CC Counterweight
Footwell LEDs
Re: Anyone Know What this Is?
That looks like the front headlight auto adjustment linkage
- These users thanked the author deekhubert for the post:
- Nanotrox (Fri Jan 08, 2021 1:57 pm)
- Has thanked: 116 times
- Been thanked: 78 times
Yup it’s for the automatic headlight adjustment on the rear if I’m not mistakendeekhubert wrote:That looks like the front headlight auto adjustment linkage
- These users thanked the author Pippypip for the post:
- Nanotrox (Fri Jan 08, 2021 1:58 pm)
Thanks everyone! is it just a case of buying a new bracket and fixing it on to fix it?
Pettit Catback
Exedy Clutch
CC Counterweight
Footwell LEDs
Pettit Catback
Exedy Clutch
CC Counterweight
Footwell LEDs
Yeah you can or you can do what the previous owner of my first Rx8 did and stick it back together with sealantNanotrox wrote:Thanks everyone! is it just a case of buying a new bracket and fixing it on to fix it?
The bracket probably broke because the sensor seized, so you'd need the complete assembly.
#FE03-51-22YC @ £345.80 plus VAT
There was a design change in 2006, so a used one from after that date should be fine.
donor car needs to be VIN later than SE17**-145228
- Nanotrox (Fri Jan 08, 2021 2:08 pm)
Check with Honkytonk as he may have a spare on a subframe he got from me recently.
I don't think it will bother me for £345 hahah I didn't even know we had auto levelling headlights to begin with thanks for the info tho will be helpful for finding one off a scrap car!warpc0il wrote: ↑Fri Jan 08, 2021 2:01 pmThe bracket probably broke because the sensor seized, so you'd need the complete assembly.
Will send him a message and see, thanks!ChrisHolmes wrote: ↑Fri Jan 08, 2021 2:05 pmCheck with Honkytonk as he may have a spare on a subframe he got from me recently.
Pettit Catback
Exedy Clutch
CC Counterweight
Footwell LEDs
Pettit Catback
Exedy Clutch
CC Counterweight
Footwell LEDs
- Has thanked: 66 times
That link is a mot fail. Mine snapped and it was picked up during the mot. Got it replaced there and then to pass the mot.
- These users thanked the author delta0 for the post:
- Nanotrox (Fri Jan 08, 2021 10:24 pm)
RX8 R3 Aurora Blue Mica
I certainly should be "an MOT fail" but I suspect, if you removed the section that's swing around, you'd get away with it.
The levelling system does look for movement as part of its test, so no error lights, and as long as the sensor is fixed in a reasonable position, then the result should be okay for the dipped-beam check.
It would take a tester with a lot of experience and specific model knowledge to recognise that there should be a link on the rear as well as the front.
Not that I'd advise driving the car in this condition, in fact, if Honkytonk doesn't have one then I'd be recommending a call to Bigpete.
Trying to get a hold of one now, is it pretty straight forward to replace it's on the front passengers sidewarpc0il wrote: ↑Fri Jan 08, 2021 8:58 pmI certainly should be "an MOT fail" but I suspect, if you removed the section that's swing around, you'd get away with it.
Pettit Catback
Exedy Clutch
CC Counterweight
Footwell LEDs
Pettit Catback
Exedy Clutch
CC Counterweight
Footwell LEDs
The part # I quoted is for the rear, though the front is similar.
Anyone breaking a 231 is likely to have a working one.
- Nanotrox (Fri Jan 08, 2021 10:36 pm)
- Has thanked: 25 times
- Been thanked: 96 times
I looked for these a while back once rockauto's stock dried up and it seems they were common across manufacturers at some point. Plenty of places list pattern parts with cross-compatibility - has anyone tried one yet?
https://www.ebay.co.uk/itm/Fits-Mazda-R ... Sw9L1fvn5i
Who'd have known our cars have something in common with a Prius!
Edit - obviously this is just the potentiometer not the arm and bracket, and might not fit the newer models depending on what changed
Headlight auto-levelling systems always use a front and rear sensor... This isn't model specific...
A car cannot level the headlights on a front or rear sensor alone as it calculates the differential between front and rear to judge the attitude of the car...
