R3 Sohn
- Has thanked: 17 times
- Been thanked: 7 times
R3 Sohn
Hi have travelled far around this forum, and have not long since found that my Sohn adaptor is useless on a R3....but there doesn't seem.much info as to why. AWould I be right in saying that the 2 "pumps" are just regulators of the engine oil pressure to take a feed for the oiling pipes/ points, which is why it's a lot more difficult to get 2t into it than it is with the Sohn Adaptor? Has anyone succeeded in getting a 2t feed to the oilers onna R3? Thanks, Ben.
Re: R3 Sohn
The R3 has an electronic metering pump rather than a mechanical, as such detangling it all from the ECU and the engine is incredibly difficult/ not worth the aggro, so just splash some 2T in the tank and live free and easy.
- These users thanked the author Dr. FrankenRex for the post (total 2):
- tsouthern (Mon Dec 14, 2020 8:13 pm) • Freddie (Mon Dec 14, 2020 10:12 pm)
- Former Trader
- RX-8: Supercharged
- Has thanked: 46 times
- Been thanked: 153 times
Re: R3 Sohn
It can be done:
- Block off and recycle sump feed.
-re-route feed to a 2t tank
-install a low pressure pump with a blow off feed back to the 2t tank.
- These users thanked the author Ryan Rotary Performance for the post (total 2):
- Freddie (Mon Dec 14, 2020 10:11 pm) • Milos_Balunovic (Sun Dec 05, 2021 10:15 pm)
Carl
Carl
Re: R3 Sohn
Thanks for the replys guys....I do put 2t in the petrol tank, but my mission to have a 6 figure engine needs engine oil and seal lube seperated ( my OCD does too) it looks as if the two pps are in series and have a single feed and a return. Sure those two cd be linked to a pump and return to a 2t tank, but would not the pumps pressure relate to the amount of 2t getting to the seal injectors?
Re: R3 Sohn
Thanks for the replys guys....I do put 2t in the petrol tank, but my mission to have a 6 figure engine needs engine oil and seal lube seperated ( my OCD does too) it looks as if the two pps are in series and have a single feed and a return. Sure those two cd belinked to a pump and return to a 2t tank. Are the black solenoid looking parts the electronic pumps? If so, shdnt it be relatively easy to get a 2t feed and return on there ?
Re: R3 Sohn
Think it's one of the biggest mode.....engine oil really wasn't designed for injection....plus the oil innthensump can never be 100%clean.
- Been thanked: 28 times
Re: R3 Sohn
if thats the case why hasnt ryan rotary developed one? they seem to be quite good at this stuff #:)
Re: R3 Sohn
Not enough profit for a small subsection of the RX jenre? Plus, it's not an easy fix like the Sohn.
Re: R3 Sohn
Not necessarily. It's a well trodden topic. It's debatable whether it's even a money saver on S1 RX8s, once you take into account the cost of the mod and the oil over x time period. I think that more beneficial on an R3, if an owner is worried, would be checking that all the oil injectors are working properly and replacing any faulty ones.
Having said that hope you have fun with whatever mod you do Freddie.
- Been thanked: 2086 times
Re: R3 Sohn
The cost of the oil is near zero, given that exactly the same amount of oil is consumed, it's just 2T rather than four-stroke engine oil, being used.
My 2T is actually cheaper, per litre, than the engine oil, so it's a net saving for me.
Re: R3 Sohn
Surely is about type and quality of oil going into the oil injectors, and lubricating the precious seals...I change oil monthly ATM but wdnt do if I had 2t going into the pumps.
Re: R3 Sohn
what? Doesnt everyone do a 5l suckout every monthish? And whats this thing about cost.....if id wanted an economy vehicle id have bought a Toyota Corolla ( its our other car and costs next to nothing) I bought Freddy cause he has a precious diamond under his bonnet, and ill do whatevers neccessary to keep it clean and happy for the next 74000+ miles. This is why im interested in seperating oils as well as lots of other bits to keep that rotor rotorating!
- These users thanked the author Freddie for the post:
- New Duke (Tue Dec 15, 2020 9:49 pm)
- Been thanked: 283 times
Re: R3 Sohn
As far as the R3 goes the extra injector and I think different oil rate made up for the potential issues the S1 may have had due to only 2 injectors/a driven mechanical OMP. Personally I wouldn't seek to change whats not broken... Theres nothing particularly wrong with burning semi synth or mineral oil in the combustion chamber other than it may be dirty (but if you change your oil at regular non monthish intervals... like yearly/6k miles or whatever some people do) you should likely be fine.
- New Duke (Tue Dec 15, 2020 9:50 pm)
Re: R3 Sohn
I think that Mazda have done certain things to make the car more " palletable", this being one....most " normal " car drivers don't want to deal with two different oils, so Mazda amalgamated the two. Even though it could be said that the rotary engine oil has a lot less stress in comparison to a reciprocating engine, it would still benifit from being fully synthetic, and the 2t seperate.
As for the 2 pumps, one has 4 exits and the other, 2 so presume that the 2 pipe is higher pressure than the 4, ....dunno, will keep research ing till I get an R3 with 2t. " Oil is the blood of the engine"
- Milos_Balunovic (Sun Dec 05, 2021 10:19 pm)
Re: R3 Sohn
I mean, Mazda did things for cost reduction sure. But they wouldn't have released a car that didn't function. Like I've said and others have you're trying to find a solution to something you don't particularly need to solve. That's up to you obviously.
I'm personally yet to hear of an R3 owner having issues running things the way they are.
But good luck regardless. Just seems like adding things that can go wrong to a system that completes its job already. :shrug:
Re: R3 Sohn
See where your coming from, but, why are Sohns so poperlear that the club's doing a group thing on buying them? Wether auto pumps/ centre feeds are better than manual is irrelevant to the type of oil they use.
- Has thanked: 252 times
- Been thanked: 206 times
Re: R3 Sohn
We were in the Twilight Zone last month when oil changes were fortnightly...so we're extending the interval. I reckon by Easter we might be heading towards an annual change...
Freddie wrote: ↑Sun Nov 22, 2020 12:56 pmHope its ok to revisit an old one.....have been changing oil fortnightly after purchasing (mk2) and have been taking it outa the sunroof so to say... i got 5 litres every time, and am quite happy with the results. TF, is it not ok to take the cover off of the gearstick seal, and suck it out. Obv with a clean unit, you can see whats come out, and replace the same. Im limited in my capacity for raising my car so am looking at all alternatives if poss. Some may say that i wouldnt be removing all, but any vehicle, and gearbox will have residual oil in that contaminated the new, esp our rotary engines, so isnt this the same?
Re: R3 Sohn
They are popular on the S1 due to lower oil rates (this can be mapped higher) and less oil reaching the chamber where it needs to go.
Something the R3s system was designed to address. With two extra injectors aiming to where the S1s injectors weren't getting oil the problem of oil not getting where it needed to go was solved.
Beyond that it's purely a clean oil feed.. But as you yourself have noted, there isn't a solution directly for the R3.. Because no one sees a reason to create one. It's as simple as that really.
Re: R3 Sohn
It's more about critical mass for the market for such a product.
There are only 455 R3s still registered in the UK and 142 of those are currently SORN'd.
Most of those are owned by people that wouldn't understand this thread, let alone go looking for a technical solution, even if one existed. So it's just not worth the product development costs.
The S1 Sohn/COFS is a passive product, so as long as it's properly engineered and installed, it's a low-risk solution.
The R3 would require an active product, including a new external pump. This gets into a whole new area of risk, especially given the catastrophic and almost instantaneous impact of failure.
So, could the S2 design be improved by providing a clean oil feed? - almost certainly, Yes.
Would it make commercial sense for someone to produce an aftermarket kit? - probably not.
Would it make sense for an individual to create one-off solution for their one car? - Why not, as long as they have the engineering skill and can manage the potential risk.
- Been thanked: 50 times
Re: R3 Sohn
Doesn’t the R3 have three oil injectors.
Also the R3 actually pumps more oil into the Chambers.
Re: R3 Sohn
It actually pumps very slightly less, most of the time, just through 6 jets rather than 4 jets.
Under normal road conditions an R3 "consumes" less oil than an S1, assuming that they were both being driven the same.
However, on track the R3 will consume slightly more, as the control curve from the PCM is higher as revs and load increases.
Some rotary specialists offer "OMP delivery rate" remapping for the S1 to increase it's oiling at higher revs/load.
