Do RX-8 Door Lock Actuators need to have the exact part number?
liamkuro
Forum Guest
Forum Guest
RX-8: Kuro
Colour: Kuro Black
Has thanked: 9 times
Post by liamkuro » Fri Oct 09, 2020 2:33 pm
I'm in need of getting new door lock actuators for both the passenger and drivers side door, I've checked the part number on the actuator and I see the number is A93-SPL-L (Passenger side) and A92-SPL-R (Drivers side). When I look for replacements parts they are often just titled RX-8 Left of Right Actuator, or some have a slightly different part number such as B13-SPL-R. Should I only get those which are a complete match to the ones I'm replacing despite them being visibly identical?
This is the number located on the plastic module with the wire connection.
Many thanks :thumleft:
Vj4sothername
Has thanked: 1358 times
Been thanked: 318 times
Re: Do RX-8 Door Lock Actuators need to have the exact part number?
Post by Vj4sothername » Fri Oct 09, 2020 2:47 pm
I've not checked the numbers when I changed them and had no issues.
S1 - 231 - brilliant black
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
Has thanked: 467 times
Been thanked: 1887 times
Post by warpc0il » Fri Oct 09, 2020 8:20 pm
Not all UK cars came with same locks, and they're different to the locks fitted in the US, JDM and most European markets; all because our cars have "Thatcham Approved security"
Post/PM your VIN and I can check which locks your car was originally fitted with and which later locks are compatible.
ChrisHolmes (Fri Oct 09, 2020 8:21 pm)
Mpv2k3
Has thanked: 205 times
Been thanked: 441 times
Post by Mpv2k3 » Sat Oct 10, 2020 9:21 pm
Whats the cost of these lock actuators?
My driver's door has stopped working. Its not the end of the world as I just use the key instead but? will get it sorted at some point.
Post by warpc0il » Sat Oct 10, 2020 9:23 pm
They're not all the same price. Depends on part number.
Mpv2k3 (Sat Oct 10, 2020 9:44 pm)
bigpete
Forum Trader
Forum Trader
Has thanked: 512 times
Been thanked: 253 times
Post by bigpete » Sat Oct 10, 2020 9:25 pm
I sell them at £39
I don’t have any Jdm ones tho
These users thanked the author bigpete for the post:
Mpv2k3 (Sat Oct 10, 2020 9:45 pm)
Bigpete
Non runners bought for cash.
Contact: 07932678556
http://paypal.me/bostonrotary
Return to “RX-8 Discussion”
