S1 Suspension in the absence of PZ's :(
- Has thanked: 267 times
- Been thanked: 28 times
Hi All,
Appears that all the Club's new PZ suspension sets are spoken for. Given that, can anyone suggest some alternatives?
Events Coordinator
Events Coordinator
Re: S1 Suspension in the absence of PZ's :(
It really depends what you want from the suspension and what your budget is...
- OEM comfort level?
- Stiffer?
- Lower?
- Adjustable - on installation, with tools or on-the-fly?
It's also possible that someone may have bought a set of PZ units, from the original group buy, not got around to fitting, and has changed plans...
- Stiffer?
- Lower?
- willberry70 (Fri Oct 02, 2020 8:18 pm)
- Has thanked: 93 times
- Been thanked: 165 times
Definitely worth posting in buying and selling for a PZ set
Otherwise I can highly recommend Tein Monosport coilovers. Adjustable for ride height and shocker stiffness.
On halfway setting I would say close to R3/PZ stiffness. Springs are stiffer though.
- Been thanked: 174 times
Best other option would be a set from an R3
- willberry70 (Sat Oct 03, 2020 1:16 pm)
- Former Trader
koni shocks and and either tein or similar springs are a fave of mine, adjustable stiffness and sensible lows
- These users thanked the author Lucky 8 Racing for the post:
- willberry70 (Fri Oct 02, 2020 8:19 pm)
Do R3 sets fit straight to S1's??
Events Coordinator
Events Coordinator
- Been thanked: 451 times
Yes, all shop stocked PZ suspension sets and springs have now been sold.
- GreySilver Beast (Fri Oct 02, 2020 9:23 pm)
- Been thanked: 283 times
Im so glad I only just managed to snag a set lol.
- willberry70 (Fri Oct 02, 2020 10:13 pm)
Yes. The R3 dampers and springs aren't interchangeable with the S1 parts, but the complete assemblies fit fine.
- willberry70 (Sat Oct 03, 2020 1:17 pm)
- Has thanked: 112 times
- Been thanked: 25 times
What's different about R3 ones? Lower/stiffer?
Slightly lower than the S1 with better damping control, plus generally a lot younger.
Without going into minute detail, the R3 suspension is essentially the same as the PZ kit. There's no noticeable difference between them on the road or on track. If you wanted the PZ suspension you'll get the same feel and performance from the R3 suspension.
I've had both on my car for road and track.
- These users thanked the author New Duke for the post (total 3):
- GreySilver Beast (Sat Oct 03, 2020 12:42 am) • V8 Power (Sat Oct 03, 2020 5:45 am) • willberry70 (Sat Oct 03, 2020 1:19 pm)
- Been thanked: 328 times
Bilstein B6 kit perhaps?
the PZ units are Billies
- GreySilver Beast (Sat Oct 03, 2020 10:36 am)
Thanks guys,
I guess I was after the equivalent of the PZ as they say it was optimised for UK roads, so it's good to know the R3 is a match or that there are other options to buy new
Obviously if anyone wants rid of their PZ set they should drop me a message
Cheers,
Will.
Cheers,
Will.
Events Coordinator
Events Coordinator
- Been thanked: 229 times
As the PZ Bilsteins and springs are a one off does anyone know is there any difference between R3 and 40th Anniversary Bilsteins and springs?
Yes, again the springs and dampers aren't interchangeable, and Mazda experimented with 3 different spring part # on the 40th, but the overall performance is very similar and the complete units fit all our models (S1 and R3).
- Has thanked: 219 times
- Been thanked: 350 times
Will, ebay number 143768583713,
- willberry70 (Sat Oct 03, 2020 11:27 pm)
Oof, looks pretty ropey condition that eBay set.
I'm just bitter. Tried to sell my good condition R3 kit for that much for months and had no takers (just requests to split the set). Ended up giving them away.
