Help with paint code on R3?
Ben_r1
RX-8: Prospective Buyer
Been thanked: 13 times
Post by Ben_r1 »
My bonnets off at the body shop being resprayed and they’re requesting the paint code which I cannot find anywhere on the car?
It’s a grey metallic colour on a 2010 car I believe the right colour may be 38E from google searches but can anyone confirm?
Ainmhidh
Has thanked: 497 times
Been thanked: 416 times
Re: Help with paint code on R3?
Post by Ainmhidh »
Driver's door pillar or under the bonnet near the driver's corner of the windscreen I believe?
Failing that, the colour police will probably be along shortly to give you a better clue!
Ben_r1
Post by Ben_r1 »
Checked every door shut including rear door and all under the bonnet. Found the vin plate and such but nothing denoting any colour codes I know Mazda to use
Nickp47
Has thanked: 189 times
Been thanked: 349 times
Post by Nickp47 »
Is it a bigger wing mirror car? If so, it will be Aluminium Silver which is 38P
viewtopic.php?f=25&t=11189
Ben_r1
Post by Ben_r1 »
Unsure what is a big or small mirror car? It’s a 2010 R3 model, still new to the 8s and their many variations.
Pic of car can be found here... https://www.instagram.com/p/CEzmxeKnSin ... 9sa9jfrba8
Nickp47
Post by Nickp47 »
Yes that’s Alu silver (later model year so does have the bigger mirrors)
Has thanked: 603 times
Been thanked: 2581 times
If the bonnet is sprayed based on that colour code then it *might* be a close enough match for the rest of the car, but really they should be getting the paint shade colour-matched by the supplier.
The guy that did the replacement front bumper for my Jeep made that mistake and you can tell the difference (too silvery) from the other side of the street #-o . Thankfully, it's just a Jeep, so I don't really care.
Ben_r1
Post by Ben_r1 »
Spoke to Mazda Uk with the Vin can confirm its 38P many thanks for all your help :thumleft:
Mpv2k3
Has thanked: 236 times
Been thanked: 493 times
Post by Mpv2k3 »
I'm pretty sure diamond grey with the smaller mirrors is 38E for reference
