Passenger door lock
Delanor
Has thanked: 18 times
Been thanked: 112 times
Passenger door lock
Post by Delanor » Mon Sep 14, 2020 7:55 pm
I have just discovered the passenger door lock was not locking, the locking button is moving with the key fob but not quite enough to complete the full lock/unlock cycle, now it is more than likely through lack of use as that door is rarely used so has anyone had this happen before I start door panel removing?
Rotary FX fender grills, Japspeed stainless exhaust, K & N filter, Kinetix slotted & dimpled discs, EBC Red stuff pads, Ryan Rotary MK11coils, Magnecor leads, Stainless front & rear grills, HID main beams, LED tail lights, front side lights/front fogs.
Has thanked: 204 times
Been thanked: 742 times
Re: Passenger door lock
Post by qwakers » Mon Sep 14, 2020 8:06 pm
yup. add lube :) which does indeed mean taking the mech out and cleaning it and lubing it properly. no way around it.
Has thanked: 469 times
Been thanked: 1902 times
Post by warpc0il » Mon Sep 14, 2020 9:00 pm
:whathesaid:
If you don't use it regularly it dries up and stops working... :roll:
