MAJOR UPDATE Page 6: **SAFETY ALERT: Fuel Tank recall - Fuel Leaks & Other Issues"
sKenDread
Has thanked: 227 times
Been thanked: 168 times
Re: **SAFETY ALERT: Fuel Tank recall - Fuel Leaks & Other Issues"
Post by sKenDread » Sat Sep 12, 2020 10:52 pm
1. Have you received this recall notice?
No. But called to confirm
2. Have you had the work completed?
Yes
3. If you have had the recall completed, which dealership did the work and roughly when?
Johnson's Mazda, Tamworth 2017?
4. If you have received the recall and not had the work done, what is your reason?
No
5. If you have had the work done, have you experienced any leaks?
Not noticed. I fill mine to the brim
6. If you have had the work done and not experienced any leaks, have you completely filled your tank at least once?
Yes
7. Did you experience any other issues, such as fuel the gauge reading incorrectly? If so, please give details.
Not sure. Seems ok
These users thanked the author sKenDread for the post:
casey (Mon Sep 14, 2020 9:09 am)
Kia-ora!
RRP Performance Ignition Coil System MKII | RRP Mini Map | RRP COFS | Powerflow Twin Exhaust
Original engine 80k
auditt235
Post by auditt235 » Sun Sep 13, 2020 3:46 pm
1. Yes
2. No
3. N/A
4. The car is off the road - am in process of getting it back up and running.
5. N/A
6. N/A
7. N/A
Nearest Mazda garage for me is Baynall near Worcester, anyone used them for a recall?
These users thanked the author auditt235 for the post:
I may get the hang of this one day??
Delanor
Has thanked: 20 times
Been thanked: 122 times
Post by Delanor » Sun Sep 13, 2020 4:14 pm
Not so good when I tried them see the last 2 posts Edwards Mazda
Stevie_P
Post by Stevie_P » Sun Sep 13, 2020 9:19 pm
YES.
YES.
Snows Mazda, Portsmouth last year I think.
N/A.
Haven't noticed anything and had MOT since so assume it's OK.
YES, many times.
Nothing untoward to report.
These users thanked the author Stevie_P for the post:
Hopkins
Colour: Stormy Blue
Been thanked: 31 times
Post by Hopkins » Mon Sep 14, 2020 8:23 am
1. Yes
2. Yes
3. Donalds, Ipswich, not sure when... Will check and correct.
4. na
5. No
6. Yes
7. No
These users thanked the author Hopkins for the post:
Dunebug
RX-8: Kuro
Colour: Kuro Black
Post by Dunebug » Mon Sep 14, 2020 1:16 pm
1. Yes
2. Yes
3. RRG Mazda Stockport, SK4 1DJ. 17/04/2019
4. N/A
5. No fuel tank leaks.
6. I always completely fill my tank.
7. It does read strangely when low on fuel, like it lasts a lot longer on the lowest part of the gague than any other part, but I feel like I remember that happening before the recall.
These users thanked the author Dunebug for the post:
casey (Mon Sep 14, 2020 4:10 pm)
Has thanked: 5617 times
Been thanked: 2572 times
Post by ChrisHolmes » Mon Sep 14, 2020 2:53 pm
Yes the last 1/4 tank does seem to go quicker than any other 1/4 !
Street Ported 231
MazdaSpeed skirts
PaulAV
Has thanked: 117 times
Been thanked: 320 times
Post by PaulAV » Mon Sep 14, 2020 5:51 pm
So answers for me are as follows
No (called local Mazda as soon as there was a rumour and I was amongst the first to get this done)
Yes (see above)
Coventry Mazda (just prior to recalls being issued)
N/A
No leaks
Brimmed the tank many times
No issues
casey (Mon Sep 14, 2020 6:54 pm)
Led side lights, purple Led interior & puddle lights, custom stainless steel grills, Ryan rotary performance coils & sohn, high spec rear drop links, HME engine rebuild at 50k, Borla exhaust, racing beat revi intake including scoop, quick shifter, alloy filler cap, pz alloys, suspension & spoiler, japspeed toe arms & hardrace camber arms.
Beef2561
Post by Beef2561 » Tue Sep 15, 2020 12:09 pm
I have followed the Spin doctor’s advice today, and emailed mmukassistance@mazdaeur.com to ask for my recall to be removed as my fuel basket was updated with a bigger pump and fresh lock rings when I fitted a return fuel line. I asked the dealer to acknowledge this but they haven’t so I’ve messaged Mazda Europe. Concerned VOSA safety notice will mean MOT station can’t pass until removed.
No Pistons:
2004 231 PS Titanium Grey RX-8
2006 Copper Red Evolve RX-8
1993 Montego Blue RX-7 FD3S
Previous: 2005 231 PS Velocity Red RX-8
Beef2561
Post by Beef2561 » Tue Sep 15, 2020 12:29 pm
1. Have you received this recall notice? YES
2. Have you had the work completed? ‘YES BY ME/ENGINEER’
3. If you have had the recall completed, which dealership did the work and roughly when? TAKEN TO BRINDLEY MAZDA WOLVERHAMPTON, AIRBAG WORK COMPLETED ONLY (SEE BELOW) HAVE ANOTHER RX8 TO BOOK IN TOO.
4. If you have received the recall and not had the work done, what is your reason? MAZDA DEALER WANTED TO INSTALL NEW BASKET, FUEL PUMP AND FILTER PLUS LOCK RINGS. I HAVE A MORE POWERFUL PUMP AND RETURN FUEL LINE FITTED (REW TURBO) AND THE SERVICE MANAGER WOULDN’T SWAP IN MY CURRENT PUMP AND FITTINGS (STRAIGHT SWAP PUMP, ONE HOLE TO DRILL IN LID AND RE-FIT BULKHEAD FITTING. I OFFERED TO DO THE ADAPTATION WORK ON THE NEW COMPONENTS BUT SO FAR FALLEN ON DEAF EARS). I SUSPECT THE RECEPTIONIST ISN’T PASSING THIS ON TO THE SERVICE MANAGER AS I CAN’T SPEAK TO HIM.
5. If you have had the work done, have you experienced any leaks? N/A
6. If you have had the work done and not experienced any leaks, have you completely filled your tank at least once? N/A
7. Did you experience any other issues, such as fuel the gauge reading incorrectly? If so, please give details N/A
I am emailing Mazda Europe to try to get the VOSA recall removed as ‘not required’ for the Turbo car as it was completed in 2018. Or to help me get the replacement components which the dealer ordered and prepare the fuel basket so all the plastics can be swapped for new.
Another issue for me is that on early RX8s (03/04) there was a fire safety recall and a fuel tank shield was fitted. In 05 these were fitted as standard. When I checked my 53 plate car for recalls I queried this early recall and was told it was done in 2005 and ‘closed’. I explained to the dealer that the shield is now pretty much disintegrating and was told if it’s not a current recall campaign we can’t do anything. I think we should look to Mazda to reissue this recall; there can’t be that many cars on the road but those that are should have these recall shields checked periodically if they are so important.
These users thanked the author Beef2561 for the post (total 3):
casey (Tue Sep 15, 2020 1:03 pm) • rotatopotato (Tue Sep 15, 2020 1:35 pm) • ChrisHolmes (Thu Sep 17, 2020 10:26 am)
No Pistons:
KayJay18
Post by KayJay18 » Wed Sep 16, 2020 5:56 pm
I've owned car since November 2019 and have had no problems. Tank gets filled regularly. Gov.uk site shows no outstanding recalls. I've been in contact with previous owner to verify.
1 Yes
2 Yes
3 Work done by Leamington Mazda 28th March 2019
4 N/A
5 No problems
6 Tank filled completely every time
7 No other problems. Fuel gauge OK
These users thanked the author KayJay18 for the post:
casey (Wed Sep 16, 2020 8:29 pm)
TEE_JAY1967
Post by TEE_JAY1967 » Mon Sep 21, 2020 5:57 pm
1. YES
2. YES
3. HENDY EASTBOURNE JULY 2019
4. N/A
5. HAVE NOT USED CAR MUCH IN LAST YEAR AND FILLED TANK TO TOP LAST MONTH
6. N/A
7. NOT THAT I HAVE NOTICED
I am currently in discussion with the dealer who made the mistake of thinking I was a stupid female. I hit every one of their social media accounts as got fed up with the Service Manager who originally wouldn't take my call.
I have also got MazdaUk involved by going through their Twitter accounts and they are also investigating.
Have to take the car back to dealer on Wednesday so that they can investigate as it seems they don't believe me or my photos and video.
I will update once they have investigated.
casey
Has thanked: 1249 times
Been thanked: 1465 times
Post by casey » Mon Sep 21, 2020 7:33 pm
Many thanks for that TEE_JAY1967
Looking forward to an update. In the meantime I'll be adding this to my spreadsheet listing :thumleft:
Club Secretary
Seibon Carbon Fibre Bonnet
embee
Post by embee » Tue Sep 22, 2020 1:16 pm
Hi all - got your email requesting a response.
Car is in for a service today so will update if any further info.
So answers are:
2. Have you had the work completed? YES
3. If you have had the recall completed, which dealership did the work and roughly when? Aug 19 including this one at Johnsons Mazda in Oxford (supplying dealer)
4. If you have received the recall and not had the work done, what is your reason? N/A
5. If you have had the work done, have you experienced any leaks? No
6. If you have had the work done and not experienced any leaks, have you completely filled your tank at least once? Yes
7. Did you experience any other issues, such as fuel the gauge reading incorrectly? If so, please give details ...No
These users thanked the author embee for the post:
casey (Tue Sep 22, 2020 2:33 pm)
Frankie 8
Forum Guest
Forum Guest
Colour: Stormy Blue
Post by Frankie 8 » Tue Sep 22, 2020 2:41 pm
1. Yes
2. Yes
3. Masters MAzda Beckenham, Colchester, March 2020
4. N/A
5. Yes
6. N/A
7. Just leaks, cost me over 400 euros to fix as I was abroad
Do you think I can file a complaint to reimburse my repairs?
These users thanked the author Frankie 8 for the post:
casey (Tue Sep 22, 2020 2:45 pm)
sztriki
Has thanked: 34 times
Been thanked: 8 times
Post by sztriki » Thu Sep 24, 2020 8:36 pm
Sorry if I'm late for the party. Mine is going to be a bit more convoluted than yes/no.
Previous owner did.
Previous owner did, shortly before I bought the car.
Early 2018, Mazda Swansea.
N/A
Previous owner said they did, sent it back to Swansea to get it fixed. I bought the car shortly after in May 2018 and smelled petrol in the cabin. Took it to Romford Mazda, paid for a new seal that was apparently missing (June 2018). Mazda Swansea office refused any refund or compensation, according to their records they carried the work out out to the dot. Failed MOT in 2019 for fuel leak, rubber seal under fuel pump was apparently snapped, paid again for a new one (independent, non-Mazda related garage). No problems since.
Yes, no problems since last MOT in May 2019.
No.
These users thanked the author sztriki for the post:
casey (Fri Oct 09, 2020 3:08 pm)
casey
Post by casey » Fri Oct 09, 2020 3:03 pm
Frankie, you have a PM.
Club Secretary
casey
Post by casey » Fri Oct 09, 2020 3:08 pm
Sorry to hear that tale. Sadly, I can't include your information in the data I'm collating as I might be double-counting. I have 3 Facebook reports of leaks where I do not have the dealership or dates involved and one of those could be your car reported by the previous owner. If you have details of the previous owner then please PM me with more info and I might be able to work out if yours is a new case :thumleft:
Club Secretary
casey
UPDATE: **SAFETY ALERT: Fuel Tank recall - Fuel Leaks & Other Issues"
Post by casey » Fri Oct 09, 2020 3:23 pm
Thanks everyone for the very useful information you have provided to help the RX-8 owning community =D> .
In summary the picture emerging is very concerning:
Of 94 respondents, 69 have taken their car to Mazda dealers for the recall, and 15 of those owners (22%) reported fuel leaks after the work had been done.
The issue is not confined to any specific dealership, the problem arising from Inverness to Eastbourne.
It is also concerning that 12 respondents are choosing not to have this work done, having learned of the problems reported by other owners.
On behalf of all RX-8 Owners, a formal letter was sent yesterday by the RX-8 Owners Club to DVSA (formerly VOSA), copied to Mazda UK, expressing our concern at the number of RX-8's being handed back to owners with fuel tank leaks post this recall campaign work being carried out.
Our contention is that no car should be collected by an owner from a dealership with a leak in the fuel tank - pretty simple really. It's not for us to say how this should be achieved, but concern has been stated at the post-recall testing procedure defined by Mazda UK that the dealerships are required to perform.
BTW, I received another report of a fuel leak last night (via FB Messenger) complete with a video similar to mine with fuel pouring out. That makes 16 of 70 now, so 22% "failures" has now risen to 23%!
These users thanked the author casey for the post (total 6):
Vj4sothername (Fri Oct 09, 2020 3:24 pm) • New Duke (Fri Oct 09, 2020 3:42 pm) • rotatopotato (Fri Oct 09, 2020 4:21 pm) • nightfire10 (Fri Oct 09, 2020 5:26 pm) • Shagrington (Fri Oct 09, 2020 8:41 pm) • Delanor (Fri Oct 09, 2020 9:19 pm)
Club Secretary
Yorindesarin
Has thanked: 26 times
Been thanked: 377 times
Re: UPDATE Page 4: **SAFETY ALERT: Fuel Tank recall - Fuel Leaks & Other Issues"
Post by Yorindesarin » Fri Oct 09, 2020 3:27 pm
That's almost 1/4 just of what has been reported.. Nevermind those who haven't seen this/aren't in the OC etc..
Scary figures in reality.. 1 in 4 chance of your car having a very serious issue.
The Red 8:
Racing beat Revi, Tein street basis z coilovers, RRP Mk2 Coils (and one Mk3), Stock catback, Cruise Control (Zoom Zoom).
For whats pending... See here: viewtopic.php?f=104&t=81689
Neilnc30
Forum Guest
Forum Guest
Post by Neilnc30 » Fri Oct 09, 2020 4:40 pm
1. Have you received this recall notice? - YES
2. Have you had the work completed? - YES
3. If you have had the recall completed, which dealership did the work and roughly when? - OLDHAM MAZDA
4. If you have received the recall and not had the work done, what is your reason? NA
5. If you have had the work done, have you experienced any leaks? - YES, PETROL SMELL INSIDE AND OUTSIDE WHEN ONLY HALF A TANK FULL OF PETROL GOES IN
6. If you have had the work done and not experienced any leaks, have you completely filled your tank at least once? - n/a
7. Did you experience any other issues, such as fuel the gauge reading incorrectly? If so, please give details.- n/a
These users thanked the author Neilnc30 for the post:
casey (Fri Oct 09, 2020 5:39 pm)
casey
Post by casey » Fri Oct 09, 2020 5:52 pm
I've been thinking about how to relate my small sample responses to the entire population of recalled cars. I posted this on a Facebook group a short while ago, but revised a little after further thought.
Based on the "how many left" website, there are a total of 2,130 RX-8's (all models) licensed at end of Q2 2020, with a further 3,245 on SORN. Yes, more on SORN than on the road, possibly more than usual due to covid? However, the recall doesn't apply to all models, some on SORN won't be getting the recall done and some owners are refusing to get the work done due to the horror stories. I guess 5,000 recall notices is a good estimate, but probably less than half have had the work done to date (just my feeling on the matter, only DVSA will know for sure).
My sample is 94 responses (1.9% of population of recalled cars), 69 of which have had the work done (the rest scheduled, SORN'd or refusing) and 15 leaks from the 69, so 22% leaking.
If we assume that 2,500 cars have had the work done (guess) then 69 represents 2.7% of the population of cars that have had the work done, not a bad sample size. I accept my data may be biased as more people will tend to respond if they have an issue - those with no issue are more inclined not to bother. However, only last night another leak was reported to me, so now 16 from 70. On the other hand, I have a strong suspicion there are a number of owners driving around who have not filled their tank and may have a leak but are unaware??
Club Secretary
Yorindesarin
Post by Yorindesarin » Fri Oct 09, 2020 5:56 pm
Thats the worrying thing. Some people may not have filled it up enough to get a leak as of yet. So when a leak does happen it could be catastrophe! As leaks seem to happen at differing fuel levels. I'd hate to of filled up with a roasting hot cat persay... Get started off again and be unfortunate enough to have the fumes catch. Especially on the forecourt of a petrol station...
These users thanked the author Yorindesarin for the post:
casey (Fri Oct 09, 2020 6:49 pm)
The Red 8:
New Duke
Has thanked: 793 times
Been thanked: 712 times
Post by New Duke » Fri Oct 09, 2020 6:01 pm
That's also assuming that there won't be a number of owners who will have a leak but either won't notice it for whatever reason, or won't be concerned enough to do something about it (God help them). Given the amount of drivers I see pottering around with a fuel cap open, wobbly wheel, or dragging exhaust etc I wouldn't set the bar very high.
Great work Malcolm, thanks for looking out for everyone.
auditt235
Post by auditt235 » Fri Oct 09, 2020 6:09 pm
This is really good work.
I am aiming to get my Rex back on the road within 8 weeks. Is there anything on a word or excel file that might warn the dealer that there are issues I will be aware of and so they should also be aware of them before they try the repairs?? I think it would need to be fairly short.....etc
casey (Fri Oct 09, 2020 7:07 pm)
Return to “RX-8 Discussion”
