PZ springs
Jeags
Has thanked: 147 times
Been thanked: 35 times
PZ springs
Post by Jeags »
Hi all,
Put the 8 into local garage today to get tracking done and he said he couldn't do it yet due to a broken rear spring (driver's side). I know these are common faults and would like to replace them with the OEM PZ springs. I looked on the shop here and it says the rears are out of stock, any ideas where I can pick a good new set up from?
Cheers,
Joe
Has thanked: 575 times
Been thanked: 2435 times
Re: PZ springs
The Club shop was the only stockist for these parts.
Your only remaining options are if someone bought a set in the group buy and is prepared to sell as their plans have changed, or someone replaced their original springs with new and still have one unbroken original spring you could buy.
Has thanked: 6257 times
Been thanked: 3070 times
Re: PZ springs
Post by ChrisHolmes »
Do you have PZ suspension on the car already? If not then you cannot fit the PZ springs as seats are different.
AB Bucket seats & 5 point harnesses
Rebuilt 6 port
Pettit SC
Racing Beat alloy flywheel, oil lines & ARBs , REV 8 Full SS Exh
Stg1 Exedy Clutch
AEM Smart Coils & MSD leads
Remote oil filter
Tein MonoSports & EDFC
Fully polybushed
Racing Brake 4 Pot Calipers
MazdaSpeed skirts & Rear Spoiler
Lockwood SS Grills
Re: PZ springs
:whathesaid:
One of the problems with Tapatalk is that it doesn't show the profile info, so I'd assumed you had a PZ.
Unless you're running the bespoke Bilstein dampers from a PZ then "PZ springs" aren't an option.
If you're running the original UK-spec suspension then that's actually "Mazda Sports Suspension" and you need springs to match that.
Don't go near motor factors, ECP, or anyone else that lists "replacement springs", as they will try and sell you the same spring regardless of which suspension you have.
Having had one rear spring break then both should be replaced, since the other would have been over-stressed.
I would recommend looking for a good, low-mileage, used pair from someone who has either upgraded to something totally different, or breaking the car for other reasons. Start with a call/message to BigPete.
You could fit complete PZ suspension, though this would have to be front and back, since the ride heights, spring and damping rates are different.
Jeags (Tue Jul 28, 2020 8:19 pm) • ChrisHolmes (Tue Jul 28, 2020 9:30 pm)
Jeags
Re: PZ springs
Post by Jeags »
ChrisHolmes wrote:Do you have PZ suspension on the car already? If not then you cannot fit the PZ springs as seats are different.
Yeah, the car is a prodrive version. Will hopefully find a solution soon, don't really want to change the suspension from OEM.
These users thanked the author Jeags for the post:
ChrisHolmes (Tue Jul 28, 2020 9:31 pm)
Re: PZ springs
Looks like our posts crossed - and you really need to update your profile ;)
Back to Plan A then
Jeags (Tue Jul 28, 2020 8:33 pm)
Conan
Has thanked: 59 times
Been thanked: 778 times
Re: PZ springs
Post by Conan »
pick up emails
Ainmhidh (Wed Jul 29, 2020 10:03 pm)
Jeags
Re: PZ springs
Post by Jeags »
Just a thought, but would it be worth asking if a garage would weld the break? It's at the very bottom of the spring. Just a thought but I'm not sure on how that would affect the spring?
Re: PZ springs
You can't repair springs by welding, since the heat means they don't "spring" any more.
Colour: Nordic Green
Has thanked: 309 times
Been thanked: 1138 times
Re: PZ springs
Post by qwakers »
warpc0il wrote:
Tue Jul 28, 2020 8:43 pm
this.
it turns spring steel into used-to-be-spring steel. :D
Re: PZ springs
I know someone that had a leaf spring on the back of their motorhome welded.
Thankfully it collapsed before he even got it out of the workshop.
Jeags
Re: PZ springs
Post by Jeags »
warpc0il wrote:You can't repair springs by welding, since the heat means they don't "spring" any more.
Ah, kinda defeats the purpose of it then! Image I'll just have to keep an eye out for one before mot time in November!
Jeags
Re: PZ springs
Post by Jeags »
What do we think about this?
http://essexrotarystore.com/product/tei ... -for-rx-8/
I doubt I'll be able to get any springs so it looks like I'll have to go for a new suspension. Just not sure whether to go for the above, or opt for the full PZ kit on the oc?
Cheers,
Joe
nightfire10
Has thanked: 1611 times
Been thanked: 766 times
Re: PZ springs
Post by nightfire10 »
You could email conan a few posts up he might have one or two
Jeags
Re: PZ springs
Post by Jeags »
nightfire10 wrote:You could email conan a few posts up he might have one or two
Ah, missed that one. Cheers!
nightfire10 (Wed Jul 29, 2020 2:39 pm)
mi60o0
Has thanked: 91 times
Been thanked: 382 times
Re: PZ springs
Post by mi60o0 »
Jeags wrote:
Wed Jul 29, 2020 2:10 pm
Cheers,
Joe
I had the street basiz then went with meister atm tein flex z. All have plus and minus.
But street basiz is good for the money but not adjustable damping. If you spend a bit more you can have coil with more adjustability.
These users thanked the author mi60o0 for the post:
Jeags (Thu Jul 30, 2020 7:13 am)
BatRex 192 stock
Yorindesarin
Has thanked: 22 times
Been thanked: 517 times
Re: PZ springs
Post by Yorindesarin »
I'll have a set of tein Street basis z in decent condition for sale soon. 180 quid including p&p
These users thanked the author Yorindesarin for the post:
Jeags (Thu Jul 30, 2020 10:08 am)
Club Treasurer "What do you mean bitcoins not a solid investment for the club..?!"
Kentaro The Red
For whats pending... See here: viewtopic.php?f=104&t=81689
Jeags
Re: PZ springs
Post by Jeags »
Yorindesarin wrote:I'll have a set of tein Street basis z in decent condition for sale soon. 180 quid including p&p
Nice! I'll have to assess all options, but sounds decent!
Yorindesarin
Re: PZ springs
I don't think the springs are too bad for like the outer covering. But I won't know until I have them off the car. No clue what the mileage is like but I found them to be an excellent ride on the road etc. They'll be without top mounts and possibly gaiters/dust covers as I'll née those for the replacements. :p
Jeags (Thu Jul 30, 2020 10:34 am)
Kentaro The Red
Jeags
Re: PZ springs
Post by Jeags »
Yorindesarin wrote:I don't think the springs are too bad for like the outer covering. But I won't know until I have them off the car. No clue what the mileage is like but I found them to be an excellent ride on the road etc. They'll be without top mounts and possibly gaiters/dust covers as I'll née those for the replacements. :p
That's fine, send me a few pics if you can when you get them off the car! Image
Re: PZ springs
It does seem a shame to compromise a PZ, if there's any way to avoid it.
Not that there's anything wrong with the Teins but the suspension is absolutely a key element in what makes a PZ a PZ.
Yorindesarin
Re: PZ springs
It is indeed. I'm sure once jeags isn't on apprentice wages he'll be in a better situation to sort that out. I'll tlbe taking them off after the cars actually moving again. Either next week or the week after probably if you aren't in much rush?
Kentaro The Red
Jeags
Re: PZ springs
Post by Jeags »
Yeah, not in too much of a rush. Mot November so needs to be done by then. Plenty of time. Does the oc still stock any PZ suspension sets after they bought some? Was considering that, but not sure if I've been a member for long enough or can afford it. The teins are about £400 new so if it's only a bit more for a PZ set from the shop, I think I'd prefer that, was obviously why I favoured a PZ. Again though, don't know if I've been a member long enough yet! Just wondering whether it may be best to buy a new set, at least I them know it'll last well and hopefully, make the car feel like new.
casey
Has thanked: 1461 times
Been thanked: 1690 times
Re: PZ springs
Post by casey »
The club still has PZ full suspension sets in stock (we had 4 sets on May 27 and we haven't sold them all, to my knowledge.
Price £995 non-members, £595 for paid up members of 12+ months standing (bargain!!) - ex shipping, £47 UK mainland.
Further details here:
https://rx8ownersclub.co.uk/forum/viewt ... 42&t=79158
Jeags (Thu Jul 30, 2020 4:39 pm)
Club Secretary
]Federal 595RS-R or Rainsport 3
xamtex
Been thanked: 124 times
Re: PZ springs
Post by xamtex »
i may have a used rear spring somewhere,not ideal changing 1 but the other was broken and i put the good one away just incase.
These users thanked the author xamtex for the post:
Return to “RX-8 Discussion”
