Mintex 1155 pads supplier
- Has thanked: 694 times
Does anyone have or know a reputable supplier of Mintex 1155 pads? I'd rather try somewhere known before risking eBay fakes.
Re: Mintex 1155 pads supplier
- New Duke (Thu Jun 18, 2020 5:05 pm)
I will get you a price from the group buy supplier.
Our supplier has no 1155 compound in stock but there is stock of 1144 compound. Are you sure 1155 compound is suitable for your type of use?
To secure the best prices I would need to order c20 sets, however for lower quantities I can source the 1144 compound pads as below;
Front MDB2589 1144 £110 delivered
Rear MDB2588 1144 £ 75 delivered
A chunk higher than the previous group buy but still hopefully the best price around.
Maybe it's almost time for another group buy...
- FrenchCarMan (Sat Jun 20, 2020 12:06 am)
- Has thanked: 46 times
- Been thanked: 80 times
i'm sure a small error but i have the fronts as 2589 and rears as 2588. BTW i can supply these much cheaper, looking about £95 front & £65 rear delivered for single sets but can obviously do better for more.ChrisHolmes wrote: ↑Fri Jun 19, 2020 10:26 amOur supplier has no 1155 compound in stock but there is stock of 1144 compound. Are you sure 1155 compound is suitable for your type of use?
Front MDB2588 1144 £110 delivered
Rear MDB2589 1144 £ 75 delivered
- Colour: Diamond Grey
- Has thanked: 52 times
- Been thanked: 31 times
Do you have pricing for the MDB1292 for those who use the 4pots?ChrisHolmes wrote: ↑Fri Jun 19, 2020 10:26 amOur supplier has no 1155 compound in stock but there is stock of 1144 compound. Are you sure 1155 compound is suitable for your type of use?
Rear MDB2588. 1144 £ 75 delivered
Thanks for pointing out the typo, every record I have is 2589 front and 2588 so just a slip the finger in the post but could have had major implications down the line so thanks again.Leck3000 wrote: ↑Fri Jun 19, 2020 11:18 ami'm sure a small error but i have the fronts as 2589 and rears as 2588. BTW I can supply these much cheaper, looking about £95 front & £65 rear delivered for single sets but can obviously do better for more.ChrisHolmes wrote: ↑Fri Jun 19, 2020 10:26 amOur supplier has no 1155 compound in stock but there is stock of 1144 compound. Are you sure 1155 compound is suitable for your type of use?
Clearly the one off set pricing I have for the club is not as good as your buying price therefore in this case You will have the business.
MDB1292 1144 compound would be £75 deliveredMpv2k3 wrote: ↑Fri Jun 19, 2020 11:24 amDo you have pricing for the MDB1292 for those who use the 4pots?ChrisHolmes wrote: ↑Fri Jun 19, 2020 10:26 amOur supplier has no 1155 compound in stock but there is stock of 1144 compound. Are you sure 1155 compound is suitable for your type of use?
Thanks a lot for doing that Chris. Yeah I want to try either 1155 or Blue Stuff. I'm sure it's down to my technique of leaning too heavily on the brakes on track, but I want a pad that can tolerate higher temps for longer. Fergus suggested that I try the 1155 last year, but I wanted to try the 1144 first. Snetterton on Wednesday made up my mind. It was a hot day and the pads were the limiting factor (closely followed by the tyres, gearbox and engine temps!):ChrisHolmes wrote: ↑Fri Jun 19, 2020 10:26 amOur supplier has no 1155 compound in stock but there is stock of 1144 compound. Are you sure 1155 compound is suitable for your type of use?
Blue Stuff seem from online chatter to handle high temps well and are very cheap from EBC with the club discount.
I agree however for those doing mainly road use with the occasional track day then 1144 compound is the best choice. 1155 is certainly a more Motorsport focussed pad and will work well at the higher temperatures encountered in track or rally driving but the downside can be that with light use such as normal road driving squeal can develop.
The above us based on numerous forums comments and Mintex tech sheets I have read. Personally I use the 1144 on track and road and find it an ideal compound.
Did you do a full lap to cool the brakes down?New Duke wrote: ↑Fri Jun 19, 2020 12:17 pmThanks a lot for doing that Chris. Yeah I want to try either 1155 or Blue Stuff. I'm sure it's down to my technique of leaning too heavily on the brakes on track, but I want a pad that can tolerate higher temps for longer. Fergus suggested that I try the 1155 last year, but I wanted to try the 1144 first. Snetterton on Wednesday made up my mind. It was a hot day and the pads were the limiting factor (closely followed by the tyres, gearbox and engine temps!):ChrisHolmes wrote: ↑Fri Jun 19, 2020 10:26 amOur supplier has no 1155 compound in stock but there is stock of 1144 compound. Are you sure 1155 compound is suitable for your type of use?
Can't say I've ever had that issue with the m1144
- These users thanked the author Mpv2k3 for the post:
- ChrisHolmes (Fri Jun 19, 2020 9:32 pm)
- Has thanked: 33 times
- Been thanked: 22 times
Did we ever get a price on the 1155s?
My 1144s are melting onto my discs, leaving deposits and vibrations galore..!
2006 Galaxy Grey 231
Nankang NS-2R | Eibach Pro-Kit Springs | Eibach 20mm Spacers | EBC Discs + Bluestuff Pads | Racing Beat REV8 Catback + High Flow Cat | BHR Ignition | K&N Filter | Koyo Rad | Mishimoto Thermostat | Greddy Sump with ER Lines | Lockwood Grills
Nothing happening currently on sourcing these pads therefore I suggest you try Google fir prices and availability, sorry.
- Been thanked: 108 times
Just my 2 pennys worth...
I did a brand new set of 1155s to the metal at Cadwell. 8 sessions on track. 4pm on the trailer. Brake dust everywhere. Proper break in followed previous day. Comparable braking to the ferrodo ds2500 and ebc rp1.
I get 3 days out of rp1 and ds2500. Mightily disappointed with the 1155.
This was for a 300mm wilwood midilite set up not 8 though.
Sent from my SM-G977B using Tapatalk
- These users thanked the author boosted for the post:
- ChrisHolmes (Wed Jun 29, 2022 12:16 pm)
EBC don’t do the RP1 for the RX-8 do they? Would like to try them out but can’t find them availableboosted wrote:Just my 2 pennys worth...
They don't at present but they have been known to respond to demand, assuming someone tells them...
