Engine teardown, do I dare?
- Colour: Metropolitan Grey
- Been thanked: 37 times
Hi all,
As you may know, I haven't had the best luck when it comes to RX-8 ownership so far. However, hopefully that'll change soon! Long story short, bought the car, sat for a few months, driven well for a couple of weeks, then went south very quickly (hot start issue emerged and engine failure a couple of weeks later). I am at the point where I have the engine out, and the plan was to let Dwayne from Silver Fern tear it down in hope of reusing some parts for a rebuild. Since we're on lockdown now, do you think is should/can attempt to disassemble the engine in the garage and can it be done with basic everyday tools?
Cheers all,
Joe
Cheers all,
Joe
Re: Engine teardown, do I dare?
That depend hugely on you definition of "basic everyday tools"
In most people's definition the answer is a clear "No", as you'd fail to get the nuts off the eccentric shaft, without which it's not coming apart.
See here viewtopic.php?f=58&t=60547 for further reading
- Jeags (Tue Mar 24, 2020 5:07 pm)
Right, thanks for that. So just wait patiently then you think?warpc0il wrote:That depend hugely on you definition of "basic everyday tools"
or.. make a locking tool for the ess and get out the mahoosive breaker bar,
I am willing to give it a go, I'm only 8 hours into lockdown and I can't stop thinking about it! I do have a Massive breaker bar!qwakers wrote:or.. make a locking tool for the ess and get out the mahoosive breaker bar,
how massive...
ive got a 6ft 1” drive and that was only just enough...
Ah, may not be as big as I thought then! I've got a teng tools one. I think this off the top of my head! https://www.toolstoday.co.uk/teng-tools ... UAQAvD_BwEqwakers wrote:how massive...
Probably won't do the job, ah well, I'll let boredom drive me insane!
well yes it probably will, you'll just need to add a bit of mechanical advantage... a scaffold pole works well...
Right, think it's worth attempting then before I die of boredom? More than happy to have a go, but would rather try and prevent any irreversible damage I could cause! Cheers.qwakers wrote:well yes it probably will, you'll just need to add a bit of mechanical advantage... a scaffold pole works well...
sure, wont do any harm. worst that can happen is you can fail.
- Jeags (Tue Mar 24, 2020 7:44 pm)
- Been thanked: 283 times
Take breaker bar, attach X length of pipe. Infinite leverage at will. Profit.
- These users thanked the author Ollie for the post (total 2):
- Jeags (Tue Mar 24, 2020 7:44 pm) • 30405 (Tue Mar 24, 2020 9:49 pm)
Great! What could go wrong?!Yorindesarin wrote:Take breaker bar, attach X length of pipe. Infinite leverage at will. Profit.
slip, fall and crack yer nut open?
- 30405 (Tue Mar 24, 2020 9:49 pm)
Small price to pay for a rebuilt engine! "He who dares wins, Rodney!"qwakers wrote:slup, fall and crack yer nut open?
- Been thanked: 330 times
Biggest thing to sort out is a 54mm socket to undo the flywheel nut
I had to specially order mine as I wanted single point and got one with a 3/4" drive too
which I then ground down to remove the large chamfer on the entrance to the hex
then you need to make up a flywheel locking tool I used a old gudgeon pin welded to some box section so I can bolt it through the bellhousing bolts using the edges of the box section to brace against the flywheel teeth
and you will also need some M10 fine pitch bolts to bolt the engine up to assembly stand
- These users thanked the author 350matt for the post:
- Jeags (Tue Mar 24, 2020 8:57 pm)
...and that's the other challenge.
However much force you put on the nut, you need to brace the engine.
The bulk of the engine simply isn't enough, unless you have access to a massive impact gun, otherwise the leverage required, will have everything, including you in a heap on the floor.
Yeah, I'll have an experiment with it anyway. I'll plan it tomorrow hopefully and take it slowly. Thanks for all the help as per usual!warpc0il wrote:...and that's the other challenge.
Dave's correct you will also need a brace
I use a long bit of angle iron with a couple of holes in it that gets bolted to the lower bellhousing bolts
- Jeags (Tue Mar 24, 2020 9:30 pm)
You can also bolt it direct across the flywheel in the absence of the locking tool on the ring gear teeth.
Undo the front bolt first as you can only lock the shaft using the flywheel.
Good luck
Good luck
- Jeags (Sat Mar 28, 2020 10:33 am)
- Been thanked: 50 times
Drop dawyne a email and ask if it’s alright I you strip the engine down.
He may want to strip it down his self.
I’m guessing they work on other cars at Silver Fern judging by they web site blurb.
Machining: Major components are machined to O.E drawing specification tolerances. The cylinder blocks are rebored or resleeved and finally honed for the essential cross hatch micro finish. The cylinder block is pressure tested. All gasket joint surfaces are remachined to O.E. tolerances. Cylinder head valve guides are checked, resized or renewed as required. The valve seats are recut to ensure concentricity. The head is pressure tested and the valves vacuum tested. Cylinder head face is surface ground to correct tolerance. Crankshafts are crack detected and the journals are reground to next undersized and micro-finished to fine tolerances. Camshaft profiles are reground and journals polished where specification permits. Connecting rods are thoroughly inspected and the small end bushes replaced and re-machined to size (if fitted). Valve faces and stems are remachined, if suitable, otherwise replaced. Oil pumps are stripped and remanufactured as required.
13BLT Renesis Rotary powered Dolomite Sprint in the making.
Balanced Lightened and Tweaked.and Supercharged.
Yeah, he said we could if we wanted. He does service other cars. Mind you, don't think he's open for a while now due to lockdown.SprintRX8 wrote:Drop dawyne a email and ask if it’s alright I you strip the engine down.
im slightly excited by the prospect of my engine dying so i can have a bash at rebuilding it. am i weird?
- Has thanked: 750 times
- Been thanked: 175 times
It's why I bought mine....dac69er wrote:im slightly excited by the prospect of my engine dying so i can have a bash at rebuilding it. am i weird?
Not weird at all!
Buy a spare engine from a breaker, you might even find that it wasn't "broken" at all, inside.
A few members have been lucky enough to buy complete cars with "a blown engine" only to find a simple fault like a couple of coils, or a duff ESS, or a massive burp from an oil overfill.
People, especially car dealers, are so convinced that rotary engines self-destruct that they will scrap a car at the first sign of "engine trouble".
Weirdly, these days it's much more likely to be the impact of tin worm that actually makes an 8 only good for scrap
- ChrisHolmes (Sat Mar 28, 2020 11:03 pm)
