Low emission E10 fuel
pstables
Has thanked: 6 times
Been thanked: 10 times
Post by pstables »
Good car choice for the stock photo on the BBC news site;
https://www.bbc.co.uk/news/uk-51731757
UPDATE 11 July 2021.
Your club committee asked Mazda UK for their position on use of E10 fuel in RX-8's and they quickly responded with an the official statement below. In summary, the important bit is, "E10 petrol is cleared for use in all models with petrol engines introduced in and from the year 2002".
UK Compatibility with E10 fuel.pdf
Essex2Visuvesi
Been thanked: 74 times
Re: Low emission fuel
Post by Essex2Visuvesi »
Oh dear.... I was hoping that they wouldn't bring this horrible stuff to the UK
Neilparry
Has thanked: 8 times
Been thanked: 220 times
Post by Neilparry »
Well all be complaining our cars won’t accelerate past 4K and very slow to pull away.
:wash:
Nerdstrike
Been thanked: 13 times
Post by Nerdstrike »
I mean... carbon emissions go down because there's less energy in the fuel. So you have to buy more. How is this helping?
Also where do the gigaliters of ethanol come from?
manuRx8
Forum Guest
Forum Guest
Post by manuRx8 »
In case it serves as a reference:
I have been using gasoline with an added 10% ethanol for 3 years and 30000km and the car is fabulous, better than with gasoline alone:
  • Softer
  • I do not notice loss of power (it is 192 and goes up without problems well above 8000rpm)
  • Consumption has barely increased (+ 3.7%)
  • The compression I think has even has be improved (after a year using it, with 85484 km, it had: front 8.20-8,46-7.97, rear 7.98-7.95-8.23).
The only drawback is that I don't have E10 suppliers in my area and I have to make the mixture myself (I add 3-4 ls of alcohol every time I fill the tank)
These users thanked the author manuRx8 for the post (total 2):
sKenDread (Wed Mar 04, 2020 1:36 pm) • turnips (Wed Mar 04, 2020 3:46 pm)
sKenDread
Has thanked: 112 times
Post by sKenDread »
manuRx8 wrote:In case it serves as a reference:
  • Softer
ImageImage I'd rather take the 3-4L of ethanol and mix it with distilled water and drink it (that's if it's not contaminated) ImageImage
Seriously though, is it possible it could be down to the water separation in the alcohol contributing to carbon clean out?
Kia-ora!
'09 R3 Aurora Blue Mica
manuRx8
Forum Guest
Forum Guest
Post by manuRx8 »
No, the cause is the higher oxygen content of alcohol; This makes that extra oxygen react with carbon, avoiding carbon deposits and reducing existing ones little by little.
In fact, alcoholic gasoline is called "oxygenated gasoline."
A study conducted in Australia for E10 determined that the CO decrease is approximately 32% and that of CO2 is 7%
Ollie
Has thanked: 11 times
Been thanked: 283 times
Post by Ollie »
Sooo cheaper car tax then? Of course not. But as long as premium petrols not E10 I don't see an issue. :p
Techathy
Has thanked: 9 times
Been thanked: 18 times
Post by Techathy »
More ethanol? Sounds like a chance to add more boost... So, guess I need to fit a turbo or supercharger kit then!
NeMFO
Has thanked: 23 times
Post by NeMFO »
Mighty car mods run E85 for added performance when they can get it don’t they so this sounds like great idea to me and I’m wondering where I can get ethanol from (another type of premix) . I am also wondering whether this might be a way of getting my car through an MOT without a cat. What are you thoughts?
Ollie
Post by Ollie »
Im sure I remember ethanol not playing well with Apex Seals but I have no idea where from.
Has thanked: 444 times
Been thanked: 2087 times
The problem with high ethanol fuels tends to be with fuel line seals and other non-metallic components in the fuel system, which can include pumps, filters and injectors, plus with older cars carburettors. These materials were never designed to be in contact with ethanol and can breakdown.
New Duke (Thu Mar 05, 2020 12:23 am) • tonym (Fri Oct 28, 2022 5:20 pm)
PaulAV
Has thanked: 173 times
Been thanked: 523 times
Post by PaulAV »
NeMFO wrote:
Wed Mar 04, 2020 5:40 pm
The only reason they run E85 is so they can increase boost and alter the timing, neither of which is of much use to the rx8 unless forced induction is used. The mot requires a car to be fitted on cars under a certain age/if they were manufactured with one, regardless of emissions.
delta0
Has thanked: 66 times
Been thanked: 45 times
Post by delta0 »
Risky but can we advance timing with more ethanol in there?
RX8 R3 Aurora Blue Mica
Not only risky, as the slightest detonation can implode a rotary, but all the evidence shows that there's also no power advantage in advancing the ignition.
This is why our PCMs make no attempt to creep the advance, no matter what fuel you give them.
Many piston engines will creep the advance until the knock sensor triggers, then back off a tad.
According to ACEA (European automobile manufacturers association)
ACEA wrote:Mazda:
E10 petrol is cleared for use in all models with petrol engines introduced in and from the year 2002,
Mazda6 (GG/GY) and models with petrol engines introduced thereafter, i.e:
 Mazda2: DY/DE.
 Mazda3: BK/BL.
 Mazda5: CR/CW.
 MX-5: NC.
 Mazda6: GG/GY/GH.
 CX-5: KE.
 CX-7: ER.
 CX-9: TB.
RX-8: SE.
PaulAV
Post by PaulAV »
Isn't this regarding ethanol safe components like hoses, fittings and pumps, for instance they don't dissolve in ethanol, more than anything else?
Yes, those as well as the engines.
Nerdstrike
Dissolving components never stopped people quaffing 10% ethanol solutions...
New Duke
Has thanked: 695 times
Been thanked: 561 times
Post by New Duke »
Interesting that it lowers mpg even further. I wonder if they accurately accounted for increased consumption in their statistics claiming lower overall emissions. Knowing how statistics are used to frame a narrative, I doubt it.
But good news! It will allow fuel sellers to sell fuel for the same price per litre, but with 10% of the fuel being a cheaper ingredient. All under the claim of helping the environment which makes it an easier sell for governments. It's genius.
Looking forward to seeing what mpg I can get from this slop at Snetterton (my control test track) where I get 4-5 mpg on E5.
Honkytonk
Media Team
Media Team
Has thanked: 121 times
Been thanked: 202 times
Post by Honkytonk »
For christ's sake can't we just switch to hydrogen for our rotaries yet?
These users thanked the author Honkytonk for the post (total 2):
30405 (Thu Mar 05, 2020 6:09 pm) • v-rex (Mon Mar 01, 2021 8:08 pm)
NeMFO (Thu Mar 05, 2020 8:25 pm)
geofftl1000r
Colour: Metropolitan Grey
Has thanked: 75 times
Been thanked: 34 times
Post by geofftl1000r »
I was having issues with my bike running on Shell fuel. So I wrote them an email asking if there was any ethanol in the fuel. They replied back saying less than 10%. So that's 9.9% then?
Stopped using Shell after that for the bikes. The RX8 doesn't seem to mind the current level, whatever it is.
40th Anniversary RX8
New Duke
Post by New Duke »
geofftl1000r wrote:
Thu Mar 05, 2020 6:26 pm
It's 5% or E5. I'm pretty sure that all UK petrol has been for years, even Momentum and V Power. It's not a brand specific thing.
Has thanked: 29 times
Been thanked: 328 times
Post by 350matt »
taking a look on various fuel advice websites
https://www.e10fuelforthought.nsw.gov.au/facts
it seems that all mazda petrol engines since 2002 are E10 safe
I know 1990's BMW's suffer with melting fuel tanks with high concentration figures of ethanol
