new disks and pads
Techathy
Has thanked: 11 times
Been thanked: 19 times
Re: new disks and pads
Post by Techathy » Wed Feb 19, 2020 4:04 pm
Conan wrote:
Tue Feb 18, 2020 7:39 pm
Grooves I believe are primarily for gas dispersal which can cause a friction problem.
Unless your going on track you don’t need to consider things like that unless you like the ascetics.
You're right, gas dispersal is why grooves started being machined/cased into discs. But, as someone who has owned cars which are very prone to water saturation of brake discs, I've experienced how much faster "cold" grooved discs disperse water.
Has thanked: 4649 times
Been thanked: 1959 times
Post by ChrisHolmes » Wed Feb 19, 2020 9:48 pm
It could be scary if I ever need any replacements !!!!!!!!!!!!!!!!!!!!!
Bridge Ported 231
MazdaSpeed sills
Short shifter
AndyBrad
Been thanked: 17 times
Post by AndyBrad » Thu Feb 20, 2020 9:24 am
im guessing those kits ar going to be a little more than a couple of hundred quid :)
Post by ChrisHolmes » Thu Feb 20, 2020 9:33 am
Carls will I am sure be very competitively priced
Bridge Ported 231
MazdaSpeed sills
Short shifter
Yorindesarin
Has thanked: 21 times
Been thanked: 206 times
Post by Yorindesarin » Thu Feb 20, 2020 11:44 am
Just imagine the import tax on top of that Chris... Sheesh.
Post by ChrisHolmes » Thu Feb 20, 2020 6:26 pm
import tax will be zero as I won’t be buying them at that price. I can buy the rotors (discs) on their own a lot cheaper.
Bridge Ported 231
MazdaSpeed sills
Short shifter
Return to “RX-8 Discussion”
