Velocity red paint code
Neilparry
Has thanked: 28 times
Been thanked: 225 times
Post by Neilparry » Wed Feb 12, 2020 1:54 pm
As the heading implies could someone tell me the paint code please
:wash:
Nickp47
Has thanked: 78 times
Been thanked: 136 times
Re: Velocity red paint code
Post by Nickp47 » Wed Feb 12, 2020 1:55 pm
27A
Neilparry
Post by Neilparry » Wed Feb 12, 2020 1:58 pm
Thanks Nick. Ordered
:wash:
Has thanked: 138 times
Been thanked: 502 times
Post by qwakers » Wed Feb 12, 2020 2:00 pm
wont match if you order it by paint code. if your not spraying a entire car i recommend getting it custom matched at a paint shop.
GreySilver Beast (Wed Feb 12, 2020 6:56 pm)
Neilparry
Post by Neilparry » Wed Feb 12, 2020 3:46 pm
qwakers wrote:wont match if you order it by paint code. if your not spraying a entire car i recommend getting it custom matched at a paint shop.
Yes James I know.
Whilst talking to my mate who has 35 years experience says because there’s no variants of the paint code you’ll be very lucky if your able to match it by altering the code. It’ll go from close to way out within a drip of another colour going in. Image
:wash:
Velocity_Dan93
Has thanked: 27 times
Been thanked: 57 times
Post by Velocity_Dan93 » Wed Feb 12, 2020 6:50 pm
Wonder what he’s painting ;)
VR bridge port Mazdaspeed with lambo doors yo!
GG bridge port track missile
Phantom stock engine impulse buy #-o
sKenDread
Has thanked: 192 times
Been thanked: 140 times
Post by sKenDread » Wed Feb 12, 2020 7:10 pm
I don't understand why there wouldn't be variants as the color will change depending on the medium it's applied to. So there's gotta be variations?
Kia-ora!
RRP Performance Ignition Coil System MKII | miniMelon Map | RRP COFS | Powerflow Twin Exhaust
Original engine 80k
sKenDread
Post by sKenDread » Wed Feb 12, 2020 7:20 pm
I've just spoken to my mate about it and yeah the code may not have variants but that's only "out if the box"
A skilled paint shop will be able to create variants and match mix it there. He recommended a place called Spraywell in Dudley
Kia-ora!
Original engine 80k
Neilparry
Post by Neilparry » Wed Feb 12, 2020 7:42 pm
We looked at the three chips against a panel I took with me and all three chips were a mismatch in a range of different lighting
So I went with the middle chip
Fortunately it’s not a panel I’m having painted so there’s no real concern for a precise match
:wash:
Has thanked: 370 times
Been thanked: 1412 times
Post by warpc0il » Wed Feb 12, 2020 7:49 pm
If you were painting something like an engine cover, then the out-of-the box should be a good enough match.
For a spoiler, mounted on non-painted uprights, you might get away with it.
For a bumper or body panel you need an exact match.
That said, one member took his fuel filler flap in to get matched, as he was painting the front bumper, only to find that the front and rear of his car were 2-3 shades different.
When challenged on this he parked his next to another VR at a meet.
Parked nose-nose they matched, but parked nose-tail they didn't.
Yorindesarin
Been thanked: 166 times
Post by Yorindesarin » Wed Feb 12, 2020 9:50 pm
My passenger wing has been painted badly at some point (low clear coat and its really noticeable) I'm not even sure if its worth trying to get it sorted...
Has thanked: 4499 times
Been thanked: 1857 times
Post by ChrisHolmes » Wed Feb 12, 2020 10:43 pm
The biggest issue with VR is metallic medium as well as the red colour coat and originally it’s a three stage process of base coat (not primer) middle coat and then clear coat.
I cannot find the supplier which does the 3 rattle can set which is annoying as I have used them fir my aero kit and the match was excellent.
Exedy Stg1 Clutch
Adaptronic ECU
Return to “RX-8 Discussion”
