Tyre Pressure Maintenance
v-rex
Has thanked: 518 times
Been thanked: 192 times
Post by v-rex » Sun Jan 12, 2020 12:30 pm
Hi All,
Did a search but couldn't see anything so I thought I'd start a new topic. Recently my tyre pressure gauge and inflator have gone faulty so I'm looking into new options and wondered what people use and their experiences with each.
1) Tyre Pressure inflator
I bought one once I found how inaccurate pressure gauges at petrol stations can be. I went for the Michelin Rapid 12262 Tyre Inflator and it served me ok but I found out about halfway through it's life that the pressure wasn't that accurate. Actually I realised that as the unit got hot that the pressure was off more and more, so by the time I got to the 4th tyre the pressure was further off.
2) Tyre pressure gauge
So I bought a tyre pressure gauge ( Race Rx0014 tyre pressure gauge ) to double check with. I over pump with the inflator slightly and then use the gauge to manually let out air and adjust down to the exact pressure. This has worked well over the last 3 years giving exactly the right "feel" in the car.
So now I am thinking of just replacing the tyre pressure inflator with the updated model of what I have, and the same gauge again. But.... for the inflator I was thinking of a foot pump instead, so to not have to start the car for minor adjustments, and possibly a digital tyre pressure gauge ( such as the one in the club shop ) . Anyone have any experiences of these, and any other options I've not thought of ?
Thanks,
Vinod
chriskirkham
Has thanked: 29 times
Been thanked: 21 times
Re: Tyre Pressure Maintenance
Post by chriskirkham » Sun Jan 12, 2020 1:04 pm
I use the supplied Mazda tyre inflator, gauge is reasonably accurate ( tends to slightly under-read pressure ).
So I inflate to 2.4 bar and then let some air out with the gauge.
Currently using an AA guage:
Sent from my SM-T550 using Tapatalk
v-rex
Post by v-rex » Sun Jan 12, 2020 1:21 pm
Supplied Mazda tyre inflator .... where is this usually ? Is this somewhere in my boot and I've never looked ? This might be a huge facepalm moment if so ....
xamtex
Been thanked: 121 times
Post by xamtex » Sun Jan 12, 2020 1:41 pm
in a black zip up bag with tyre sealer in the boot strapped to the os inner wing
chriskirkham
Post by chriskirkham » Sun Jan 12, 2020 1:50 pm
If you don't have one, they are relatively inexpensive, you may find one of the traders on here are selling.
The tyre repair fluid is likely to be out of date now, but just buy some tyre sealant from ECP or eBay.
https://rover.ebay.com/rover/0/0/0?mpre ... 4147844155
NGK Iridium plugs
D585 coils
Magnecor leads
LC Rotary mini-map
Millers 10w/40 semi-synthetic oil
Millers NT Transmission Oil in Gearbox and Diff
Pre-mixing with Protek R
Sebring cat-back exhaust
H&R lowering springs (dropped 45mm)
Front number-plate relocated
De-badged front
Chrome SS Strakes (needing refurb)
v-rex
Post by v-rex » Sun Jan 12, 2020 1:52 pm
Getting a facepalm ready....
I know of that bag but thought it only contained emergency tyre repairs. I've not looked inside since I got the car 12 years ago....
v-rex
Post by v-rex » Sun Jan 12, 2020 1:53 pm
This is a good point. I probably should update the sealant, when I finally open that bag....
chriskirkham
Post by chriskirkham » Sun Jan 12, 2020 1:57 pm
Every day is a school- day, eh?
These users thanked the author chriskirkham for the post:
v-rex (Sun Jan 12, 2020 2:00 pm)
v-rex
Post by v-rex » Sun Jan 12, 2020 2:01 pm
;) Don't be surprised if my next post asks where the tyre jack is.....
nightfire10
Has thanked: 1190 times
Been thanked: 552 times
Post by nightfire10 » Sun Jan 12, 2020 2:05 pm
That'll be with the emergency tow hooks! ImageImage
v-rex (Sun Jan 12, 2020 2:13 pm)
v-rex
Post by v-rex » Sun Jan 12, 2020 2:20 pm
I know where those are as I got stuck in a farmer's field once ( in the snow ) and I had to be towed out.
They did keep coming out though. Apparently I didn't screw them deep enough.... ! ( Cough cough ) ;)
delta0
Has thanked: 78 times
Been thanked: 40 times
Post by delta0 » Sun Jan 12, 2020 2:24 pm
Which aren’t actually hooks for towing. They are only for tie down during transportation
These users thanked the author delta0 for the post (total 2):
v-rex (Sun Jan 12, 2020 2:27 pm) • GreySilver Beast (Sun Jan 12, 2020 2:35 pm)
RX8 R3 Aurora Blue Mica
xamtex
Post by xamtex » Sun Jan 12, 2020 2:42 pm
trouble with tyre sealer is once you use it the tyre is scrap as it cant be repaired properly with sealer in it....i got a spacesaver for mine and the bag is on the garage shelf.
Has thanked: 5597 times
Been thanked: 2564 times
Post by ChrisHolmes » Sun Jan 12, 2020 6:06 pm
That is a common misconception, the eyes that screw into the front and rear are for towing another car or being towed. The tie down points for shipment are actually underneath the car.
v-rex (Sun Jan 12, 2020 8:42 pm)
Street Ported 231
MazdaSpeed skirts
Has thanked: 490 times
Been thanked: 1999 times
Post by warpc0il » Sun Jan 12, 2020 10:35 pm
Conan (Sun Jan 12, 2020 10:54 pm)
Post by ChrisHolmes » Sun Jan 12, 2020 11:26 pm
Lost in translation is a phrase that comes to mind here.
The wording is poor because the second sheet whilst using the term “tie down eyelets” is in fact also showing how to attach them in order to tow the vehicle. Substitute the word towing eye in certain places and the sheet makes sense.
Under the car there are two lugs with holes at the rear which are shown as jacking points, but I think are the tie down points for shipping, I use them to sit into axle stands as in the attached photo.
Taking out the blanks in the rear bumper and front grill to attach the eyes for shipment tie down runs the risk of damage to paintwork and doing this on every car at the speed they load ships would I think be impractical.
From practical regular experience across the membership of starting flooded cars by towing we know that a properly screwed in eye is more than capable of towing the car without damage to the bumper.
Street Ported 231
MazdaSpeed skirts
Ainmhidh
Has thanked: 488 times
Been thanked: 402 times
Post by Ainmhidh » Mon Jan 13, 2020 11:04 am
Are you aware of the button next to the bonnet release that opens the boot? Chris Holmes can show you where that one is :lol:
Post by ChrisHolmes » Mon Jan 13, 2020 2:21 pm
:censored: :censored: :censored: :censored: :censored: :blahblah: :blahblah:
Ainmhidh (Mon Jan 13, 2020 2:28 pm)
Street Ported 231
MazdaSpeed skirts
Has thanked: 266 times
Been thanked: 586 times
Post by Dr. FrankenRex » Mon Jan 13, 2020 5:52 pm
Can't add any more to what has already been said, as I use the Mazda OEM one. Seems accurate enough to me.
Only thing I can add is that the cigarette lighter adaptor is powered on when the key is in IGN position, but without the engine running. So unless you're inflating a tractor tyre then you'll be fine doing all 4 tyres with the engine off without draining the battery :thumleft:
v-rex (Mon Jan 13, 2020 7:18 pm)
Yorindesarin
Has thanked: 26 times
Been thanked: 375 times
Post by Yorindesarin » Mon Jan 13, 2020 5:58 pm
I wish I had the Mazda supplied tyre kit. Supposedly its an MOT failure to not have it?
The Red 8:
Racing beat Revi, Tein street basis z coilovers, RRP Mk2 Coils (and one Mk3), Stock catback, Cruise Control (Zoom Zoom).
For whats pending... See here: viewtopic.php?f=104&t=81689
PaulAV
Has thanked: 116 times
Been thanked: 319 times
Post by PaulAV » Mon Jan 13, 2020 6:02 pm
Wouldn't of thought it's an mot failure not to have it, it is not a requirement to have a spare wheel (but if you have one it has to be road legal)
Post by warpc0il » Mon Jan 13, 2020 6:09 pm
It's not included in the MOT test
Yorindesarin
Post by Yorindesarin » Mon Jan 13, 2020 6:34 pm
Is it not? I can't remember where I read that. But not having a spare and not having a repair kit of some description seems like it would logically be a failure of having a road worthy car? Or do they just presume you're able to have emergency breakdown cover and thus it doesn't matter if you only have 3 tyres that function?
The Red 8:
Post by warpc0il » Mon Jan 13, 2020 6:45 pm
A car without a spare wheel or repair kit, is perfectly roadworthy, until you have a puncture.
*If* you carry a spare wheel then the tyre must be road legal and correctly inflated, the same as if it was fitted.
In France (and some other countries) it's a legal requirement to carry spare bulbs, which makes sense as bulb failure is statistically more likely than a puncture.
I've had more fan/drive belt failures than punctures in over 45 years of driving, but they don't make carrying a spare fan belt a requirement...
Yorindesarin
Post by Yorindesarin » Mon Jan 13, 2020 7:02 pm
Fair point. I should see about tyre stuff anyway... Just incase.
The Red 8:
Return to “RX-8 Discussion”
