Underseal/Waxoyl
Leck3000
Has thanked: 46 times
Been thanked: 80 times
Underseal/Waxoyl
Post by Leck3000 »
Hey everyone. So it was MOT day last week and all went well apart from a new advisory for underside corrosion.
I had seen some reference to getting the underside protected but its not an area i am familiar with at all, certainly with regards to options and also where is good to get it done.
If anyone would mind educating me but also any recommendations for someone in the oxfordshire-ish area.
Has thanked: 186 times
Been thanked: 548 times
Re: Underseal/Waxoyl
Post by Dr. FrankenRex »
It would need to be fully treated first to stem the current corrosion. I don't know of any particular places, but my understanding is that it's not a massively complex or specialist area
Nickp47
Has thanked: 175 times
Been thanked: 326 times
Post by Nickp47 »
New Duke (Mon Dec 16, 2019 2:20 pm)
OP is not a member, so canny read that ;)
Nickp47 (Mon Dec 16, 2019 1:20 pm)
AndyBrad
Been thanked: 28 times
Post by AndyBrad »
i was quoted between 250 and 450 for the underside of the rx8
how much is a subframe?
AndyBrad
Post by AndyBrad »
the one thing i keep meaning to do is a massive can of acf50 as you can just atomise it all over the underside of the car.
Ollie
Has thanked: 11 times
Been thanked: 283 times
Post by Ollie »
Being a member would gain you a huge wealth of knowledge and discounts on rust prevention. If you go the DIY route there's a product called Vactan (members can save money on this. It's highly concentrated and is generally diluted for off the shelf rust converters). After this presuming no welding is required you'd use an underseal of some description (waxyol). Otherwise you'd obviously have welding done first and then underseal.
Leck3000
Post by Leck3000 »
Thanks guys. As it has only just appeared as an advisory i do hope the extent is limited at the moment but when i have a chance i will get under and assess it more myself.
New Duke
Has thanked: 695 times
Been thanked: 561 times
Post by New Duke »
If it's an advisory Leck that means it's already eating at key areas, it's just not officially a safety hazard yet (as far as they know). If you're not experienced with rust then take maybe post up pictures here (if you know where to look) or even better take it to a professional if you don't know how to evaluate it yourself.
The deal on Vactan in the members area may be of interest to you... but as with all this stuff you need to know what you're doing with it or have the time to learn.
That's the second R3 that's been mentioned on here with rust this week. Looks like their time has come.
New Duke
Post by New Duke »
AndyBrad wrote:
Mon Dec 16, 2019 11:47 am
Like... a whole subframe? Incl fitting to the car? Crikey if it's gone that far the sills will likely be toast as well, not to mention what else will be suffering.
It's so much cheaper just to deal with rust properly/prevent it in the first place.
The thread that Nick linked to was my post in the members area about my experience on Friday having my R3 professionally rust prevented. Not just the underside; the lights, boot areas, engine bay, bonnet, doors, suspension... everywhere. And not with a traditional Waxoyl based product.
Definitely worth renewing your membership for given the quotes you've had just for the underside ;)
In the meantime get yer RX8s in a garage with a decent dehumidifier. It'll help slow it down at least.
Leck3000
Post by Leck3000 »
New Duke wrote:
Mon Dec 16, 2019 1:54 pm
Thanks, unfortunately something that must wait until the finer weather arrives but an initial google and prices aren't eye watering but still not pocket change either.
For the love of cars! :roll:
Has thanked: 2572 times
Been thanked: 940 times
Post by ChrisHolmes »
RX8OC members can have their cars fully treated where New Duke has his treated last week for £276 inc VAT so worth joining the club to be able to read the thread as a member.
These users thanked the author ChrisHolmes for the post (total 2):
Leck3000 (Tue Dec 17, 2019 9:35 am) • willberry70 (Sun Jan 05, 2020 9:56 am)
dac69er
Been thanked: 18 times
Post by dac69er »
I personally wouldn't touch it until the summer. Especially if it's a daily.
You want it clean and bone dry before treating and sealing anything imo.
Been thanked: 68 times
Post by RX8R3Rod »
Lots of really good advice here.
I guess the value of ‘I recommend company x’ is somewhat limited by proximity.
But that said, Rustbuster in Spalding is very good.
Before whacking on the underseal they steam clean the underside, flush the body with Salt remover, dry the car using infrared heaters, remove loose / heavy rust, stbalise surface rust with a rust converter, inject cavity wax with rust converter / inhibitor at high temperature and 2500psi (beats my old waxoyl pump can , I imagine) and ... then whack on the underseal. ;-)
And given all the above, you can have it done at any old time you like.
These users thanked the author RX8R3Rod for the post:
willberry70 (Sun Jan 05, 2020 9:57 am)
Tein Monosport EDFC Active coilovers, K-Sport BBK 8-pot forge 356mm front, 4-pot BBK 330 mm rear, 20" ATS Racelight, Michelin PS 4 245/30/20, Pettit exhaust, Pettit front and RB rear ARB's, Cusco strut and brake brace, Full Paintshieldx2, Rustmasterx2, and Rustbusterx2, M'Z Custom nose and rear skirts
Has thanked: 444 times
Been thanked: 2087 times
Bizarre as it sounds, given that treatment regime, the result may actually be better in the winter.
The relative humidity is often much lower on a cold crisp winters day than a hot summer day, which is why you can often get static electric shocks in the winter.
Obviously the metal needs to be dry and warm enough to avoid condensation.
Post by RX8R3Rod »
That’s a really interesting thought, Dave ... 👍🏻
Leck3000
Post by Leck3000 »
Thanks for the thoughts and suggestions. I have found a great looking company quite near to me (ish) and i will be speaking with them in the coming months. First job is to have a proper little gander and see exactly whats going on underneath but that can wait a month or two.
untakenname
Colour: Kuro Black
Has thanked: 71 times
Post by untakenname »
After my last RX8 succumbed to rust (sills were shot and the rust went into the body though it looked ok with the damage being hidden by the aero kit) I looked at over a dozen RX8's before finding my current one, all the other ones I looked at had the bubbling just starting on the rear sills.
To keep mine in good condition I generally won't use it in winter when it's wet and the council have salted the roads but if I do then I rinse out under the arches and underside of the car with a bendy hose pipe attachment.
I injected Bilt Hamber Syntax 50 into the sill cavities and also undid the arch liners and treated behind them as well as treating everything else with ACF50
Did mine last year and when I came to renew it this year the coating was still protecting so left it in place.
I use the liquid 1 litre bottle and pour it into an empty normal domestic trigger spray cleaner and it atomised pretty well as long as it was warm (left the bottle in hot water for 15 before hand).
Post by RX8R3Rod »
Top work! That sounds like a really good approach. 👍🏻
Delanor
Has thanked: 42 times
Been thanked: 229 times
Post by Delanor »
There used to be quite a few much regarded rust proofing companies like Zeibart in the UK but then they died out when the car industry started to make cars that didn`t rust. =D> :^o #-o
That didn`t last did it! :-k
Post by RX8R3Rod »
Oh gosh, yes, that’s a name from the past, isn’t it? 😄
And as you say, very highly regarded
Just to make life perhaps even more challenging for those non-rusting car makers, I’m told by my local Mazda dealer that Lincolnshire is planning to use gritting salt that’s coated in molasses. 🤔
Apparently it sticks to the road better, but I imagine the stuff that doesn’t will potentially stick even better and more corrosively to the nooks and crannies of our chassis ...
Didn't they try that in Wales and the car vs sheep rate went through the roof, as the sheep kept standing licking the road... :shock:
Colour: Nordic Green
Has thanked: 100 times
Been thanked: 545 times
Post by qwakers »
dartmoor ponies and ponies on bodmin moor get hit far more often in the winter, as horses are very partial to salt, and will stand in the middle of the road licking it....
The must have detailing product in 2020 will I suppose now be “Molasses Remover”
You can use molasses to remove rust, it's an old engineers trick that goes back to the early steam trains, at least.
willberry70 (Sun Jan 05, 2020 9:59 am)
