Brake squeal only when cold
Noticed this more now with the cold weather but brakes squeal at low speeds until they are warmed.
If I don't get them warmed before breaking at speed its a little bit like a wobble board sound
But if they are warmed through then everything is fine....
Had new disks and pads summer before last iirc
- Been thanked: 544 times
- Been thanked: 59 times
Re: Brake squeal only when cold
my old Mintex pads were loud when under light braking.
Thanks, Stu
Mad as anything
Mad as anything
They are mintex but just their normal OEM style
Could be glazing of the pads and / or deposit build up in the discs.
Do you always brake lightly or do you have occasional good hard braking applications. The latter should prevent glazing and clear any deposits.
- Been thanked: 2086 times
Removing the pads, cleaning the backs and pins and then applying a fresh thin coat of Ceratec can often fix this issue, especially if the previous installation was left dry or copper grease was use.
Chris
Don't think that's likely as not overly gentle on the brakes
They definately werent left dry when I fitted them. But a good clean is probably my first port of call.
- Has thanked: 53 times
- Been thanked: 76 times
Mine squeal really badly under light braking and thats with mintex pads I'm using with the BB kit on the group buy a while back.
If you are on 1144 compound they should not squeal at all
Some thought I did have.... I replaced the shims with the ones that came with pads as originals were very corroded and splitting at the edges is it worth trying to get some more?
And also had a load of grief trying to fit them as had to file pads metal edges down
Despite cleaning clips and calipers
(Also did sliders at the same time.)
Actually it's funny how things occur annually....
viewtopic.php?f=6&t=78264&hilit=Pads&p=1186115#p1186115
mine did under light braking.ChrisHolmes wrote: ↑Sat Nov 23, 2019 7:30 pmIf you are on 1144 compound they should not squeal at all
Thanks, Stu
Mad as anything
Mad as anything
Yeah they only dont squeal when your foot is reasonably hard down on the pedal, in fact embarrassingly loud when feathering the brake
Mine is worst pulling up to junctions or sitting in traffic.
But like I said above is more disconcerting breaking from speed if they haven't warmed.
Hmm! I have never had any squeaking from 1144 pads.
I wonder if this is a reaction to residue left on the discs from previous pad materials.
Definately some cross talk on this thread...
Pads are OEM mintex not 1144 and discs were new
And I'm out of bed at 4am due to hacking cough
Okay well didn't get to look at car due to last week's illness and catching up on work stuff..
Today the left rear brake disc seems substantially hotter than the rest. Think it must be binding a bit....
