And the compression results are in...
Jeags
Has thanked: 101 times
Been thanked: 17 times
Post by Jeags » Fri Nov 01, 2019 4:20 pm
... Rotor 1 - 300rpm 5.1-5.25.3 250 rpm 4.4-4.5-4.5
... Rotor 2 - Comprssion too low to be registered.
Spoke to Dwayne about this, as he put it "it's one of the best condition 8's he's seen in a while, but the worst compression as well!". He's advised me not to premix or red line the car, said just to keep it mid range (3k in a 30) and hopefully carbon will clear. He reckons it is carbon build up as the last owner has probably never red lined it and it isn't even that high mileage (48k). I'll take his advice and hopefully it will slowly improve. Will go for another test after 6 months or so if the car still runs! Any more advice? Not the outcome I wanted but at least I know where I am with it!
Nickp47
Has thanked: 91 times
Been thanked: 158 times
Re: And the compression results are in...
Post by Nickp47 » Fri Nov 01, 2019 4:26 pm
I’m confused, won’t keeping the revs low cause more carbon buildup?
Hate to be negative but the engine sounds beyond the point of being saved by a regular Italian tune up, hopefully I will be proven wrong though.
Jeags
Post by Jeags » Fri Nov 01, 2019 4:30 pm
What I thought. But he thinks that redlining it would do more harm than good. It will need a rebuild, but he said hopefully if it doesn't die before then, he can clean most of it up and replace seals which should fix it! I wasn't too sure about it but I'm in no position to go against his word.
Has thanked: 1100 times
Been thanked: 1063 times
Post by MARKTHOMASBRAND » Fri Nov 01, 2019 4:31 pm
Who's Dwayne :?:
Mark's : 2020 Championship White Honda Civic FK8 Type R .
Mandy's : 2019 Mazda MX-5 30th Anniversary RF # 1761/3000.
Nickp47
Post by Nickp47 » Fri Nov 01, 2019 4:32 pm
Ok I see so more of a temporary solution than an attempt at a fix :thumright:
Nickp47
Post by Nickp47 » Fri Nov 01, 2019 4:33 pm
Who's Dwayne :?:
These users thanked the author Nickp47 for the post (total 3):
Vj4sothername (Fri Nov 01, 2019 4:35 pm) • Jeags (Fri Nov 01, 2019 4:38 pm) • Shagrington (Fri Nov 01, 2019 7:39 pm)
Jeags
Post by Jeags » Fri Nov 01, 2019 4:38 pm
:lol: He's a fella at a local rotary specialist (Silver Fern). Nice chap!
Has thanked: 656 times
Been thanked: 558 times
Post by New Duke » Fri Nov 01, 2019 4:39 pm
Please shop around before agreeing to have him do your rebuild. I hope 'clean most of it up and replace the seals' weren't his words. Call RRP when you're ready to rebuild, or bigpete may even be able to fit a working second hand engine for you quickly.
Sorry you got those results. Hopefully once it's sorted you'll finally get to experience the engine at full power.
@Mark and Nick, he's at Silver Fern Performance.
These users thanked the author New Duke for the post (total 2):
Vj4sothername (Fri Nov 01, 2019 5:13 pm) • Jeags (Fri Nov 01, 2019 5:18 pm)
Post by MARKTHOMASBRAND » Fri Nov 01, 2019 4:43 pm
I remember seeing something posted about "Silver Fern" on here many moons ago & it was pretty controversial :p
Ryan Rotary Performance
Sponsor Trader
Sponsor Trader
Has thanked: 170 times
Been thanked: 584 times
Post by Ryan Rotary Performance » Fri Nov 01, 2019 4:44 pm
Dont want to say any ill words but,
Its VERY inlikely to improve by any significant amount if at all! Not sure about the advice but my advice is to get it rebuilt either by him or another specialist.
Hopefully at the moment the plates and housings are all in good condition being such a low mileage car you'll get a much better (and cheaper) engine if you just do it now.
Thats my advice
These users thanked the author Ryan Rotary Performance for the post (total 2):
Jeags (Fri Nov 01, 2019 4:48 pm) • Velocity_Dan93 (Sun Nov 03, 2019 12:52 pm)
Jeags
Post by Jeags » Fri Nov 01, 2019 4:46 pm
Aye, being an apprentice money definitely isn't that good (would take me a considerable amount of months to save enough for a worst case scenario rebuild). Definitely will rebuild this though, love it to bits! Maybe have to see about getting a credit card... :shock: #-o
Jeags
Post by Jeags » Fri Nov 01, 2019 4:48 pm
Thats my advice
Right, well it would take me a while to save up anyway so I guess no harm it trying his idea? I'm not expecting a miracle, just hopefully enough for the engine to survive while I save up!
Has thanked: 399 times
Been thanked: 1559 times
Post by warpc0il » Fri Nov 01, 2019 4:49 pm
With those results I'd be wondering if the rear stationary bearing has failed and the tail of the eccentric shaft is wobbling around, either that or there's a big score in one of rear iron surfaces.
Actually, the last time someone reported numbers like that it was finally tracked down to a broken spark plug, but then he did also have "a strange metallic clicking" which everyone was sure was the bearing, though it was the air escaping through the plug body. #-o
Sponsor Trader
Sponsor Trader
Post by Ryan Rotary Performance » Fri Nov 01, 2019 4:51 pm
I'd drive it as little as possible until you save up TBH. At this point you're probably doing more harm than good.
Jeags
Post by Jeags » Fri Nov 01, 2019 4:58 pm
I wish it was that, he checked the plugs and said they were good. I haven't a clue tbh. I guess time will tell.
Vj4sothername
Has thanked: 789 times
Been thanked: 165 times
Post by Vj4sothername » Fri Nov 01, 2019 5:16 pm
New Duke wrote:Please shop around before agreeing to have him do your rebuild. I hope 'clean most of it up and replace the seals' weren't his words. Call RRP when you're ready to rebuild, or bigpete may even be able to fit a working second hand engine for you quickly.
Keep an eye out and if you get lucky a cheap engine that runs may come up. I was luck (with help from here) and bagged one for 300. Run that while saving to get yours rebuilt.
These users thanked the author Vj4sothername for the post (total 2):
New Duke (Fri Nov 01, 2019 5:20 pm) • goodeggbob (Fri Nov 01, 2019 5:32 pm)
S1 - 231 - brilliant black
Feb 08 built,
Fake Toyosport back box,
Dents,
Scratches,
Replacement engine,
Smiles
Jeags
Post by Jeags » Fri Nov 01, 2019 5:19 pm
Nice idea. I'll keep an eye out, cheers.
Vj4sothername
Post by Vj4sothername » Fri Nov 01, 2019 5:35 pm
Mine was found on the rx8 classifieds UK Facebook page. It came out of a running car for an engine swap. He did have a second engine for the same price.
Swapping isn't massively hard if you have everything. Namely a crane (you can rent one). I did mine 95% on my own (the Mrs helped with crane control while I lined everything up). Took me 4 days to get out and in. That's on my driveway with 2 stands and a lot of faffing. My knowledge of this was online guides, changing brake pads and discs experience and a butt load of enthusiasm.
I think in a proper garage I could do it in 2 days maybe 1 long day (18hours). I'd expect a pro could do it in less still.
I'll egg on everyone in to do it themselves as I found it very rewarding. But it could give you a rough idea of getting an experts cost £x X 18 hours = £etc
If there's enough work near by Luke maybe willing to travel up.
Feb 08 built,
Dents,
Scratches,
Replacement engine,
Smiles
njkmr
Has thanked: 84 times
Been thanked: 141 times
Post by njkmr » Fri Nov 01, 2019 5:37 pm
Great advice.
Don't destroy what may be a fairly good set of engine parts now.
Get a cheap temporary replacement to ride around with whilst saving up. :thumright:
Jeags
Post by Jeags » Fri Nov 01, 2019 5:52 pm
So just to be clear, you're suggesting I could find an engine that runs, swap it out for my poorly one and get that poorly one rebuilt and then swap it back in? If so, it's definitely a possibility, I guess i'd sell the engine I bought to run around after my old one was fixed?
Vj4sothername
Post by Vj4sothername » Fri Nov 01, 2019 5:56 pm
Jeags wrote:So just to be clear, you're suggesting I could find an engine that runs, swap it out for my poorly one and get that poorly one rebuilt and then swap it back in? If so, it's definitely a possibility, I guess i'd sell the engine I bought to run around after my old one was fixed?
Well it's up to you. I've kept my dead one as a project to rebuild. If the replacement one is good you can just run that and sell the old one for parts.
These users thanked the author Vj4sothername for the post:
Jeags (Fri Nov 01, 2019 5:58 pm)
Feb 08 built,
Dents,
Scratches,
Replacement engine,
Smiles
Has thanked: 453 times
Been thanked: 653 times
Post by goodeggbob » Fri Nov 01, 2019 6:13 pm
Hi there,i ,along with john,have had good luck with buying engines. as said before,contact big pete and see if he can help. in my opinion,there is nothing wrong with having a reserve engine,especially if you are keeping the car for a while. also ,i have a ramp here that you are welcome to use,and not that far from you,see my other thread about ramp meet,rob.
Jeags (Fri Nov 01, 2019 6:19 pm)
Vj4sothername
Post by Vj4sothername » Fri Nov 01, 2019 6:17 pm
goodeggbob wrote:Hi there,i ,along with john,have had good luck with buying engines. as said before,contact big pete and see if he can help. in my opinion,there is nothing wrong with having a reserve engine,especially if you are keeping the car for a while. also ,i have a ramp here that you are welcome to use,and not that far from you,see my other thread about ramp meet,rob.
10/10 recommend Robs ramp. Robs ace too! Pete's a great guy with a large selection of parts and put up with my nonsense. 10/10 would order again.
Feb 08 built,
Dents,
Scratches,
Replacement engine,
Smiles
Jeags
Post by Jeags » Fri Nov 01, 2019 6:19 pm
Cheers for all your help guys, will start investigating options now!
Vj4sothername
Post by Vj4sothername » Fri Nov 01, 2019 6:22 pm
Jeags wrote:Cheers for all your help guys, will start investigating options now!
Any questions drop me a pm.
If it was to all work out time wise I could be tempted with another trip to robs.
Jeags (Fri Nov 01, 2019 6:23 pm)
Feb 08 built,
Dents,
Scratches,
Replacement engine,
Smiles
