Stereo sucurity bolt
- Has thanked: 105 times
- Been thanked: 46 times
Hi all sorry to be a pain could someone please tell me where the above is located exactly please
A pic would be good(through drivers side or passenger side?)
Many thanks
Dazza
Many thanks
Dazza
Re: Stereo sucurity bolt
Driver's side, up behind the plastic on the left of the driver's side footwell.
- Dazza44 (Fri Oct 25, 2019 10:00 am)
Next problem got the stereo out put it back in and nothing completly dead I've checked the cabin fuse that s fine
Anyone any ideas please was all working before i removed it
- Has thanked: 750 times
- Been thanked: 175 times
The connection between the front plate and the actual unit is probably loose. I had the exact same thing. Take the faceplate off, check/clean the contacts and put back together.Dazza44 wrote:Next problem got the stereo out put it back in and nothing completly dead I've checked the cabin fuse that s fine
- Dazza44 (Fri Oct 25, 2019 12:16 pm)
Thanku silly question but do when u say front plate do u mean were all the buttons are for the stereo are
Sorry if I sound daft
That's the one! Was just trying to find a guide on YouTube but I can't see one. I can't for the life of me remover how I did it. It wasn't hard though I remember that much. Undid from the back I think.Dazza44 wrote:Thanku silly question but do when u say front plate do u mean were all the buttons are for the stereo are
- Has thanked: 112 times
- Been thanked: 74 times
Yeah what he said.
The facia is screwed to the unit with 4 screws.
But the problem is the brass / copper sleeve inserts which are inserted into the facia. Over time, those sleeves become loose and the facia slowly moves away from the unit. So no screwing back in will work and if it does, it will work its way out again.
Unscrew the 4 screws, carefully remove the unit from the facia making sure not to bend any contact pins.
Then push the sleeves back into the facia and add a dab of super glue ( a tiny bit! ) wait for the super glue to fully cure before carefully offering the facia to the unit again being mindful that you are guiding the contact pins into their original position.
Then screw the 4 screws back in. That problem will be solved. Very rare. If that doesn't work then it's possibly buggered
- These users thanked the author sKenDread for the post:
Kia-ora!
'09 R3 Aurora Blue Mica
- Been thanked: 2086 times
If you removed the audio unit without disconnecting the battery first then an anti-theft feature in the unit would have been triggered and part of the circuit would have burnt-out.
As an anti-theft feature this is totally ineffective, because they don't tell anyone about, yet it would only be a deterant if the scrots knew that a stolen unit would be unusable.
Thankfully there is a way to repair the board, and the information is on the forum.
Ah didn't disconnect the battery first
Shoot
Can u point me.how to solve this please?
Shoot
I'll find the link when I'm home on my desktop, unless someone else can do a search first...
"audio battery fuse link "
- Dazza44 (Fri Oct 25, 2019 12:16 pm) • sagarh (Sat Oct 26, 2019 6:34 am)
That's a really good point Dave. By habit I always pull the battery before doing any electrical work.
Check those screws connecting the facia to the unit. There shouldn't be a gap and if you look close you might see the sleeves sticking out of the facia. So give that fix a whirl. Don't bother about the superglue, if you're diagnosing.
Hopefully by you pulling the head unit out by pulling on the facia, its pulled the connections away which is really common. Once you've done the fix it, reconnect all the unit connectors without fitting back into its place and reconnect the battery.
Hopefully it will come back on. If not, then you will have to do what Daves suggested
Best of luck
Keni
Best of luck
Keni
Kia-ora!
Thanks everyone for your help much appreciated
It turnt out being the facial a little loose.
- These users thanked the author Dazza44 for the post:
- 30405 (Fri Oct 25, 2019 12:24 pm)
And there's me thinking it was the loose nut holding the steering wheel
- Dazza44 (Fri Oct 25, 2019 12:25 pm)
I've decided I'm going to renew my membership,as the advice and help everyone continues to give is value for money on its own.
- These users thanked the author Dazza44 for the post (total 5):
- warpc0il (Fri Oct 25, 2019 12:25 pm) • sKenDread (Fri Oct 25, 2019 12:39 pm) • 30405 (Fri Oct 25, 2019 2:09 pm) • casey (Sun Oct 27, 2019 2:48 pm) • Ainmhidh (Sun Oct 27, 2019 11:22 pm)
