Abreviations Explained.
- Has thanked: 219 times
- Been thanked: 350 times
Good Morning, i was wondering whether people on here could post up on this thread,a typical abbreviation used in relation to our cars,with it's full meaning.
I ,for example, am sometimes stuck when it comes to a post that is full of them,and find that i am scratching my head sometimes,whilst also knowing that said post could be very useful to me.
I am not asking anyone to stop using them,far from it, but it may be useful to me,and possibly others if this post was dedicated to them. Please post up what you know,and i will add them to the o p.
2T - Usually applied to 2 stroke oil
4T - Sometimes used for 4 stroke oil
ABS - Anti-lock Braking System
ACC - Auto Climate Control
AFR - Air to Fuel Ratio (the ratio of the mass of air used by the engine, compared to the mass of fuel)
APP - Accelerator Pedal Position
APV - Auxiliary Port Valve (the additional intake port present on the higher-power 231 engines)
BHP - Brake Horse Power (usually measured at the crank / e shaft)
BP - Bridge Port
CAN - Controller Area Network (the digital network used by control modules to communicate)
CC - Cruise Control
CEL - Check Engine Light
COFS - Clean Oil Feed System (Ryan Rotary Performance device similar to Sohn system)
CPP - Clutch Pedal Position
CT - Coolant Temperature
DLC - Data Link Connector (OBD2 connector)
DSC - Dynamic Stability Control
DTC - Diagnostic Trouble Code
EBD - Electronic Brake force Distribution
ECU - Engine Control Unit
EGR - Exhaust Gas Recirculation (we don't have this)
EMOP - Electronic Metering Oil Pump (R3 version of OMP)
EPAS - Electric Power Assisted Steering
ES - Eccentric Shaft (a rotary's "crank" shaft)
ESS - Eccentric Shaft Sensor (points at the toothed wheel at the front of the ES)
FBP - Full Bridge Port
FL22 - Mazda's specification of very long life coolant
FWD - Front Wheel Drive (shopping trolleys )
FWHP - FlyWheel Horse Power
HBP - Half Bridge Port
HFS - Heated Front Screen
HHP - Hub Horse Power (OK, this isn't usually used, but it should be!)
HO2S - Heated Oxygen Sensor
HVAC - Heating Veintilation & Air Conditioning
IAT - Intake Air Temperature
JDM - Japanese Domestic Market (models or individual cars built to be sold specifically in Japan)
LIM - Lower intake manifold
LSD - Limited-Slip Differential
LTFT - Long Term Fuel Trim
MAF - Mass Air Flow sensor (pokes into the intake tube near the accordian tube)
MAP - Manifold Air (or Absolute) Pressure sensor (we don't actually have this sensor)
MIL - Malfunction Indicator Light (see CEL)
MSP - Multi Side Port (as in the RX-8 engine designation "13B-MSP")
O2S - Oxygen Sensor (aka Lambda sensor)
OAT - Organic Acid Technology (a type of coolant)
OBD - On-board Diagnostics
OMP - Oil Metering Pump (the pump that supplies the rotor oil injectors)
OP - Original poster (the person who wrote the first post in the thread on a forum)
OT - Oil Temperature
PAS - Power Assisted Steering
PCM - Powertrain Control Module (the ECU (Engine Control Unit) of the car)
PID - Parameter Identifier (identifies a piece of diagnostic data from OBD)
PP - Peripheral Port
PPF - Power Plant Frame (the girder that connects the gearbox to the differential)
PS - Power Steering
R3 - The series 2 version of the RX8 available in the UK from 2009
RON - Research Octane Number (for fuel)
RWD - Rear Wheel Drive (like an RX-8)
RWYB - Run What Ya Brung (Usually relates to Drag Racing but can also be Tracks Days or Drifting)
S1 - Series 1, the original version of the RX8, released in 2003
SAI - Secondary Air Injection (the air pump that injects air into the exhaust manifold during cold starts, to heat up the catalyst)
S-DAIS - Sequential Dynamic Air Intake System (term describing the combined SSV, VDI, APV & VFAD system)
SP - Street Port
SRS - Suplementary Restraint System (Air bags!)
SSV - Secondary Shutter Valve (One of the intake control valves on the intake manifold)
STFT - Short Term Fuel Trim
TC - Traction Control
TPMS - Tyre Pressure Monitoring System
TPS - Throttle Position Sensor
UIM - Upper intake manifold
VDI - Variable Dynamic-effect Intake (a valve that open at high revs to link the two intake tracts and provide "dynamic air charging effect")
VFAD - Variable Fresh Air Duct (system used on 231 models to shorten the pre-airbox intake length at higher revs)
VSS - Vehicle Speed Signal
WHP - Wheel Horse Power (Measured by rollers running on the car's tyres)
WOT - Wide Open Throttle
BP - Bridge Port
CC - Cruise Control
PS - Power Steering
SP - Street Port
- These users thanked the author goodeggbob for the post (total 4):
- 30405 (Tue Oct 22, 2019 9:50 am) • PeteH (Tue Oct 22, 2019 10:01 am) • Ainmhidh (Tue Oct 22, 2019 5:04 pm) • CylonOne (Fri Nov 01, 2019 9:40 pm)
- Has thanked: 318 times
- Been thanked: 256 times
Re: Abreviations Explained.
UIM - Upper Intake Manifold
MAF - Mass Air Flow
PCM - Power-train Control Module
MAP - Manifold Absolute Pressure
PS - Power Steering
HVAC - Heating Ventilation & Air Conditioning
AFR - Air Fuel Ratio
MAF - Mass Air Flow
PS - Power Steering
Last edited by MARKTHOMASBRAND on Tue Oct 22, 2019 9:20 pm, edited 1 time in total.
- These users thanked the author MARKTHOMASBRAND for the post (total 2):
- bigpete8 (Tue Oct 22, 2019 9:51 am) • goodeggbob (Tue Oct 22, 2019 7:01 pm)
- Has thanked: 750 times
- Been thanked: 175 times
- MARKTHOMASBRAND (Tue Oct 22, 2019 8:25 pm)
- Has thanked: 147 times
- Been thanked: 287 times
MTB-MARKTHOMASBRAND
- These users thanked the author kopite72 for the post (total 3):
- Shagrington (Tue Oct 22, 2019 11:46 am) • MARKTHOMASBRAND (Tue Oct 22, 2019 8:25 pm) • brix79 (Tue Oct 22, 2019 9:07 pm)
Great idea. I've taken the liberty of incorporating all of these, and adding my own, into the OP's post (while I still have the awesome power of the edit.... )
- Has thanked: 34 times
- Been thanked: 40 times
RTFI - Read the f*cking instructions
RTFM - Read the f*cking manual
- These users thanked the author Paul_13 for the post (total 3):
- 30405 (Tue Oct 22, 2019 11:52 am) • nightfire10 (Tue Oct 22, 2019 3:22 pm) • MARKTHOMASBRAND (Tue Oct 22, 2019 8:25 pm)
- Has thanked: 23 times
- Been thanked: 111 times
Another shirt ruined; thanks a lot
Ranjan.
- These users thanked the author Ranjan for the post (total 2):
- Paul_13 (Tue Oct 22, 2019 11:46 am) • 30405 (Tue Oct 22, 2019 11:52 am)
The following :
CC = Cruise Control
ACC = Auto Climate Control
EPAS = Electric Power Assisted Steering
PAS = Power Assisted Steering
HFS = Heated Front Screen
I will think of a few more Rob
CC = Cruise Control
- Been thanked: 25 times
- Been thanked: 2086 times
SWMBO - She Who Must Be Obeyed ("The owner of the balls", rather than "The keeper of the balls", in a relationship)
PICNIC - Problem In Chair Not In Computer
- These users thanked the author Essex2Visuvesi for the post:
- sKenDread (Fri Oct 25, 2019 8:35 am)
My understanding is that IAT is "Intake Air Temp" not "Indicated" - although I may be wrong
Some others:
Some others:
Ah Jesus lads it's all a bit OTT ( no pun intended) now. Anyone looking at that would be like
- These users thanked the author Paul_13 for the post (total 2):
- GreySilver Beast (Tue Oct 22, 2019 6:51 pm) • PeteH (Tue Oct 22, 2019 8:51 pm)
I think all these TLA s need to be in in the FAQ...
WTF,i wasn't expecting that,very useful though,even if a little OTT,ROB.
THIS IS THE ONE THAT GOT ME THINKING ABOUT THIS
- 30405 (Tue Oct 22, 2019 6:53 pm)
As discussed by the Moderators - behind the scenes - the final output of this thread will be added to the FAQ for future reference.
- GreySilver Beast (Tue Oct 22, 2019 6:52 pm)
EXCELLENT IDEA DAVE,I TRUST THAT THE MODS CAN SORT OUT THE RELEVANT STUFF,ROB.
Don't shout
SASM - steering angle sensor module (not sure if that exists actually. It's listed on forscan)
RKE - immobiliser
RKE - immobiliser
